Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide - Page 421 - AVS Forum | Home Theater Discussions And Reviews
 36Likes
Old 10-21-2012, 10:29 AM
TVMAN1991's Avatar
Quoted: 54 Post(s)
Liked: 54
Anthem guys,
I have separates. I just bought the 300 for ARC. How much better is it than audyssey and mcacc? I've heard different things. Also, any tips for the first time setup?
TVMAN1991 is offline
Old 10-21-2012, 11:17 AM
diablo676's Avatar
A lot of people who have ARC say it is the best, but then maybe people with XT32 might disagree. All I know is that it is pretty damned good.
Just try out setting it up for a start - preferably using the manual option. It will give you a clue as to what is going on, than maybe post some graphs on here. smile.gif
diablo676 is offline
Old 10-21-2012, 12:00 PM
Tigger!'s Avatar
Originally Posted by TVMAN1991 View Post
Anthem guys,
There are a million answers to the question of how much better is it... Your posting in an Anthem thread, so I think you know what answer you can expect to that question here.
As for getting started. Read through the posts in the FAQ post at the start of the thread. (post #2). In particular read the Quick Start Guide post.
Please, before you ask a question about...
General Information on the MRX Series: See the First post here.
Technical Information including using ARC: See the "FAQ" post here.
Tigger! is offline
Old 10-21-2012, 01:02 PM
NeogeoG's Avatar
Quoted: 29 Post(s)
Originally Posted by Tigger! View Post
These look great!
There is a bit of a dip in the sub, that I think is still confusing ARC a bit. <<Advice not intended for any other users!!!>> NeogeoG, you are one of the very rare cases where I might recommended trying to force 120 for your sub. In your targets window, set the sub cut off to 120hz. Then recalculate and post your results for us to take a look at. If they look good... upload and give them a try.
AGAIN, this advice is for a very specific case. In general you should not attempt to force a higher cutoff on the sub. This suggestion is only for NeogeoG to try in this very specific case.
Thanks Tigger for the help, but I have a question, ¿when do I have to set the 120hz, before doing the arc measurements or after? also ¿what would I gain in sound quality for my sub if I change it to 120hz and works ok?.
Greetings.
NeogeoG is offline
Old 10-21-2012, 01:13 PM
NeogeoG's Avatar
Quoted: 29 Post(s)
Anthem guys,
Ive had two receivers with Audyssey XT and ARC is a lot better, the sound of ARC is totally natural, Audyssey XT on the other hand really changes the sound and for music is really not the best option, also with the Anthem you get a high quality mic and a nice tripod, and beeng able to see what ARC does on your PC is huge improvement so you can make changes and correct what is not working, with other receivers you are totally blind, also ARC equalizes the subwoofer way better than than Audyssey XT.
Cant compere it to XT32, Ypao, mcacc etc..., but I still see some clear advantages in ARC that ive mentioned above.
Greetings.
NeogeoG is offline
Old 10-21-2012, 02:21 PM
Shrike645's Avatar
Quoted: 46 Post(s)
Liked: 40
Greetings.
Just open the last measurement you did, open the targets window, change the sub to 120, recalculate and upload.
Shrike645 is online now
Old 10-21-2012, 07:40 PM
jayray's Avatar
Liked: 25
One thing I can say about ARC vs other room correction systems is that in this forum, most people have tried other schemes and their comparisons are based on their experiences as opposed to people who haven't but still criticize ARC. I've done a comparison in a friends HT and yes, ARC sounded better than Audyssey, for both movies and music. MRX 500 vs Denon 4310
John
Jayray
Read the FAQs
jayray is offline
Old 10-21-2012, 07:54 PM
tubeheadEL34's Avatar
Since the last firmware update, I seem to have lost the onscreen display for volume adjustment. Confirmed that "Status Message" under Display/timeouts is still turned to on. Anyone experience this?
tubeheadEL34 is offline
Old 10-21-2012, 08:34 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
I know this is stating the obvious, but you didn't change the video output to "Through" did you?
Esoteric K-03X. McIntosh MX121. McIntosh MC205. McIntosh C2500. Revel Studio 2 (Mains). Revel Voice 2 (Center). Focal Electra IC 1002 In-Ceiling Surrounds. Paradigm Studio Sub 15. Oppo BDP-105D. Roku XS. Roku 3. Apple TV(3). "Silenzio" EA-2 Media Server (pc-based). DirecTV. Panasonic TC-P65VT50. Samsung UN40FH6030F, URC MX-780.
My current SACD list
scirica is offline
Old 10-21-2012, 10:09 PM
MitchPope's Avatar
Quoted: 26 Post(s)
Liked: 25
Anthem guys,
I am doing the same, I still have my AS-EQ1, should I leave it connected to my sub, or unhook it and let ARC do everything?
