Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide - Page 555 - AVS Forum
post #16621 of 16641 Old 10-12-2014, 07:21 AM
Liked: 0
Originally Posted by grasshoppers View Post
According to your graphs you are already getting
Solid output at 20hz. You have your EQ set to flat too.
Ok, thanks again
macario12 is offline
post #16622 of 16641 Old 10-12-2014, 07:35 AM
audit13's Avatar
Liked: 24
Originally Posted by chilliking View Post
I just bought a 2nd hand MRX500. I wish to use it in my PC music set up as follows:
monitor -> PC -> soundcard -> avr -> speakers
Unfortunately, I've run into a problem already. My monitor does not have and HDMI port (my graphics card does but I guess that it HDMI out not in?).
I won't be running HDMI all the time. I simply intend to use SPDIF to make the connection from soundcard to avr. But, to get the settings correct and to do ARC I need to be able to see the GUI in my monitor.
One option I thought of would be to buy a HDMI to DVI connector. Would this work or would I run into problems?
Or are there any better options? Would plugging the AVR HDMI out to my graphics card HDMI port work?
By the way - I tried to e-mail Anthem via their webform but I get an error every time I try to submit it - does anyone know their e-mail address?
If you are using a Win7 machine, the best way to set things up would be to connect like this:
PC --hdmi-->MRX--HDMI/DVI adapter-->Monitor and run through the set up routine.
Once it has been set up, do this:
connect video card to the monitor via dvi. Set the monitor as your main monitor in
connect video card to mrx via hdmi. Extend the desktop to the mrx in Win7. Set audio output device as mrx.
This is what I did with my htpc and my mrx500. I use it to playback music and movies.
audit13 is offline
post #16623 of 16641 Old 10-15-2014, 04:13 AM
spirosgon's Avatar
Liked: 0
Good Morning from Greece,
Tonight the mrx 500 is going to be permantly installed in my rack ...I' ve spent several hours, these last days, trying to read this thread, but I do have much distance to go up to page 555 ...
I have a simple question : Initially, if you had only a 5.1 speaker system, you couldn't use the 6th and 7th channel to bi-power your front speakers (something my current Pioneer vsx 921 does) ... Do you happen to know if this fact changed and can be done via a firmware update ?
Thanks for the attention !
Spiros
spirosgon is offline
post #16624 of 16641 Old 10-15-2014, 08:13 PM
grasshoppers's Avatar
Quoted: 151 Post(s)
Liked: 157
Spiros
The MRX 500 can not bi- power or bi amp.
Sorry!
The new 510 can.
grasshoppers is online now
post #16625 of 16641 Old 10-15-2014, 09:37 PM
spirosgon's Avatar
Liked: 0
Thank you for the answer ... I was just hoping that this issue could be fixed with a firmware update, since they handled it with the 510 ...
post #16626 of 16641 Old 10-18-2014, 03:26 AM
Liked: 0
OK - here's my first shot at ARC with my new MRX 500. I am running PC (optical out) --> MRX500 --> speakers (2.1). Fronts are B&W 602s3 and Sub is SVS SB2000.
How does this look?
For some reason the crossover seems to have been set at 60Hz small. I think it should have been set to 80Hz?? Certainly, the SVS Merlin tool recommends a x-over at 80Hz.
I read somewhere about setting the sub to flat but can't remember what all that is about and how I try it?
Name:	2014-10-18 11_21_03-Anthem Room Correction - Anthem Room Correction.jpg
chilliking is offline
post #16627 of 16641 Old 10-18-2014, 08:04 AM
Quoted: 151 Post(s)
Liked: 157
How does this look?
Please post up your targets screen and speaker levels.
Your subwoofer graph looks very good and the sub appears
To be in a "good spot". You could set the sub response to
"Flat" if you want to,but it already looks pretty flat down low.
I am concerned about your speaker graphs, in particular the
Left speaker. The response from 50hz to 100 hz has a huge
Dip in it and a very large unnatural peak at a 120hz
You may need to move the speaker around to get it to
Even out a bit. Make sure the speakers have room behind
Them and are away from side wall.
Post a pic if you want.
post #16628 of 16641 Old 10-18-2014, 08:53 AM
Liked: 0
Hi grasshoppers - you mean these screens?
