Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide - Page 406 - AVS Forum | Home Theater Discussions And Reviews
 36Likes
post #12151 of 17056 Old 09-06-2012, 12:42 PM
ninja12's Avatar
Originally Posted by vkowalski1970 View Post
Curious why set the sub to flat?
Setting the sub to Flat gives you a little more oomph with the low frequencies because ARC doesn't roll off the low frequencies when the setting is Flat. ARC passes all of the low frequencies to your sub for your sub to handle. However, you should only set your sub to Flat if your sub has built-protection, which means it will not try to play frequencies that it's not capable of playing, and your sub plays with good volume down to 20 Hz. If your sub is not capable of those two requirements, then leave it set to Auto. With Auto, ARC will determine the low end capability of your sub and roll off the low frequencies to make sure that your sub doesn't try to play them.
ninja12 is offline
post #12152 of 17056 Old 09-06-2012, 12:54 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
I may play around with this flat configuration after I've become conditioned to the new sub. Will save the "Flat" ARC calculation as a separate file in the event I need to go back. Honestly, the new sub sounds pretty awesome for both music and movies (the ones I auditioned today anyway). Thanks for the vote!!
George Fire Eagl likes this.
Esoteric K-03X. McIntosh MX121. McIntosh MC205. McIntosh C2500. Revel Studio 2 (Mains). Revel Voice 2 (Center). Focal Electra IC 1002 In-Ceiling Surrounds. Paradigm Studio Sub 15. Oppo BDP-105D. Roku XS. Roku 3. Apple TV(3). "Silenzio" EA-2 Media Server (pc-based). DirecTV. Panasonic TC-P65VT50. Samsung UN40FH6030F, URC MX-780.
My current SACD list
scirica is offline
post #12153 of 17056 Old 09-06-2012, 01:00 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Looking at the advanced targets window, I set to flat and then below there are "minimum subwoofer eq" numbers. Do I leave those at 20 or lower them in addition to the "Flat" setting?
scirica is offline
post #12154 of 17056 Old 09-06-2012, 01:15 PM
rwheelwright's Avatar
Quoted: 99 Post(s)
Liked: 33
YOu leave them. Also, when you set to flat you don't have to re-measure. You just need to recalculate and upload which is nice.
rwheelwright is offline
post #12155 of 17056 Old 09-06-2012, 01:36 PM
jayray's Avatar
Liked: 25
Leave it at flat and don't change anything else.
John
George Fire Eagl and scirica like this.
Jayray
Read the FAQs
jayray is offline
post #12156 of 17056 Old 09-06-2012, 02:30 PM
keefy6's Avatar
Liked: 30
Originally Posted by Tigger! View Post
This can work great initially... heck go one step further.. put your sub in your listening position and then with Quick Measure running, walk the mic around your room! Why trust just your ears when you have a great tool to help assist you wink.gif
Of course, once you find a good place, put the sub there and use Quick Measure back in your listening position to confirm it works as well as it looked the other way around biggrin.gif
definitely going ot try this, thanks.
keefy6 is offline
post #12157 of 17056 Old 09-06-2012, 03:34 PM
Tigger!'s Avatar
On the sub itself, crossover is maxed out/off, output level is at 50%, and phase is 0. I didn't take a screen shot of the other screen that comes up during ARC that shows the levels, etc. Is there a way to get to that by re-opening the ARC file? All I see now are the graphs. Thanks!
Wait, here are the targets if they are worth looking at.
As for the levels, you can only see those on the MRX, after ARC's settings have been uploaded. To see them, go to your Speaker Level Calibrations Setup Menu. We aim for them to be +/- 5 or so... some of OCD types aim for +/-3, though really this is not so important. I'm guessing with the Sub at 50% volume, you are probably about spot on.
As for setting your sub to "Flat"... as was mentioned above, no need to re-run ARC or save two different files. All you are really doing is re-calculating the data you collected with your last ARC run. You can re-calculate again, with your origional settings, any old time. The measured data is never changed... just the data calculated for the upload to the MRX wink.gif
Please, before you ask a question about...
General Information on the MRX Series: See the First post here.
Technical Information including using ARC: See the "FAQ" post here.
Tigger! is offline
post #12158 of 17056 Old 09-06-2012, 03:44 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Oh..THOSE numbers! Here they are:
Front Left: 0db
Center: +1db
Front Right: +2db
Surround Right: +1db
Surround Left: -1db
Movie Sub: -2db
Music Sub: -2db
scirica is offline
post #12159 of 17056 Old 09-06-2012, 04:20 PM
richmagnus's Avatar
Quoted: 221 Post(s)
Liked: 128
Originally Posted by richmagnus View Post
Hooked up an Anthem Statement A5 to my MRX 300 and damn it's good.
