Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 36Likes
post #991 of 17053 Old 12-24-2010, 07:08 AM
ekka.ied's Avatar
Originally Posted by Shrike645 View Post
Is Dolby volume on?
No. Infact I just re-installed the firmware, still no good. It's a MRX-500.
ekka.ied is offline
post #992 of 17053 Old 12-24-2010, 08:08 AM
HeffeMusic's Avatar
Quoted: 175 Post(s)
Liked: 75
You have to go into the menu of the AVR and turn off Dolby volume for each source.
HeffeMusic is offline
post #993 of 17053 Old 12-24-2010, 09:17 AM
Chucka's Avatar
Quoted: 116 Post(s)
Liked: 39
Does anyone have any updates on the progress of the MRX-900? Any sign of it being in the hands of Beta Testers. Will it be shown at CES?
Chucka
Chucka is offline
post #994 of 17053 Old 12-24-2010, 09:21 AM
Shrike645's Avatar
Quoted: 46 Post(s)
Liked: 40
Chucka
I think the 900 is still a long ways off.
Shrike645 is offline
post #995 of 17053 Old 12-24-2010, 10:19 AM
ekka.ied's Avatar
I'll check it at my clients place tomorrow but I'm just curious, how is it that an Audio CD plays very cleanly when the DSP is at 'All Channel Stereo' but gets completely muffled when its on 'Stereo' or 'Dolby vs Ref'??
My interconnect is an AQ Forest and the Source is a Denon DBP-2010 just in case.
ekka.ied is offline
post #996 of 17053 Old 12-24-2010, 10:47 AM
HeffeMusic's Avatar
Quoted: 175 Post(s)
Liked: 75
I think in all channel stereo, there is no Dolby involved.
post #997 of 17053 Old 12-24-2010, 11:06 AM
slvrado's Avatar
Hi Guys,
Here are my curves, have a look. I can't figure our why my room gain is zero.
slvrado is offline
post #998 of 17053 Old 12-24-2010, 11:21 AM
TKO1's Avatar
Liked: 65
Originally Posted by slvrado View Post
Hi Guys,
I can't offer any reason for your lack of room gain but your subwoofer should not be reproducing sounds that high. Normally you wouldn't expect to see the subwoofer reproduce any frequencies above 500Hz. Yours is reproducing frequencies up to 6kHz! Maybe this is something to look into?
Cheers.
Tony
TKO1 is offline
post #999 of 17053 Old 12-24-2010, 11:51 AM
akopperl's Avatar
Quoted: 34 Post(s)
Does ARC set listener position from speakers?
Also, do I need to shut Dolby Volume off for all sources and set speaker levels to 0 prior to running ARC?
akopperl is offline
post #1000 of 17053 Old 12-24-2010, 11:56 AM
Shrike645's Avatar
Quoted: 46 Post(s)
Liked: 40
You need to enter speaker distances manually but you do not need to shut off dolby or set the levels. ARC will do that.
post #1001 of 17053 Old 12-24-2010, 05:15 PM
Unobtainium's Avatar
My new mrx700 is on order with studio 100's, and 2 sub 12's. Going to use this and my HK sig 2.1 to bi-amp the front 3 speakers. Should be a real nice upgrade all around.
Luckily the dealer is coming out to install, set-up, and PBK and ARC the system for me. 2 weeks is going to seem like forever. They had no stock at all.
"The bitterness of poor quality lingers long after the sweetness of low price subsides"
Unobtainium is offline
post #1002 of 17053 Old 12-24-2010, 10:21 PM
ekka.ied's Avatar
Hi,
So I had a look and Dolby Volume is off for all sources but yet the muffled sound when on 'Stereo', 'Dolby vs Ref' & 'Dolby Wide'.
Writing to Anthem, lets see what they have to say.
ekka.ied is offline
post #1003 of 17053 Old 12-25-2010, 01:29 AM
m_maloney's Avatar
It's Christmas which means I get to open my Anthem MRX500 today!! Happy holidays everyone and thanks for all the helpful info. I'm sure I'll be posting questions soon...
m_maloney is offline
post #1004 of 17053 Old 12-25-2010, 05:32 AM
HeffeMusic's Avatar
Quoted: 175 Post(s)
Liked: 75
Hi,
Hi,
I am curious are you using analog interconnect cables or HDMI? The only way you are going to get the top performance out of this AVR is with HDMI.
post #1005 of 17053 Old 12-25-2010, 09:48 AM
ekka.ied's Avatar
Hi,
Everything is on HDMI, source connections and projection output. I'm using the AudioQuest Forest HDMI cables.
ekka.ied is offline
post #1006 of 17053 Old 12-25-2010, 12:41 PM
HeffeMusic's Avatar
Quoted: 175 Post(s)
Liked: 75
Hey guys when ARC reads EQ @ top setting, what does that mean? I feel like my highs are a little hot?
post #1007 of 17053 Old 12-25-2010, 01:03 PM
TKO1's Avatar
Liked: 65
Hi
Not sure I understand your issue. Can you please elaborate?
