Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide - Page 391 - AVS Forum | Home Theater Discussions And Reviews
 36Likes
Old 08-09-2012, 01:00 PM
blb1215's Avatar
I am not one of the "experts" but it looks to me ARC has done an excellent job on your sub and should sound great! It really is not much difference on the corrected line than the "perfect" chart you have as reference. What cutoff did ARC select? If it is 120hz you are fine. I would say you should set the sub to flat as you have good output at 20hz.. SVS makes outstanding subs and the SVS PB-12 is a very capable performer.
Barry
blb1215 is offline
Old 08-09-2012, 01:02 PM
jayray's Avatar
Liked: 25
Originally Posted by crazzycanuck View Post
Thanks John for your input, do you agree that all channel should be seen here as an optional setting (glitch because it is missing) ?
I've never really used the different modes due to my lack of surround speakers.
John
Jayray
Read the FAQs
jayray is offline
Old 08-09-2012, 01:07 PM
Dordt1977's Avatar
Barry
Thanks for the reply Barry,
Arc set the cutof on 80 hz. In stereo the bass is missing some impact.
Dordt1977 is offline
Old 08-09-2012, 01:11 PM
jayray's Avatar
Liked: 25
Originally Posted by Dordt1977 View Post
Some advice needed.
What must i do to have the same sub chart as below?
This is my chart:
And should i set my sub to flat? I have a SVS PB-12 NSD
Your sub needs to be moved using ARCs quick measure utility. When you get a red measured line that is close to flat from 100-20Hz, then you remeasure using ARC and your cutoff in the targets page should be close to 120Hz. Flat from 100-20Hz gives you great punch that you are missing now. That sub chart is mine and it looked like yours when I started.
John
Jayray
Read the FAQs
jayray is offline
Old 08-09-2012, 01:34 PM
jayray's Avatar
Liked: 25
Some of the bass missing is because you have a 10dB drop from 70Hz to 100Hz. That's why moving it is necessary.
John
Jayray
Read the FAQs
jayray is offline
Old 08-09-2012, 01:39 PM
Tigger!'s Avatar
Looks like Anthem has removed all mention of the MDX-1 Dock from the Anthem Site and the MRX Datasheet frown.gif
Please, before you ask a question about...
General Information on the MRX Series: See the First post here.
Technical Information including using ARC: See the "FAQ" post here.
Tigger! is offline
Old 08-09-2012, 01:41 PM
Dordt1977's Avatar
John
Thanks for the advice John.
My sub is now between the center and the right front speaker.
I shall move the subwoofer to a different location and run quick measure.
Old 08-09-2012, 01:53 PM
saeyedoc's Avatar
Quoted: 82 Post(s)
Liked: 69
Guess I can stop holding my breath.
saeyedoc is offline
Old 08-09-2012, 01:57 PM
jayray's Avatar
Liked: 25
Inches can make a difference. I went from the front right corner to 8' up the right wall towards the seats. If I move it inches in either direction the graph changes a lot so keep that in mind.
John
Jayray
Read the FAQs
jayray is offline
Old 08-09-2012, 03:12 PM
bryan338's Avatar
Quoted: 23 Post(s)
Need you expert opinions...
I went to my local dealer and he gave me the price of Mrx500 for $1200 and Mrx300 for $800. Are the prices still high? Do you guys think the extra $400 for mrx500 is worth it? I dont need internet radio or usb, i already have apple tv and popcorn hour. Should i be worried if im going to buy is a display unit but never been used? They just took the unit out of the box for display, the mrx300 still has the plastic on the screen but the 500 doesnt have.
My speakers are Paradigm monitor 7s7, center 3 and polk tsi300 for surrounds.
bryan338 is offline
Old 08-09-2012, 03:15 PM
RaggedEdge's Avatar
@bryan338,
Your dealer is giving you a very good price on both. How big of a room are you trying to fill?
Alex
RaggedEdge is offline
Old 08-09-2012, 03:29 PM
bryan338's Avatar
Quoted: 23 Post(s)
Thank you so much for the reply. My living room is 2500 cuft and opens to the kitchen.
bryan338 is offline
Old 08-09-2012, 03:46 PM
RaggedEdge's Avatar
I would go with the 500 with the price that was quoted for you. Should be plenty of power.
Alex
Old 08-09-2012, 05:47 PM
dean-l's Avatar
It's a sad story that's way too common amongst the boutique audio companies.
I wonder if Apple insisted on something that just went farther than it was worth trying anymore.
Moderator harassment is wrong and immoral.
dean-l is offline
Old 08-09-2012, 06:00 PM
jayray's Avatar
Liked: 25
It's likely a lack of interest communicated from dealers. While a handful here may be interested, they likely don't think it's worth it.