What exactly did you notice as the difference? Clarity?
The difference is staggering IMO. I run Monitor Audio Apex with a Studio Sub15. There is much more detail,airiness and composure. The sound is effortless and smooth at volumes I could not achieve before without it sounding too loud. Now I can crank it up but it isn't uncomfortable in any way. The MRX 300 has great amps. But this really is another league. So much headroom and particularly good with music.
Denon 7200,Lyngdorf TDAi 2170, Lyngdorf SDA 400's, MK MP300 LCR,MK S300T's, MK S150mk2 FH,S150T TM,Dual MK X10, Oppo 103,Sonos ZP90, Sony 65XD9305
richmagnus is offline
post #12160 of 17056 Old 09-06-2012, 04:48 PM
ninja12's Avatar
Front Left: 0db
Center: +1db
Front Right: +2db
Surround Left: -1db
Movie Sub: -2db
Music Sub: -2db
You are in good shape. Your graphs look good, and your speaker trim levels look good. I say you should just sit back and let your ears do some judging. Good Job!!! biggrin.gif
ninja12 is offline
post #12161 of 17056 Old 09-06-2012, 04:55 PM
jayray's Avatar
Liked: 25
Front Left: 0db
Center: +1db
Front Right: +2db
Surround Left: -1db
Movie Sub: -2db
Music Sub: -2db
These are fine, you're good to go so now go and try some good old fashion LFE:D
John
Jayray
Read the FAQs
jayray is offline
post #12162 of 17056 Old 09-06-2012, 04:56 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
John
Thanks guys! Right now it's Jeff Beck Live at Ronnie Scott's. Some LFE action later tonight when the room dims wink.gif
scirica is offline
post #12163 of 17056 Old 09-06-2012, 07:13 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Please explain this one to me...When I watch Directv and bring up the Anthem Advanced Source Setup Menu it shows "Arc Not Available". If I stay in the same menu and cycle to another source and then back to Directv, it says "On". I'm confused...just a bug? I'd like to know my Arc is on! It is not specific to the Directv input. Whatever source I am currently watching exhibits the same behavior.
scirica is offline
post #12164 of 17056 Old 09-06-2012, 08:12 PM
jayray's Avatar
Liked: 25
I thought you were going to say the menu was displayed sideways:D This is a new one. Let Anthem know.
John
Jayray
Read the FAQs
jayray is offline
post #12165 of 17056 Old 09-06-2012, 09:05 PM
Tigger!'s Avatar
John
+1
Tigger! is offline
post #12166 of 17056 Old 09-06-2012, 09:07 PM
Tigger!'s Avatar
Front Left: 0db
Center: +1db
Front Right: +2db
Surround Left: -1db
Movie Sub: -2db
Music Sub: -2db
These look great... your graphs look great... I bet it is sounding great! Sit back and enjoy!
Tigger! is offline
post #12167 of 17056 Old 09-06-2012, 09:12 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
This was a new one for me, perhaps known by others. With an Oppo BDP 93 feeding one HDMI to my MRX input 1 and another HMDI directly to my display, the MRX cannot send 3D through to the display. Really had me stumped until I unplugged the HDMI that was going directly from my Oppo to my display.
Learning more and more every day.
And yes, it's time to kick back and enjoy the new world of LFE with the Sub 15. Thanks for everyone that chimed in and complimented by graphs. Very reassuring that I spent my money wisely!
Follow up: I guess this is really just the way the Oppo operates when both HDMI outputs are active. Oppo thread was very helpful here.
scirica is offline
post #12168 of 17056 Old 09-08-2012, 01:12 PM
dacaesar's Avatar
Hi,
I just installed a new subwoofer (SVS PB13-ULTRA) after my previous old and tired Velodyne just didn't seem up to the task. I'm limited to where I can place this beast, so I hope it will suffice. Would any of the resident experts take a look-see and offer some advice or general input? Thanks so much in advance. FYI, I did calculate for the advance setting on the sub to be flat.
dacaesar is offline
post #12169 of 17056 Old 09-08-2012, 02:27 PM
ninja12's Avatar
Originally Posted by dacaesar View Post
Hi,
You need to click on Calculate to get the Calculated (Green) result. Your graphs are only showing the Measured and Target results. From looking at the Measured results for your sub, I would suggest that you check to make sure there are no filters and crossovers engaged on your sub. Your sub is dropping off majorly after 50 Hz. I know that you said that you are limited in placement; but, if you don't have any filters and/or crossover engaged, I suggest that you might try another spot for your sub. The goal is to have ARC set your sub's cutoff to 120 Hz naturally. Anyway, for now, click on Calculate to get the Calculated result and repost your charts.
ninja12 is offline
post #12170 of 17056 Old 09-08-2012, 03:33 PM
dacaesar's Avatar
Here's the calculated.