MitchPope is offline
Old 10-21-2012, 11:24 PM
That did it sir. I setup a new projector recently and changed the settings. Well done and thanks.
Old 10-21-2012, 11:33 PM
NeogeoG's Avatar
Quoted: 29 Post(s)
Thanks Shrike645, I guess that if I dont like the change I can just go back set it to 80hz without having to do the speacker trims and recalculate/upload.
But I dont know what changes I should expect from changing 80hz to 120hz, if I dont know what can change I might not even notice any diference, and mind as well stay with 80hz.
Greetings.
Ps. ¿How can I change the HDMI setting to Through just to try it, I currently have it set to 1080p, and it doest give me the option to change, I only got the option when the source was something like 480p.
NeogeoG is offline
Old 10-22-2012, 01:12 AM
bryan338's Avatar
Quoted: 23 Post(s)
Greetings.
Just press the resolution button on the remote then press up or down arrow
bryan338 is offline
Old 10-22-2012, 05:26 AM
Shrike645's Avatar
Quoted: 46 Post(s)
Liked: 40
Greetings.
Yes you can easily go back. You could save a copy of the file and save yourself changing the settings and recalculating. If we told you what to expect the power of suggestion might make it so. The bottom end sound from your sub will expand to fill the room with earth shaking frequencies and extension that will pale in comparison to it's it's previous sound. smile.gif
Seriously though it is all in what you hear. If you don't hear a difference then it doesn't matter if you leave it where it is or return it to the prior setting.
Old 10-22-2012, 06:57 PM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
Anthem guys,
Having used all 3, I have no hesitation in easily declaring ARC the winner. I had considering writing up a lengthy comparison of them all, but its all so subjective that I felt like it would just end up with pointless bickering.
In a nutshell though, MCACC is like trying to swat a fly with a sledgehammer. It's too crude of a tool to solve most problems, although to its credit, you can peel away enough layers that you can get some benefit from some aspects of it. Audyssey is like a neurosurgeon who only knows how to do radical brain surgery, even if all you need is some tylenol for a headache. Typically ends up overcorrecting, and ultimately doing more harm than good. ARC is definitely the most complex and involved to run, and the results more subtle - but it's 100% improvement, and you can set sane limits so it doesn't overcorrect.
Steam/PSN/Xbox Live: Darius510
bd2003 is offline
Old 10-23-2012, 02:02 PM
SKiTLz's Avatar
Quoted: 22 Post(s)
Is anyone else disappointed in the lack of advancement/progress in Anthem firmware updates?
Things like more OSD information, additional RS232 commands... The dock... Where the heck is it? Still not out?
I guess I expected more post support for this line. Haven't really seen anything other than some bug fixes.
It takes a big man to cry, but it takes a bigger man to laugh at that man
SKiTLz is offline
Old 10-23-2012, 04:05 PM
nr1416's Avatar
Sorry if this question has been asked before, I did a search in this thread and couldn't find an answer. When I go to turn on my MRX300 it doesn't, the only way to turn it on is be unplugging the unit from the wall. It is happening more frequently lately. Is there a fix to this problem? I just downloaded the new firmware, I was running the 50.23.
nr1416 is offline
Old 10-23-2012, 04:44 PM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
I don't think the dock will see the light of day. Personally, I don't really care since connecting my iPod to the MRX's usb port using the iPod cable allows me to browse the playlist, songs, etc. using the OSD.
As for more information on the OSD, what sort of information did you want to see? I rarely use the OSD myself.
For firmware advancements/progress, the firmware seems fairly complete and mature to me. Are you experiencing a particular problem that needs to be addressed? As with my computers, I update the firmware when I have an issue. If it's stable, I leave it alone.
audit13 is offline
Old 10-24-2012, 06:50 AM
Nick @ Anthem's Avatar
Quoted: 299 Post(s)
Liked: 216
This can happen when line voltage reaches a certain point. We have a mod that allows the standby circuit to accept slightly higher voltage - please contact tech support if the problem is frequent enough to require action. This seems to be a more of a problem in 240V countries where line voltage sometimes reaches 265-270V, though it also appears in 120V countries depending on region.
The most important noise floor is in your head. Always remember to protect your hearing.
Nick @ Anthem is offline
Old 10-24-2012, 06:53 AM
Quoted: 299 Post(s)
Liked: 216
Sorry, some months ago we announced the dock's cancellation due to its demand having dwindled. In general, smart phones have become a remote control for servers/streamers as opposed to being the server itself (earphones and portable speakers aside) which has made docking them less desirable.
Old 10-24-2012, 06:55 AM
Quoted: 299 Post(s)
Liked: 216
True, but be aware that clicking Auto Detect enters the original values - no need to manually re-enter them.
