Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide - Page 354 - AVS Forum | Home Theater Discussions And Reviews
 36Likes
Old 05-07-2012, 09:07 PM
sharp10's Avatar
Originally Posted by mikey94025 View Post
This is a useful reference and likely helpful to others who aren't getting optimal sound. Can you summarize what in the end improved things for you, e.g. speaker placement, rerunning ARC, firmware, etc.? Thanks!
I was fairly happy with my MRX right out of the box but after running ARC, I felt that I may have done more harm than good. It just didn't sound right to me. The sound was not as warm as I like and I found music to be very bright and fatiguing. Good sound should be easy to listen to for long periods of time. This was not the case for me.
So I would post my charts over and over, each time changing things based on suggestions from this thread.
Some of the adjustments I made were.....moving my fronts away from the wall.changing mic positions, moving my sub around, and replacing my sub. I continued to have sub issues and eventually used quick measure and moved some furniture to unbox my sub. I also used more than 5 mic positions when running ARC. Things finally sounded great. Even then it was suggested that that I only use 5 mic positions but I didn't run ARC since I felt things were fine. I eventually did go back to 5. . Well it turned out that Tigger was right on this one too. I didn't even feel the need to post my charts. It has been at least a month now since I ran ARC and don't feel the need to do it again unless something changes to my room ......very happy with my Anthem.
sharp10 is offline
Old 05-08-2012, 05:29 AM
Hostility's Avatar
hey guys, just a question. Im still dying to pick one of these up, i found a used mrx 500 For about $100 less the what the 300 sells for, but its used. Is there much difference between 300 and 500? Or am i better off buying new with warranty. I would still have to toss in money for gas ontop of the mrx500, where i wouldn't with the 300.
Hostility is offline
Old 05-08-2012, 05:33 AM
ninja12's Avatar
Originally Posted by sjb266 View Post
Hey everyone.. Great thread.. Has been so helpful in the few days i've had my MRX700...
Ive done an ARC calibration and am a bit disappointed in the lack of bottom end.. I don't know if the ARC just corrected for a total bass trap of a room or if i'm doing something wrong!
My main concern is the Music profile which was done just using L/R and no sub..
My speakers are Dynaudio Confidence C2's which have a fairly decent bottom end...
Maybe all the experts here could have a look at my graphs and offer me some advice..
Cheers..
S.
Definitely follow the advice that Jayray and Tigger has provided.
I do have a question for you. Did you change the mic positions between taking measurements for Movie vs Music? I'm asking because ARC couldn't tame the peak in your fronts at all for Music; but, ARC did tame the peak in your fronts for Movie. The only reason that I can think of that causes this is different mic positions between Movie and Music.
As for your sub, do as Tigger suggested by trying different sub locations. The goal is to reduce/eliminate that peak at 40Hz so that you don't have close to a 20db drop from 40Hz to 70Hz. Hopefully, that will help ARC in naturally setting a cutoff of 120Hz for your sub.
Good Luck!!
ninja12 is offline
Old 05-08-2012, 07:23 AM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
I was also torn between getting the 500 and 300. If you don't need the usb ports and iPod dock, I would go for the 300. I thought I would use the usb ports for playing back my media files but I found that it would not recognize or play back many of my music files.
Since you can get a used 500 for less than a new 300, it may be worth it; however, the warranty is not transferable. If you go with the used unit, make sure to give it a good testing before agreeing to buy it.
As has been mentioned before, all of the audio/video circuitry in the 300, 500, and 700 are identical. As you go up the line, you get some added features.
I assume you saw the receiver on Canuck? If it's the same posting, I noticed that the seller is the second owner of the unit.
audit13 is offline
Old 05-08-2012, 10:49 AM
Hostility's Avatar
Yes it is the one on Canuck, I think I might just wait And get a 300, I want one so bad but I really would like having the piece of mind of having warrenty
Old 05-08-2012, 12:24 PM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
If it's the same mrx-500 that was posted a few weeks ago, the original owner has great feedback on Canuck and the current seller has great feedback from one buyer.
Since it's been through two owners, I would think that any problems with the unit would have been noted and presumably rectified.
If I didn't already have an mrx, I'd be tempted to buy it myself
audit13 is offline
Old 05-08-2012, 03:31 PM
Hostility's Avatar
the owner selling it now, said hes had it for 3 weeks
Old 05-08-2012, 03:44 PM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
I would assume that the seller thoroughly checked out the machine and, if he or she wants to maintain their good reputation, any problems or issues would be disclosed to the potential buyer.
