Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide - Page 418 - AVS Forum | Home Theater Discussions And Reviews
 36Likes
post #12511 of 17058 Old 10-07-2012, 01:05 PM
paradigmfan's Avatar
Originally Posted by NeogeoG View Post
Originally Posted by paradigmfan View Post
Are you using any sort of surge device? If not try using a surge protector/ power conditioner should help also...
Sent from my HTC One X using Tapatalk 2
Thanks for the help and advice, but I dont know anything about surge protector/ power conditioner, could you put me a link to what I should have installed so I can show it to the people that did the electric intallation in my house?.
Greetings.
Panamax.com should have something you could use. It provides surge protection and linear filtration from old electric work that may in fact cause interference with video/audio.....including noise from units and speakers....best buy carries alot of the Panamax units. I use the M5100PM.
paradigmfan is offline
post #12512 of 17058 Old 10-08-2012, 02:03 PM
richmagnus's Avatar
Quoted: 221 Post(s)
Liked: 128
I read somewhere that -10db is reference on the MRX's.
Denon 7200,Lyngdorf TDAi 2170, Lyngdorf SDA 400's, MK MP300 LCR,MK S300T's, MK S150mk2 FH,S150T TM,Dual MK X10, Oppo 103,Sonos ZP90, Sony 65XD9305
richmagnus is offline
post #12513 of 17058 Old 10-08-2012, 02:16 PM
NeogeoG's Avatar
Quoted: 29 Post(s)
Thanks for the help, will have it in mind for when I have my Anthem back, although I dont think we have this brand in Spain.
NeogeoG is offline
post #12514 of 17058 Old 10-08-2012, 02:21 PM
NeogeoG's Avatar
Quoted: 29 Post(s)
For me its just a guess, but after having the Onkyo 809 that is suposed to get referecen volume at 0, I think you are wright and probably reference volume in the Anthem is around -10db, but in normal house rooms its nearly imposible to listen at such high volumes.
NeogeoG is offline
post #12515 of 17058 Old 10-09-2012, 07:07 AM
You should have some sort of surge/filer device in Spain. Contact Panamax and look into it. They make the best out there...along with Furman Brand.
post #12516 of 17058 Old 10-09-2012, 08:25 AM
bolsen187's Avatar
Anthem had me do a factory reset to unlock my internet radio. What have I lost? All I get is multi channel sound no more stereo. All my speaker distances are gone. Do I need to do a complete reinstall? Do I need to do ARC from scratch or is it still in the receiver? I did a search but all I found was how to do it. I need guidance on how to get back everything I lost. More questions to follow depending on the answers to this battery.
bolsen187 is offline
post #12517 of 17058 Old 10-09-2012, 09:13 AM
RaggedEdge's Avatar
If you did ARC yourself before, you should have saved the file. Just load the ARC file you saved, hit calculate and then upload it to the MRX. This will give you back your ARC settings. You will have to manually enter your speaker distances again.
Alex
RaggedEdge is offline
post #12518 of 17058 Old 10-09-2012, 09:59 AM
bolsen187's Avatar
From your response I assume I lost arc so I am getting the old pc out. Can you weigh in on any of the other question? Thanks
post #12519 of 17058 Old 10-09-2012, 11:21 AM
blb1215's Avatar
I think this depends on how you have the Dolby Volume Cinema Reference mode set. When set to "on" then reference level or -0- on volumn control is 85db or -10db reference. If set to off then -0- should be 75db.
barry
blb1215 is online now
post #12520 of 17058 Old 10-09-2012, 11:53 AM
NeogeoG's Avatar
Quoted: 29 Post(s)
Thanks, ¿What do you think about these filters that I can find here?:
http://www.studio-22.com/_filtros-de-red.htm
NeogeoG is offline
post #12521 of 17058 Old 10-09-2012, 12:05 PM
bolsen187's Avatar
I am going to attempt to reload my arc tonight but I am way behind in updates. Should I upload my arc from 2 years ago with the old mm and main section software or should I update one or both before I reload arc?
post #12522 of 17058 Old 10-09-2012, 12:13 PM
Something like the Isol-8 and up
on that page and has enough power inputs for what you need should be fine. And if there's no difference in sound return it. Should help though. If the electric in the house is old, it could interfere with audio and video quality....hope it helps.
post #12523 of 17058 Old 10-09-2012, 12:14 PM
Update it to the newest firmware which I believe is 50.25
post #12524 of 17058 Old 10-09-2012, 12:14 PM
Also do the update before you run ARC.
post #12525 of 17058 Old 10-09-2012, 12:33 PM
NeogeoG's Avatar
Quoted: 29 Post(s)
Thanks, I will first try with my electrician to se if he can fix the problem, if not I will try the Isol-8.
Greetings.
NeogeoG is offline
post #12526 of 17058 Old 10-09-2012, 12:46 PM
Tigger!'s Avatar
I've seen a few answers to peices of your questions... but it is to much work to try and find/quote them all... so this may be slightly repetative but hopefully fills in some gaps.