I double checked, and all filters are indeed disabled. I must admit, I'm at a bit of a loss as to where I'd put this thing that would make a difference. Presently, it's in a corner. See image below. the only option would be switch the main with the sub, placing the Focal 816 in the corner, and having the sub facing directly out in the room.
http://s19.postimage.org/836om6ixf/subwoofer.jpg
http://postimage.org/image/qir5jkx1r/
dacaesar is offline
post #12171 of 17056 Old 09-08-2012, 04:45 PM
jayray's Avatar
Liked: 25
Moving it by inches can make a difference as can pointing it in new directions. It takes time but if you get a good spot it will be worth it. My chart is at the end of the second post, first page of the thread. Look at the red measured line. That's what you're trying to get.
John
Jayray
Read the FAQs
jayray is offline
post #12172 of 17056 Old 09-08-2012, 05:23 PM
ninja12's Avatar
Overall, your charts are pretty good. Out of all of your speakers, I think you need to concentrate on your sub. I know you said that your locations are limited; but, it sounds like you can move it to another location. It might be worth moving it to try to improved the measured response from 50 Hz to 100 Hz. When it comes to the low frequencies, even inches can make a difference. BTW, what did ARC set your speaker level trims to? I normally like to see them be within +/-3 for all speakers. One thing at a time, so, I would say to concentrate on the sub if you can. If you can't move it, then it is what it is, and you will just have to live with it which is ok too.
ninja12 is offline
post #12173 of 17056 Old 09-08-2012, 05:25 PM
dacaesar's Avatar
John
Thanks John! I'll try with what limited options there are. If moving doesn't get desired results, the SVS PB13-ULTRA has the ability to boost certain frequencies (e.g. 50, 65 etc.) by 3db. Would that be another option to go as well before measuring? If not, I would have more options for placement with a sub with a smaller footprint. This one's 27" length is very limiting within the confines of the space.
dacaesar is offline
post #12174 of 17056 Old 09-08-2012, 05:45 PM
jayray's Avatar
Liked: 25
Smaller sub but better placement could be another option. Not sure about boosting freq., getting there by placement is the best way.
John
Jayray
Read the FAQs
jayray is offline
post #12175 of 17056 Old 09-09-2012, 07:55 AM
dacaesar's Avatar
John
First I want to say thanks to both John and Ninja12 for your help. Here's my latest results after running quick measure for the most innocuous placement changes I could muster under the circumstances and changing the placement accordingly. It's actually better for the room, 'cause the sub can now double as a "coffee table" next to the couch.
The subwoofer seemed to improve to my untrained eye. When I compare this chart to John's example of a good one, while this does have a dip at 50 as before, the starting point at 20 is at a higher db level. That being said, ARC did not change the target to 120 as would be optimal, and I'm not sure what to do about that.
Thanks again!
Dave
dacaesar is offline
post #12176 of 17056 Old 09-09-2012, 09:33 AM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Thanks again!
Dave
Dave: your sub position has paid off. That is a graph you should be proud of!
scirica is offline
post #12177 of 17056 Old 09-09-2012, 03:00 PM
thenewguy11's Avatar
Has anyone had an issue controlling the MRX 500 with a Crestron Adagio through the RS232 port? The MRX will not turn on probably 90% of the time now through my TP. Additionally, when the MRX wont't respond to the Crestron, it doesn't respond to the remote directly or using the front of the receiver either. I have to unplug it and plug it back in to turn it on. I'm on my second MRX after returning the first one for the same issue and have the same problem cropping up again. Any advice?
thenewguy11 is offline
post #12178 of 17056 Old 09-09-2012, 03:51 PM
ninja12's Avatar
Thanks again!
Dave
This position is better than your last position. You have reduced the null; but, your sub is still dropping off about 10db after 50 Hz. If this is your only other position, then I would say leave it in the new position.
ninja12 is offline
post #12179 of 17056 Old 09-09-2012, 04:34 PM
dacaesar's Avatar
Thanks! I have one more possible place, but it will be a project for another day checking it out. That said, what would be the determining factor for ARC to eventually change the target response from the 80 it presently is to the "optimal" 120?
dacaesar is offline
post #12180 of 17056 Old 09-09-2012, 04:44 PM
ninja12's Avatar
"PLACEMENT!!!"
ninja12 is offline
Anthem Mrx500 , Anthem Mrx300 , Anthem Mrx700 , Receivers Amplifiers , Component Amplifiers , 3d Hdtv , Speaker Systems