I understand your hesitation. I have a 500 which I purchased from an Anthem retailer. I wanted a used one to save myself some money but there weren't any for sale when I made the decision to take the plunge. I searched for about 3 weeks and couldn't stand it anymore. After reading all of the glowing reviews and this entire thread, I bought it and don't regret it.
audit13 is offline
Old 05-08-2012, 03:49 PM
RaggedEdge's Avatar
Get a new 300 from an authorized dealer and be happy. If you don't mind haggling a bit and paying cash, your local dealer will probably come down the $100 and you can get the 300 for the same as the used 500.
Alex
RaggedEdge is offline
Old 05-08-2012, 05:58 PM
Hostility's Avatar
Very true! My main goal was to do mrx300 and if needed more power then xpa5. Maybe I'll go see my local dealer with cash in hand instead. I know these are great units but you never know what could happen
Old 05-08-2012, 07:27 PM
kzhtoo's Avatar
I'm thinking of upgrading from Integra DTR 40.3 to MRX-500.
Fronts: Paradigm Studio 60v5
(Adding a CC-590 center real soon)
Sub: Paradigm Studio Sub 12 (PBK)
A) Is it worth upgrading?
- Sound quality
- ARC vs. Audyssey
(I can live with no analog inputs and a few less HDMI ports)
B) Integra is 110W per channel. MRX-500 is 100W per channel. While knowing 10W difference might not be significant, I'm currently utilizing Integra's bi-amp option - 220W per one Studio 60 front. MRX's do not have this option and I'm wondering if this would be significant? (I do feel bi-amping sounds somewhat better when I compared with/without on Integra)
C) My room is roughly 25x15x12. I'm planning to add Rear and Surround speakers in the future, maybe even 7.1 system. Is MRX-500 capable of driving the entire system at moderately loud level?
Thanks in advance.
kzhtoo is online now
Old 05-08-2012, 07:28 PM
kzhtoo's Avatar
- Sound quality
- ARC vs. Audyssey
Thanks in advance.
Integra DTR-40.3 product page
http://www.integrahometheater.com/mo...s=Receiver&p=f
Old 05-08-2012, 08:51 PM
jayray's Avatar
Liked: 25
I've compared Audyssey XT against ARC and ARC had better soundstage (wider), better imaging and better sub correction, using the same speakers as yours. I believe you will hear a diff because of ARC, and yes it will drive your speakers. The room I tested it in was 14x18x9 and there was plenty to spare,
John
Jayray
Read the FAQs
jayray is offline
Old 05-09-2012, 07:36 AM
SimpleTheater's Avatar
Quoted: 202 Post(s)
Liked: 95
- Sound quality
- ARC vs. Audyssey
ARC is better than Audyssey, but is your room four walls of drywall or have you put in some diffusers and absorbers? This isn't just a low cost method of getting better sound, but nothing is going to fix room issues like good absorption and diffusion.
It takes 10x the wattage to double the decibel level. 10 watts is insignificant, of course this assumes the manufacturers specs are accurate!
Absolutely.
Why is there NO perfect equipment, only compromises?
SimpleTheater is offline
Old 05-09-2012, 11:56 AM
kzhtoo's Avatar
Absolutely.
Thank you, Jayray and ST. I think I'm gonna pull the trigger. It sounds great as it is with Integra right now but I just feel Integra is not pulling out the best from the 60s and Sub12.
Old 05-09-2012, 04:10 PM
Ouiff's Avatar
Kzhtoo
I am not the most knowledgable on these issues and I am not familair with the integra model and haven't heard it but i can say from personal experience that i had a Yamaha 671 and was disaapointed when i got home with this and the Studio 60s I had just purchased, i really felt like i wasn't getting the best out of the speakers, with the disappointment i did some resaearch and came across the anthems and convinced the fiance to let me upgrade and i have not looked back, the sound quality is supurb, ARC does a great job also. I don't run a sub and i annoy my neighbours (in an apartment) as it is, i can only imagine how good it would be with your sub.
The MRX doesn't have all the bells and whistles on it that some of the others do, and maybe an extra HDMI port might be nice but i think with your speakers, you will be very happy. Good luck
Ouiff is offline
Old 05-09-2012, 09:50 PM
Spurrier Sucks's Avatar
Quoted: 643 Post(s)
Liked: 466
Anyone running 2 subs with their MRX? Easy to blend/EQ?
Spurrier Sucks is offline
Old 05-10-2012, 07:20 AM
Giraffe's Avatar
Yes. I am running dual subs with my MRX with great results. My subs blend perfectly with my mains and load the room very evenly. There are no issues with localization and the bass is accurate and effortless. How it does in your situation will depend alot on your room, subs, placement and room treatments. You can be sure that if there are any issues, it won't be the MRX.
