Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide - Page 556 - AVS Forum
post #16651 of 16672 Old 11-03-2014, 10:50 AM
grasshoppers's Avatar
Quoted: 204 Post(s)
Liked: 166
Originally Posted by edgnoj View Post
You mean the level calibration in the speaker configuration menu?
The levels there are:
Front left +1
Center 0
Front right +1
Surround right 0
Surround left
Movie subwoofer +6
Music subwoofer +6
The subwoofer can't be much increased in the MRX and in the setup of the subwoofer the volumelevel is 90%
Thank you, your sub should be capable of putting
Out a lot more volume than it is now.
Couple of things..
1) is your listening area very large???
Large areas can be hard for a single sub to
Energize. Report back on size off room. Don't
Forget the ceiling height.
2) how far away is the subwoofer from your listening
Position? (Same place as ARC microphone)
Did you remember to enter the speaker&sub distance
Into the MRX?
Finally I see that the sub has a very extensive DSP
Menu which allows A LOT of control over the sub's
Outputs, frequencies, boosts and cut offs.
Much more than I am used to dealing with!
I suggest that you disable all of these settings.
Perhaps a reset to factory defaults?
We want to start over with the sub just in the factory
Default mode. No processing or adjusting of the signals.
If we can't get the output levels up higher then there
MAY be a possibility that the sub is defective.
grasshoppers is online now
post #16652 of 16672 Old 11-03-2014, 12:38 PM
edgnoj's Avatar
Thanks for your help, much appreciated.
My room is fairly small. The listening area is about 12x12 feet with one open corner. Total room is 25 x 15 feet. Hight is about 8 feet.
Distance subwoofer to LP is 10 feet. Front speakers and centre also at 10 feet and the surround at 3 feet.
Distances in MXR are ok
When using LFE, most of the filtering will be bypassed.
All other dsp shut off
Sub back to factory default (2x)
Nightmode not working.
One extra note: using the internal amp testtones after using ARC all speakers are around 72dB. Subwoofer level then is about 80dB. So using the intrrnal testtone the sub is much louder?
I hope you will understand what I am trying to say here. My english is not very well I am affraid.
edgnoj is offline
post #16653 of 16672 Old 11-03-2014, 02:14 PM
Quoted: 204 Post(s)
Liked: 166
I understand you just fine! I'm a bit confused what to do
Next. I see 2 options.
1) if possible take sub to dealer to be tested on another
AVR. Or if you can test a new subwoofer of the same
Make and model to test on the MRX.
2) see if you can bring home a different sub to test.
Or borrow a sub from a friend to test in your system.
If a different sub does the same thing it maybe the MRX.
If a different sub plays louder volume then your Monitor
Sub may be defective.
I think you have a good quality sub with the Monitor. It should
Be performing MUCH better than it is. Your room is not too
Big and you are not that far away either.
Something is not right. Not sure what else to try...
Maybe a factory reset of the MRX is needed??
edgnoj likes this.
post #16654 of 16672 Old 11-03-2014, 03:40 PM
edgnoj's Avatar
You have some great ideas sir, thanks you very much.
Tomorrow I will try another receiver. My neighbour has a Denon 4311 so I will ask him to help me testing the sub.
A factory reset of the MRX is the second thing I will try
Last thing is get another subwoofer to see if my sub has a problem.
What would be a normal level for this subwoofer? About 75dB after ARC?
I come back when I have all the answers.
Thanks again
What if I just raise the volume of the sub from 90 to 100%? The sub has a digital amp. Would that be a problem?
Another possibility is raising the LFE level in the MRX from +6 to +10 or 12
Just some thoughts
edgnoj is offline
post #16655 of 16672 Old 11-03-2014, 04:01 PM
Quoted: 204 Post(s)
Liked: 166
Thanks again
75db is a good starting point. Your sub should be able
To hit well above 95 db easily. Especially with the level
On the sub itself turned up so high(you said 90%?)
I have a very similar sealed 12inch sub with a 300 watt
Amp and had to turn in Down to 35% because the level
Was too high for ARC! My room is a bit larger than yours too.
It would be a good idea to take your sub over to your
Neighbors and hook it up to his Denon. Shouldn't
Take very long to test it out!
I look forward to hearing back from you on your problem,
Like I said that is a pretty good sub you have,it should
Be performing much better!
post #16656 of 16672 Old 11-03-2014, 04:07 PM
Quoted: 204 Post(s)
Liked: 166
Regarding your additional paragraph..
You should not have to turn the gain
On the sub up too 100% AND increase
The LFE level in the MRX to max to get
Good results with that sub.
My sub gain is at 35% and ARC set the LFE
To negative 6!
If you want to try it though go ahead, but
I think something is wrong.
post #16657 of 16672 Old 11-04-2014, 11:15 AM
edgnoj's Avatar
Some good news, the subwoofer is working just fine. Tried it on the Denon by my neighbours and the volume output is ok. So the sub is not broken.