Cheers
Tony
TKO1 is offline
post #1008 of 17053 Old 12-25-2010, 03:03 PM
HeffeMusic's Avatar
Quoted: 175 Post(s)
Liked: 75
Originally Posted by TKO1 View Post
Hi
Cheers
Tony
In the targets window under EQ it has a setting from 200-5000. My setting is 5000.
post #1009 of 17053 Old 12-25-2010, 03:09 PM
markabuckley's Avatar
Quoted: 95 Post(s)
Liked: 33
can you manually EQ > 5khz ?
just in my current setup - I use a -2.5dB cut on my centre at 8khz, and it seems to makea noticeable improvement.
I'm guessing I couldnt' with the MRXs ?
markabuckley is offline
post #1010 of 17053 Old 12-25-2010, 03:41 PM
bruce24's Avatar
I just unboxed my MRX-500, hooked everything up, powered up for the first time and started going through the setup screens. I soon realized that my select button doesn't work on the remote. While the red light illuminates when I press the SEL button, the receiver doesn't do anything. If I go over and press the button on the receiver, it works.
Has anyone else had this issue?
-Bruce
bruce24 is offline
post #1011 of 17053 Old 12-25-2010, 05:26 PM
TKO1's Avatar
Liked: 65
Hi
in this instance this is the maximum frequency where ARC stops applying equalization. In other words ARC will attempt to maintain a constant dB level across the frequency range until it reaches the maximum EQ frequency (e.g. 5000Hz), above this frequency it will not be equalized.
Hope this helps. Cheers.
Tony
TKO1 is offline
post #1012 of 17053 Old 12-25-2010, 05:29 PM
TKO1's Avatar
Liked: 65
Hi,
not sure if you can go higher. I never tried it personally and the ARC user manual argues against it:
The default correction range is up to 5 kHz. Although the limit can be changed if needed, a higher one is generally not advised since the microphone becomes directional at upper frequencies, affecting measurement accuracy especially if the height of the speaker's high frequency driver is not at ear level.
Tony
TKO1 is offline
post #1013 of 17053 Old 12-25-2010, 05:35 PM
Shrike645's Avatar
Quoted: 46 Post(s)
Liked: 40
Hi,
Tony
For The MRX Receivers ARC is limited to 5K. The statement processors allow up to 20K but most people tried it at first but most seem to backing down to 5K.
post #1014 of 17053 Old 12-25-2010, 05:58 PM
HeffeMusic's Avatar
Quoted: 175 Post(s)
Liked: 75
Hi
Tony
Ok,
post #1015 of 17053 Old 12-25-2010, 06:51 PM
slvrado's Avatar
-Bruce
Nope, mine works fine. I have an MRX500.
slvrado is offline
post #1016 of 17053 Old 12-25-2010, 07:22 PM
bruce24's Avatar
Thanks, I'll call Anthem and see if they will send me a replacement.
bruce24 is offline
post #1017 of 17053 Old 12-26-2010, 12:25 PM
HeffeMusic's Avatar
Quoted: 175 Post(s)
Liked: 75
Hey guy's
I am noticing a sound, a kind of a click that comes out of my rear channels when the amp changes incoming sound codecs. An ex of this is when I am watching a blue ray and the audio changes from Dolby digital to Dts master, you can hear the codec change over with a low popping sound. Has anybody else experienced this?
post #1018 of 17053 Old 12-26-2010, 06:01 PM
KB007's Avatar
Weird thing just started between my MRX700 and Bell HD receiver. On HD channels with DD audio, the sound is gone. Haven't changed anything in either device's config, it just stopped working. If it's an SD channel with PCM 2 channel it works fine. Was only using a single hdmi cable between the 2.
Have changed cables, diff cable in diff input, checked config of the Bell box and it's all as it shoudl be. Have dbl checked with BD player - it works fine into it's normal inout and into the input usually used for the sat receiver. Currently the only way I can get audio from an HD DD channel is via a swapped in optical cable and setting input to Opt1. HDMI Dig just doesn't seem to be working.
Any ideas?
KB007 is offline
post #1019 of 17053 Old 12-26-2010, 06:09 PM
slvrado's Avatar
I had the same problem. This has been fixed in a recent software update. Check the release notes on the Anthem web site after you download the upgrade.
slvrado is offline
post #1020 of 17053 Old 12-26-2010, 07:21 PM
Nov
Nov's Avatar
So what am I doing wrong? I can't get video out when I'm using my Blu-ray player. Sound is coming out fine.
I've got a MRX-500 along with a Panny BD-55 connected to an older Optoma HD77 projector.
The input is set to auto resolution for video.
The projector is searching but can't find the signal.
I've connected the same input to my satellite receiver and the picture and sound come out fine (also used the same cables).
Any suggestions?
Craig
Nov is offline
Anthem Mrx500 , Anthem Mrx300 , Anthem Mrx700 , Receivers Amplifiers , Component Amplifiers , 3d Hdtv , Speaker Systems