Giraffe is offline
Old 05-10-2012, 12:54 PM
usxplong's Avatar
Quoted: 104 Post(s)
Liked: 92
Can MRX 700 send AV to TV when it is off and setting the MRX to AVR (not AVR & TV or TV). Thanks in advance.
usxplong is offline
Old 05-10-2012, 01:59 PM
jayray's Avatar
Liked: 25
Yes. Turn on CEC on in Aud/Vid Setup and Presets and leave HDMI Audio Output on AVR. Turn off MRX and sound comes out of the TV.
John
Jayray
Read the FAQs
jayray is offline
Old 05-10-2012, 02:07 PM
usxplong's Avatar
Quoted: 104 Post(s)
Liked: 92
John
Thanks jayray. But how about picture? How can I get audio and video sent to tv when MRX is off. I want to eliminate cables. Thanks.
usxplong is offline
Old 05-10-2012, 02:20 PM
jayray's Avatar
Liked: 25
TV remains on when CEC is on. Sound is through the TV speakers ie. adjustable with TV controls.
John
Jayray
Read the FAQs
jayray is offline
Old 05-10-2012, 03:06 PM
usxplong's Avatar
Quoted: 104 Post(s)
Liked: 92
John
Thanks jayray. But now that I know about it, I found out that with CEC on AVRs will constantly use 40-50 watts of power. That is a lot of watts 24/7.
usxplong is offline
Old 05-10-2012, 03:36 PM
jayray's Avatar
Liked: 25
that is correct. So is it worth it for that feature to use that amount of power is a good question.
John
Jayray
Read the FAQs
jayray is offline
Old 05-10-2012, 06:13 PM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
The power consumption of many electronic components, even when turned "off", is one reason I use a power bar with individual switches to turn on and off each component.
audit13 is offline
Old 05-11-2012, 09:11 AM
sukumar's Avatar
Quoted: 12 Post(s)
My receiver mrx 700 is not responding well with Logitech 900 remote. Remote works well with Oppo 93 and most of the time with projector.
Basically, it is not turning off mrx 700 many times. Volume button does not respond for few seconds and then starts responding. Is there anything I am missing to fix these issues?
Also, device does not respond when 3d is on. I have to use original remote only. I read in a forum that it is due to projector sending IR for 3d. But I don't understand exactly what is happening to have conflict and also wonder if I can assign different channle or something so that receiver responds while 3d is on as well.
sukumar is offline
Old 05-11-2012, 09:23 AM
Rock Danger's Avatar
I have a logitech 900 and have no issues with the Anthem. Are you using IR or the RF blaster to control it? If you're using IR, try assigning the MRX to the blaster.
There is no other channel just the option of IR or RF to control devices.
Rock Danger is offline
Old 05-11-2012, 09:41 AM
Tigger!'s Avatar
Have you made sure the latest updates are on your remote? I have a Harmony One, but if you are using IR, they should behave the same.
As for 3D, try and see if you can some how block your MRX's IR receiver from seeing the Projector. (of course it still needs to see the remote from where you are sitting...).
You might try blocking the IR transmitter on your porjector (even for non 3D content) and see if all of your problems go away. Not a permanent fix, but at least it would help you isolate if the IR transmitter on the Projector is causing some or all of your issues.
As mentioned earlier, switching to RF on the remote and using an IR blaster for the MRX could be your solution if you find that covering the IR transmitter on your projector was a temporary solution. Keep in mind that you want to make sure the MRX can only see the IR blaster and not the projector when you go this route. Otherwise the Projector could still overwhelm the IR sensor on the MRX.
Please, before you ask a question about...
General Information on the MRX Series: See the First post here.
Technical Information including using ARC: See the "FAQ" post here.
Tigger! is offline
Old 05-11-2012, 09:44 AM
Tigger!'s Avatar
Originally Posted by niualaals94 View Post
I guess my question relates to whether or not the first 300 owners will be starting from scratch on bugs/issues or if they will benefit from what the 500/700 owners have uncovered.
300s benifit from the same fixes the 500/700 get (in general, some fixes don't apply to the 300).
As the main componenets of the 300 are the same as the 500/700, they all pretty much behave the same way, including any bugs they may be experiencing.
Tigger! is offline
Old 05-11-2012, 09:56 AM
sukumar's Avatar
Quoted: 12 Post(s)
Sorry. What do you mean by assigning MRX to blaster? What are the steps do to for this task?
I believe I am using IR. Basically, I got powered device (extender) and I connected one of mini blaster to it and put it in front of mrx 700 on the left side around 6 inches front of receiver.
sukumar is offline
Anthem Mrx500 , Anthem Mrx300 , Anthem Mrx700 , Receivers Amplifiers , Component Amplifiers , 3d Hdtv , Speaker Systems