John
Jayray
Read the FAQs
jayray is offline
Old 08-09-2012, 06:36 PM
sukumar's Avatar
Quoted: 12 Post(s)
I am playing music through usb. Unfortunately, my projector is not available now so I can't see what it is playing. They would have displayed file name, folders etc in the MRX display.
It is playing songs in the root directory. Now I can click next and play next song etc.There is only one sub directory. How do I play songs from that sub directory?
sukumar is offline
Old 08-09-2012, 06:49 PM
keefy6's Avatar
Liked: 30
white noise and popping noises from the center speaker.
i've read other posts, does the beta firmware upgrade eliminate this/
keefy6 is offline
Old 08-09-2012, 07:19 PM
ninja12's Avatar
Originally Posted by hydrotex View Post
Could some of you be so kind as to give some guidance on where to learn about room treatment. I've got some real nasty things that ARC is having a hard time with.
You can do a Google on room treatments and get plenty of info to read up on. What nasty problems are you having? Normally, room treatments are good down to about 60 Hz. If you begin to have problems lower than 60 Hz, then you will have to depend on placement and EQ.
ninja12 is offline
Old 08-09-2012, 07:24 PM
hydrotex's Avatar
Quoted: 16 Post(s)
Thanks. I'll be playing with placement again this weekend. I've gone so far as to move furniture and i don't see any movement in quick measure even though i see different results in ARC. Thought there might be a thread on AVS that i overlooked for room treatment.
hydrotex is offline
Old 08-09-2012, 07:25 PM
jayray's Avatar
Liked: 25
You'll have to try it yourself. Not everyone has that issue, me included, so it's worth testing.
John
Jayray
Read the FAQs
jayray is offline
Old 08-09-2012, 07:29 PM
keefy6's Avatar
Liked: 30
John
not reassuring but ok. i have 50.24 beta, i'll check the website if there is a new one.
keefy6 is offline
Old 08-09-2012, 07:38 PM
sharp10's Avatar
Apple tv provides the same purpose with more features.
Sent from my iPad using Tapatalk HD
sharp10 is offline
Old 08-09-2012, 08:05 PM
ninja12's Avatar
There sure is: http://www.avsforum.com/t/255432/acoustical-treatments-master-thread
ninja12 is offline
Old 08-09-2012, 08:21 PM
hydrotex's Avatar
Quoted: 16 Post(s)
Thank you, Thank you, Thank you, Thank you, Thank you! :-)
hydrotex is offline
Old 08-10-2012, 06:21 AM
larry_in_keller's Avatar
Another source of links for you. http://www.avsforum.com/t/1332114/master-thread-of-favorite-at-links
I found the Real Traps and GIK sites to have very useful information (yes they sell products but provide unbiased information / assistance.) Just a word of warning . . if you suffer from COD (compulsive, obsessive disorder) reading these links won't help your condition. smile.gif
larry_in_keller is offline
Old 08-10-2012, 07:05 AM
HeffeMusic's Avatar
Quoted: 175 Post(s)
Liked: 75
John
John,
I respect your help an opinions 100%, but in this case that answer does not make any sense. When these AVR's first came out one of highlights in there advertisement was an Apple Dock coming soon? In today's Audio World this feature is a huge selling point. I LOVE my MRX 700 but I cannot believe they gave up on this. This looks like a case of false advertising.
HeffeMusic is offline
Old 08-10-2012, 07:33 AM
crazzycanuck's Avatar
John
John,
Did I miss something is the dock not being offered now?
First the DVD player now the dock?
crazzycanuck is offline
Old 08-10-2012, 08:17 AM
rwheelwright's Avatar
Quoted: 99 Post(s)
Liked: 33
I had some really bad crackling coming out of my center the other day when I was set to 2.0 and no surround processing on. Hasn't happened since but it was really weird. And it was coming from the tweeter in the center. I thought it was blown but when I switched to a CD from DVD using the same player and still 2.0 it went away. Very very strange that a speaker that shouldn't have been playing was having crackling sounds.
rwheelwright is offline
Old 08-10-2012, 08:22 AM
HeffeMusic's Avatar
Quoted: 175 Post(s)
Liked: 75
All
Firmware 50.25 has been officially released. If I downloaded 50.24 and I don't care about the zone issue do I need to update?
Old 08-10-2012, 09:35 AM
jayray's Avatar
Liked: 25
John,
Anyone interested in the dock should email Anthem. That way they'll have a sense who is interested.
John
Jayray
Read the FAQs
jayray is offline
Anthem Mrx500 , Anthem Mrx300 , Anthem Mrx700 , Receivers Amplifiers , Component Amplifiers , 3d Hdtv , Speaker Systems