Old 10-24-2012, 07:38 AM
bd2003's Avatar
Quoted: 915 Post(s)
Liked: 1703
If we're talking about firmware advancements, I'd really like to see a way to quickly modify dolby volume leveling. You can turn DV on or off easily, and I leave it on all the time for the frequency response adjustment. But I have to dig through tons of menus to get to the leveler setting. Meanwhile, the standard DRC control can swap between night modes super easy - the same should be extended to DV.
bd2003 is offline
Old 10-24-2012, 07:55 AM
yanknuck's Avatar
Quoted: 36 Post(s)
Liked: 45
I would sure love to see FLAC ability in the multimedia section.
However, a real question I have is: Is ARC going to be functional with the new Windows 8 around the corner? From what I have read about 8 is, it is quite different. I think I keep my XP tower just in case...cool.gif
Religion, race, color, creed...whatever.
yanknuck is offline
Old 10-24-2012, 08:57 AM
SKiTLz's Avatar
Quoted: 22 Post(s)
I'm pretty sure it came out of Anthems own mouth, but when I first got my MRX i was disappointed in the lack of OSD information compared to other units 1/3 of the price and was told more information would be coming. For instance my second room cheapo Onkyo displays all of your DSP/Sound mode settings on screen as an overlay for you to change on the fly.
This is perfect for hiding your receiver out of site yet still changing a DSP mode on the fly without pulling up the shall I say "slow" setup menu. All we get right now for OSD is volume, which is pretty lacking in my opinion. I'm also put off by the Dock strategy. It was littered all over my MRX literature that it would be available. Despite whatever Anthem thinks of the market now and the way users are interacting with their equipment, they should have gone through with their marketing. Maybe take a lesson from this and don't print something all over your advertising if you have no intention of seeing it through.
SKiTLz is offline
Old 10-24-2012, 09:11 AM
SKiTLz's Avatar
Quoted: 22 Post(s)
On a lighter note.
Any opinions on how the MRX-500 will drive a set of Aperion 5T's?
Frequency Response (+/- 3dB) 55-20,000 Hz -- (+/- 6dB) 45-22,000 Hz
Impedance 6 Ohms
Sensitivity 89 dB
Recommended Power 50-200 Watts
SKiTLz is offline
Old 10-24-2012, 09:24 AM
dean-l's Avatar
The "Status Message" OSD is a copy of the Receiver front display.
You can change it if you come out of the setup menu and IMMEDIATELY press the "audio" button to quickly change the front display. So when the receiver grabs the front display info after leaving the set up menu it will not be the usual info.
This means IMO that Anthem could pretty easily add front display info grabs at other times too. Some good examples of it's use would be...
Using the "audio" "channels" and "Dolby Volume" settings.
"Info" button info,etc.
Truth is....you could add an option in setup menu for the Front Panel Display to flash up to the Status Message OSD anytime the front display changes info. A perfect run of it would be using the "Front Panel Wake up" setting. Anytime my receiver is in "Up 1" mode on my front display would be a PERFECT time to put it up on the Status Message OSD. It would NOT be terribly complicated. Plus the addition to the FW is a VERY low risk change.
Currently, the Status Message info is pretty useless. You DO have to think a more elaborate version had to be planned originally. I find it hard to believe this nearly useless feature was the END plan.
Edit :spelling
Moderator harassment is wrong and immoral.
dean-l is offline
Old 10-24-2012, 04:46 PM
ScofieldKid's Avatar
Hmmm. Will probably put my MRX 500 up on EBAY.
I could do an elaborate review, but in short I'm finding the match of the "warm" sound with my relatively "bright" speakers (paradigm ref studio 100) to be just a bit out of my preference. Smart move might be to toss the large Paradigms, since I have found them difficult to match with other rooms / other components. My setup is fine for Jazz and Piano, but it's not as enjoyable for the fusion and rock.
Biggest pluses on the MRX 500 I think are 1) the COAX digital seems to be fairly good 2) the bass linearity is very good and 3) the noise floor is extremely low.
Biggest minuses 1) some of the interface is clunky and 2) no pure audio path passthru if you have external DACs and so on.
ScofieldKid is offline
Old 10-24-2012, 04:55 PM
dacaesar's Avatar
What do you mean by " no pure audio path passthru if you have external DACs and so on"?
dacaesar is offline
Old 10-24-2012, 05:21 PM
Uh, I believe all inputs travel through the internal DAC of the Arcam. Correct me if I'm wrong.
Old 10-24-2012, 06:30 PM
Brian-HD's Avatar
Quoted: 44 Post(s)
Liked: 41
Zone 2
Brian-HD is offline
Anthem Mrx500 , Anthem Mrx300 , Anthem Mrx700 , Receivers Amplifiers , Component Amplifiers , 3d Hdtv , Speaker Systems
