Looking for a good / reliable 5.1 budget receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 10-16-2010, 07:09 PM - Thread Starter
cgprelude's Avatar
I'm about to purchase two front Pioneer floor standing speakers and the pioneer front channel. I figure since I'm not even doing a full surround sound setup getting an expensive receiver is of no real value to me.
My main concern is that the receiver does a decent job for what I'm asking and doesn't break after a few years (overheating issue?).
So far these are the the two I'm concidering:
http://www.amazon.com/Onkyo-TX-SR308.../dp/B003BEDQQM
http://www.amazon.com/Pioneer-VSX-52.../ref=de_a_smtd
Please share your thoughts and what you would if you only needed it for the TV/DVD/Xbox and had this speaker setup.
cgprelude is offline
post #2 of 16 Old 10-16-2010, 07:26 PM
rabican's Avatar
also the slightly higher pioneer model: http://www.amazon.com/Pioneer-VSX-82...039XQL2G...but the two you listed are better for comparison purposed.
rabican is offline
post #3 of 16 Old 10-16-2010, 08:27 PM
zieglj01's Avatar
Quoted: 1708 Post(s)
Liked: 1623
The VSX 820 will be ok - the Pioneers don't run as hot, as the
Onkyo receivers.
__________________________________________
Who AM I
Speakers -- Canton GLS 2 > Boston VS240
Receiver -- Integra 50.2
zieglj01 is online now
post #4 of 16 Old 10-16-2010, 09:38 PM - Thread Starter
cgprelude's Avatar
Thats good to hear about the Pioneers. What about this Yamaha? It has 4 HDMI ports and is only slightly more. Would this be a better buy?
http://www.amazon.com/Yamaha-HTR-306...7290075&sr=1-1
post #5 of 16 Old 10-16-2010, 09:57 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
I am not impressed with that Yamaha model. If your budget could swing it, I would suggest a better model like the RX-V667.
If not, there may be better deals out there. New egg often has really good deals.
Not trying to encourage you to spend a lot of money, but 5.1 receivers are often ultra budget models. In those models, they make the biggest compromises in the power supply, among other things.
Using a 7.1 receiver for 5.1 is totally fine, and you are not really wasting much money on the unused amps ( they are really just a handful of cheap parts.) These models are usually more capable.
"But this one goes up to 11"
MichaelJHuman is offline
post #6 of 16 Old 10-16-2010, 10:02 PM - Thread Starter
cgprelude's Avatar
I understand the "not wasting" since they are more quality parts but I'm unable to push it any further since I was given a 2k budget for TV + sound and I don't want to waste too much on receiver when I still need TV and stand.
Any thoughts on this Denon?
http://www.amazon.com/Denon-AVR-391-.../dp/B003QP3M8I
Looks like it's getting good reviews and I've always heard good things about Denon.
MichalJHuman - Could you explain why the power supply is so important?
post #7 of 16 Old 10-16-2010, 10:22 PM
Knucklehead90's Avatar
Quoted: 504 Post(s)
Liked: 435
How about a refurbished Denon 1610?
You could go even cheaper with a 589 -- or 590 if you can push the budget a bit. All of these have Audyssey MultEQ which will help a lot in getting the best out of your speakers.
Yamaha CX-A5000 - VTA ST-120 (6550 output tubes) - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - Acurus A100 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #8 of 16 Old 10-16-2010, 11:09 PM
jdsmoothie's Avatar
Quoted: 15322 Post(s)
Liked: 7475
Do you plan on buying a 3D TV, otherwise there's no need to buy an HDMI 1.4 AVR? The above Denon AVR does not include the ARC feature nor will it allow you to pass an HDMI source through while it's in Standby (ie when wanting to use the TV's speakers only). It also doesn't include the Audyssey speaker calibration system. For not much more you can upgrade to the 1611 which include all of the above. Give Denon authorized vendor Electronics Expo a call for their best price (as they list MSRP on their website).
jdsmoothie is offline
post #9 of 16 Old 10-17-2010, 06:37 AM - Thread Starter
cgprelude's Avatar
I've always been scared of buying refurbished products but I see a lot of guys recommend it in the threads. Is this something that people don't worry about with these manufacturers?
Also another question: I'm trying to understand speaker impedance; the speakers operate at 6ohms and the receiver is (6-ohms @1kHz, 75-Watts x 5 @ 8-ohms, 20 - 20kHz). I read that if the speaker impedance is lower than the amplifier impedance, the amplifier will tend to overheat and more power is used up in the amplifier than is delivered to the speaker. Is this just a setting I can change to make it function correctly on the 6ohms?
post #10 of 16 Old 10-17-2010, 07:02 AM
jdsmoothie's Avatar
Liked: 7475
Refurbished Denon AVRs come straight from Denon. Dakmart extends the normal 90 day Denon warranty to a full 1 year and would be a better choice over eCost. Although in some cases you can get a brand new unit for a very similar price from Electronics Expo.
post #11 of 16 Old 10-17-2010, 07:15 AM
rabican's Avatar
is there any plus to 1.4hdmi if you dont own a 3d tv?
other than being future proof...?
rabican is offline
post #12 of 16 Old 10-17-2010, 07:20 AM
jdsmoothie's Avatar
Liked: 7475
Nope. Which is why buying last year's models would be the better buy.
post #13 of 16 Old 10-17-2010, 07:28 AM
rabican's Avatar
this makes sense. which do you feel is best for under 250$...? (cheaper is better) esp sense only being used with two pioneer floor speakers...
rabican is offline
post #14 of 16 Old 10-17-2010, 07:42 AM
jdsmoothie's Avatar
Liked: 7475
As Knucklehead suggested ... the Denon 1610, either refurbished at Dakmart or see what Electronics Expo will sell it to you for brand new which would then include a full 2 year warranty.
post #15 of 16 Old 10-17-2010, 08:33 AM
rabican's Avatar
the 1610 looks like a solid choice, what would be your second choice if you werent going refurb (under 250$)?
rabican is offline
post #16 of 16 Old 10-17-2010, 08:34 AM
ratm's Avatar
Quoted: 41 Post(s)
Liked: 39
im not sure if there are any left, but newegg had the Yamaha rx-v765 for $299 shipped. New.
ratm is offline