Name:	2014-10-18 16_48_19-Target Customization.jpg
ID:	318082   Click image for larger version
Name:	2014-10-18 16_48_42-Advanced Target Customization.jpg
post #16629 of 16641 Old 10-18-2014, 09:28 AM
Quoted: 151 Post(s)
Liked: 157
Correct..if you want to set your subwoofer to
Flat do that on the drop down menu on the smaller
Screen shot where it says "subwoofer high pass
Order". Change from auto to flat.
You need to try and correct your speaker graphs
If you can. If you are not able to move them around
I would raise the crossover on the speakers from 60hz
Up to 80 hz.
post #16630 of 16641 Old 10-18-2014, 10:40 AM
Liked: 0
Up to 80 hz.
Noted, thanks mate. I'm kinda stuck with the speakers where they are (you're correct in that they are close to a wall) due to limited space in an odd shaped room.
Do I change the x-over in the MRX menu rather than ARC? Does ARC not override it if I do that?
post #16631 of 16641 Old 10-18-2014, 11:53 AM
Legairre's Avatar
Quoted: 14 Post(s)
Liked: 61
Unfortunately since the new x10 models came out they have stopped releasing updates for out x00 series, so we won't be seeing any new firmware updates.
spirosgon likes this.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is online now
post #16632 of 16641 Old 10-18-2014, 12:01 PM
Quoted: 151 Post(s)
Liked: 157
Change the speaker crossover in ARC,re-calculate and upload
Back into the MRX.
post #16633 of 16641 Old 10-18-2014, 07:49 PM
JustABrah's Avatar
Quoted: 64 Post(s)
Liked: 66
For the phase control that's just the distance for the sub right?
JustABrah is offline
post #16634 of 16641 Old 10-19-2014, 04:22 AM
Liked: 0
What is the guidance on setting the response cutoffs? These seem to be different to x-over settings but I can't quite grasp what I should be setting the response cutoffs to.
post #16635 of 16641 Old 10-19-2014, 12:52 PM
Liked: 0
On another note, I have my PC hooked up to my MRX500. I am using SPDIF (toslink). 48000 Hh files play but 44100 Hz do not? Surely the MRX supports 44100 Hz, so I'm a bit stumped?
post #16636 of 16641 Old 10-19-2014, 05:29 PM
Liked: 0
Thanks for all the information....
andy28_sd is offline
post #16637 of 16641 Old 10-22-2014, 09:38 AM
spirosgon's Avatar
Liked: 0
Hi guys,
I bought my mrx 500 as second hand.
Before I run the arc for my set up, do I need to -somehow- erase the arc parameters of the previous owner ?
thanx for the attention !
post #16638 of 16641 Old 10-22-2014, 10:03 AM
mhuk's Avatar
No, they get replaced when you upload your ARC settings.
mhuk is offline
post #16639 of 16641 Old 10-29-2014, 09:02 AM
Liked: 0
Hello. I have a MRX300 that works with Triangle speakers Espirit Titus, subwoofer Velodyne CHT 10R. Rate my graphics.
Name:	график anthem 1.png
ID:	338770   Click image for larger version
ID:	338778   Click image for larger version
Name:	график anthem.png
Alexey Shahparonov is offline
post #16640 of 16641 Old 10-29-2014, 09:34 AM
Quoted: 151 Post(s)
Liked: 157
Your left/right front speakers have a dip in
Freq response at 150hz but ARC has mostly
Corrected it.
Your subwoofer has some problems. I'm seeing
A 15db drop from 50hz to 100hz. Make sure
The freq response dial on the back of the sub
Is turned to its highest value or bypassed.
You should be seeing a straight line response from
The sub from 30hz to 100hz. Small peaks and dips are
OK. This is not true in your case.
You may need to experiment with different placements
Options to get a better graph. The 'quick measure' function
Can help.
Alexey Shahparonov likes this.
post #16641 of 16641 Old 10-29-2014, 09:39 AM
Liked: 0
Thank you
Anthem Mrx500 , Anthem Mrx300 , Anthem Mrx700 , Receivers Amplifiers , Component Amplifiers , 3d Hdtv , Speaker Systems
Gear in this thread - Mrx500 by PriceGrabber.com
