HDMI ARC Confusion - AVS Forum | Home Theater Discussions And Reviews
Old 10-10-2010, 12:01 PM - Thread Starter
balpers's Avatar
This is dumb, but I am new to HDMI and ARC.
I'm going to upgrade to a new system in the next few months:
Vizio XVT553sv
Denon AVR-3311CI
The Vizio allows ARC only on the HDMI-1 input.
The Denon allows ARC only on the Monitor-1 output.
I have a few questions:
  1. Are these devices compatible with respect to ARC?
  2. Does the connection diagram in the attachment make sense?"
  3. Do I need optical connection #3 to get digital audio from the HR20 DVR?
Please help unconfuse me.
Burt
The Consultant's Creed:
I can do it right.
I can do it cheap.
I can do it fast.
You get to choose any two.
balpers is offline
Old 10-10-2010, 12:30 PM
petern's Avatar
If you are hooking your DirecTV HR20 up with HDMI to the Denon Receiver, why do you want audio coming from the Vizio TV?
petern is offline
Old 10-10-2010, 12:55 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi balpers, there's an issue with Vizio ARC. Check out the LCD Flat Panel Display forum under "Vizio XVR3SV".
JChin is offline
Old 10-10-2010, 01:02 PM - Thread Starter
balpers's Avatar
If I am understanding this correctly, using ARC is the only way to get the Audessey display and the Denon GUI to show up on the screen.
I can do it right.
I can do it cheap.
I can do it fast.
balpers is offline
Old 10-10-2010, 01:03 PM - Thread Starter
balpers's Avatar
I'll check this out.
I can do it right.
I can do it cheap.
I can do it fast.
balpers is offline
Old 10-10-2010, 01:22 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
No it does not require ARC (Audio Return Channel).
JChin is offline
Old 10-10-2010, 01:28 PM - Thread Starter
balpers's Avatar
I'll go back and read the manual more carefully. Like I said, this is all new to me.
I can do it right.
I can do it cheap.
I can do it fast.
balpers is offline
Old 10-10-2010, 01:34 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
FYI, there's a Official Denon 3311CI/ 991 Owner's Thread (with lots of info) where you can search for answers and post your questions.
JChin is offline