If you performed a factory "Reset":
1) The factory reset should not have removed any firmware updates you applied. So, assuming you were on the latest, you are all set with the firmware... otherwise...
a) If you have a MRX 500/700, Check the MM firmware and update if it is not version 1.10 (this has not changed in a long time so likely it is all set)
b) Check the main firmware and update if it is not version 50.25
2) You will need to set up each source again. Including any settings you may have made in the Advanced Source Stup.
3) Re-Enter your distances
4) Re-Upload ARC
a) If you saved your old ARC file, you can simply re-upload it.
b) Otherwise re-run ARC and upload (make sure you save the results this time wink.gif )
NOTE: With very few exceptions, even if your ARC software is older, it will be the same, but you can upgrade to the latest version of ARC (v3.0.2) if you like before you re-run ARC. To upgrade, download the new version from Anthems website and then install it over the old version. No need to uninstall the old version. If you are installing on a new computer, make sure you install the old version first, from your origionally supplied CD, so that the microphone calibration file is coppied over. Then upgrade wink.gif
Hope this answers everything in your post above?
Please, before you ask a question about...
General Information on the MRX Series: See the First post here.
Technical Information including using ARC: See the "FAQ" post here.
Tigger! is offline
post #12527 of 17058 Old 10-09-2012, 01:15 PM
bolsen187's Avatar
I've got my old arc. I need to update both firmwares . I've already got my distances reloaded. I assume I do these things in the sequence in your post and that the arc is the last thing to do? My old PC with the serial port will not connect to the net. The mm update I can do from another pc. Can I down load the main firmware on the new pc , move it to a disc and then to the old pc or does the mrx have to talk over the internet to do the download? When I down load old arc file to the mrx do I need to have the setup menu set for "load user settings" or something else?
post #12528 of 17058 Old 10-09-2012, 01:31 PM
Tigger!'s Avatar
It would be recommended to probably do them in the order I listed (though there are several combinations that would work).
The MM firmware is loaded via USB, so it can easily be done from any computer.
The Main firmware does not need to talk to the internet, so you download it on wone computer and then copy it via disk/network/usb over to the old PC you are using to run ARC. The main firmware is updated using the same serial connection you use when you run ARC. There is no need to put the MRX in any special modes, just simply turn it on and you should be all set. You will probably want to confirm the MRX is set to the faster serial speed otherwise the firmware updates will take a really long time. (they are not the fastest things in the world even with the higher speed serial setting).
Tigger! is offline
post #12529 of 17058 Old 10-09-2012, 01:55 PM
KarVi's Avatar
Last week I finally got myself an Anthem MRX 300.
This was after much listening and thinking about my needs, and I ended up with the MRX, simply because it sounded best to me, and was less bloated with useless features, a thing I really apreciate. Also like the menus better. And then off course because theres ARC.
Definately a major step up from my previous Denon AVR-2808.
It works as a processor, as I have separate power amplifiers for my 5 channels.
My speakers are Dali Mentor 6 for the fronts (fantastic sounding speakers), Dali Concept Center, and Dali SR-5 surrounds. Center and surrounds are lower class than the fronts but still very fine sounding.
Tomorrow I am going to pick up my new sub (BK XXLS400 FF), and when that is proberly setup, I will post some graphs.
I have one question allready though.
A very seldom time I get a short burst of white noise from my left front speaker, for about a second. The music is still playing, the white noise is underneath it. It happens in both stereo and surround modes. I have noticed it about 5 times now, and only happens once per powerup, as far as I have heard.
I did not have this problem with any of the demo units I have had loaned (MRX500 and MRX300).
It is not a big problem, but curios anyway. Is this a bug in the 50.25 firmware? Has anybody else had the same "problem"?
In any other way, the Receiver has been perfect. I'm very very satisfied with its sound. Fantastic amount of detail, bass is plentifull yet still tight and fast.
Its an eyeopening experience hearing what ARC does to tighten up the sound, especially since my listening room is very far from perfect.
KarVi is offline
post #12530 of 17058 Old 10-09-2012, 02:45 PM
Tigger!'s Avatar
That does not sound normal at all. Since you just got it... I would see if your dealer will just trade it for you. Otherwise I would call Anthem.
I would also, just to help make sure it is not something in your environment... Disconnect everthing except your player and perhaps TV. See if it continues. Also try running an extension cord to another outlet on a another circuit and see if that resolves the issues. If you are using a line filter on your power, try removing it.
Particularly discounnet any cable/satalite boxes that are connected to the MRX. Let us know how you get on!
Tigger! is offline
post #12531 of 17058 Old 10-10-2012, 06:54 PM
nytefog's Avatar
Just recently my right channel on my MRX700 started to hum, hiss and click. It would start the noise, then stop, then return, and this would repeat. The audio coming out of the speaker was perfectly fine. I tried unplugging all sources from the reciever. I then tried switching another speaker to that channel and the same problem recoccured. I am assuming their is a internal issue with the unit. It has not had any problem in the 2 years that i have had it and i have done the firmware updates. Has anyone else had a similar issue??
nytefog is offline
post #12532 of 17058 Old 10-11-2012, 11:54 AM
cfineman's Avatar
Quoted: 35 Post(s)
I believe this has already been asked and answered but since it's critical to my AVR decision process I wanted to be sure.
All of my music is in FLAC. Currently I pipe it all through a SqueezeBox using it's audio outputs. In the new setup I'm thinking of running all music through an HTPC. I was considering getting some sort of DAC (perhaps VLink or Xonar) and pushing it through the MRX.
From what I've read, it seems I would not be able to shunt this over to Zone 2. Is that correct?
If, on the other hand, I used the DAC inside the SB and continued to use the analog output I would be able to shunt it over to Zone 2?
In that case, would I be able to have the kids listening to a movie inside (zone 1) and the "grown ups" (using the term loosely) listening to music outside (zone 2)?
cfineman is offline
post #12533 of 17058 Old 10-11-2012, 12:00 PM
saeyedoc's Avatar
Quoted: 82 Post(s)
Liked: 69
If you run analog from the DAC to the MRX, it will work on zone 2. The issue is with zone 1, it will force another analog to digital conversion and then back to analog again, there's no analog pass through as far as I know with zone 1.
saeyedoc is offline
post #12534 of 17058 Old 10-11-2012, 12:19 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Correct. Anything that is directed to Zone 2 must be sourced as analog. I have HDMI and Analog audio outputs set up for my Oppo, Directv, Roku, and Appletv for this very reason.
Esoteric K-03X. McIntosh MX121. McIntosh MC205. McIntosh C2500. Revel Studio 2 (Mains). Revel Voice 2 (Center). Focal Electra IC 1002 In-Ceiling Surrounds. Paradigm Studio Sub 15. Oppo BDP-105D. Roku XS. Roku 3. Apple TV(3). "Silenzio" EA-2 Media Server (pc-based). DirecTV. Panasonic TC-P65VT50. Samsung UN40FH6030F, URC MX-780.
My current SACD list
scirica is offline
post #12535 of 17058 Old 10-11-2012, 01:17 PM
cfineman's Avatar
Quoted: 35 Post(s)
Wow what a PITA... I wanted to get a modern AVR to reduce complexity! So how well does this work when I'm running zone1 & zone2 at the same time from the same source? I guess any delays are negligible. Since I plan to run a power amp for my front two, the only thing the MRX really has going for it is the ARC. I'm starting to wonder if the MRX is the right fit for me.
cfineman is offline
post #12536 of 17058 Old 10-11-2012, 02:06 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
My zone 2 is the patio out back, so it is usually on music while TV or Movies are on in the living room, hence I don't notice delays. I'm running a Proceed Amp5 for the living room 5.1 channels and using the MRX amplification for zone 2. Works great!
scirica is offline
post #12537 of 17058 Old 10-11-2012, 02:38 PM
saeyedoc's Avatar
Quoted: 82 Post(s)
Liked: 69
I ended up running the digital out from the SB Touch to the MRX for my main system, and use the analog outputs into a small zone amp controlled by a volume control on the wall for the outdoor speakers. This setup was just easier than running more wires to the MRX due to my specific setup and is easier to control for my wife and kids.
saeyedoc is offline
post #12538 of 17058 Old 10-13-2012, 08:13 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
So, after having my system calibrated by Jeff Meier this morning, I come to find out that while the Anthem does a great job with audio, the video processing leaves a lot to be desired. I don't have the technical details, but regarding contrast and low-level black information it really performed poorly. Decided to go with the "through" mode to calibrate my Samsung UN60D7050 and all the detail came back. Very happy with the work done by Jeff. He is truly a master at his craft and just a great guy to work with. I will post the calibration graphs soon.
scirica is offline
post #12539 of 17058 Old 10-14-2012, 06:50 AM
AV_mike's Avatar
Quoted: 91 Post(s)
Liked: 86
Can you get Jeff to provide any detailed information with regards to the effect that the MRX had on the video going through it?
I believe the MRX clips Blacker Than Black (BTB, level 16 & below) and Whiter Than White (WTW, level 235 & above) no matter what settings you use - but it would be good to have it confirmed/denied by an expert.
I have been using Through for my Blu-Ray, but Auto for my broadcast sources - as the scaler in the MRX does a better job than the other devices - and broadcast stuff just isn't that good anyway (not here in the UK eek.gif )
Regards, Mike.
AV_mike is offline
post #12540 of 17058 Old 10-14-2012, 08:30 AM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Regards, Mike.
I believe you are describing what Jeff explained to me. Clipping at the ends of the spectrum for sure. I'll see if he can email me a description of his observations. Blacker than black is where it was really poor.
I'm using through for all sources at this point. For Directv, I'm only outputting 1080i, 720p, and 1080p. I may play with using auto for Directv. I agree that broadcast is a step below here as well, although not bad.
scirica is offline
Anthem Mrx500 , Anthem Mrx300 , Anthem Mrx700 , Receivers Amplifiers , Component Amplifiers , 3d Hdtv , Speaker Systems