The factory reset of the MRX didn't work
At last I tried ARC again, but the results are about the same.
So I still have the same low volume output from the MRX500 to the subwoofer.
Can't try another subwoofer in the next weeks, so I don't know what to do now. It seems there is something wrong with the Anthem.
Extra problem is that the Anthem is out of warranty
edgnoj is offline
post #16658 of 16672 Old 11-04-2014, 12:19 PM
unavol's Avatar
Liked: 26
Where is the sub placed in the room? Have you tried moving the sub to a different place in the room? Could it be that the sub is sitting in a null where the bass frequencies are cancelling each other out?
I'm no Anthem expert. I just picked up a 300 myself. I haven't even run ARC yet. I'm sure I'll have some questions in the near future though.
UNAVol
There's nothing to see here.
unavol is online now
post #16659 of 16672 Old 11-04-2014, 03:06 PM
edgnoj's Avatar
The sub has always be standing there, on the left of the right front speaker, and has never given problems there. So no, I haven't moved the sub.
edgnoj is offline
post #16660 of 16672 Old 11-04-2014, 03:28 PM
Quoted: 204 Post(s)
Liked: 166
Hello, I'm a bit baffled by your issues. When you tested your sub
At your neighbors house did you have turn the gain/volume
Up to get good volume?? Just curious how far up you turned
The volume.
I can't really think of any other possible solution.
post #16661 of 16672 Old 11-04-2014, 03:41 PM
edgnoj's Avatar
The volume.
My previous AVR had Audyssey XT32. Before measuring I used a SPL meter to set the subwoofer at a level op 75dB. After that I did a 8 point measurement and everything was fine.
Volume in the settings of the sub was then -25 on a scale of -80 - 0dB (electronic soundlevel system)
The same this afternoon with my neigbour. Sub on -25 and it sounds great.
When I use this setting using ARC measuring stops with an error because the sublevel is too low.
After raising the volume on the sub to -10dB I get the results of the posted scale, with a peak of 70dB.
So it looks like the sub-out is not "hot" enough.
edgnoj is offline
post #16662 of 16672 Old 11-04-2014, 03:50 PM
Quoted: 204 Post(s)
Liked: 166
Could very well be...try bumping the sub trim level
Higher in the MRX.
If you used -25 on your your sub setting then
To me that is turning it up pretty high.
I have another idea...if you have a "Y" rca cable could
Try to hook it up to the left/right inputs of the sub.
The single end would of course go into the MRX.
This kind of cable
http://www.amazon.com/Mediabridge-UL...5141447&sr=1-1
I've heard you can get more output doing this.
You need to change the input on your sub though
post #16663 of 16672 Old 11-04-2014, 04:14 PM
edgnoj's Avatar
Quick question before I have to go to bed (It's midnight here in the Netherlands)
Such a "Y Cable" has to be put in the L-R connectors. Those are analog connectors and not LFE right?
Does these connectors work with digital audio including LFE?
Thanks again, you are extremely helpful.
edgnoj is offline
post #16664 of 16672 Old 11-04-2014, 04:32 PM
Quoted: 204 Post(s)
Liked: 166
Yes it will work just fine, remember you will
Be using the LFE out put on the MRX.
Also need to tell your sub that you are not using
LFE input rather left/right input. (From your owners manual)
post #16665 of 16672 Old 11-09-2014, 02:14 AM
edgnoj's Avatar
Hi, sorry about the delay, but I had to wait till the spliting cable had arrived.
Well it didn't help. Output with this cable was around 35dB, so hardly audible.
I also tried different 8 places in my room, that helped a bit.
This is the best I can do. Subwoofer output still at 90% at LFE position:
Added the first measurement of the subwoofer
ID:	356817   Click image for larger version
ID:	356841   Click image for larger version
edgnoj is offline
post #16666 of 16672 Old 11-09-2014, 07:37 AM
Quoted: 204 Post(s)
Liked: 166
Sorry it didn't work out. I'm fresh out of ideas.
Your sub graph on post #16645 is a better looking graph.
But, on this new graph you picked up about 5db's of
Output. I prefer the older graph. It doesn't have the
Peaks and valleys that ARC had trouble correcting.
At this point the only thing you can do is raise the
Sub trim levels in the speaker level menu. It can go
As high as +12...
I still wonder how a different sub would do? But,
Based on on your current sub being tested at your
Neighbors place, I am not sure if it would make a
Difference.
post #16667 of 16672 Old 11-09-2014, 02:54 PM
larod241's Avatar
Liked: 0
Hi,
HDMI PassTrough of the MRX500 is compatible with 4k@30 ?
Regards.
larod241 is offline
post #16668 of 16672 Old 11-12-2014, 08:51 AM
smile's Avatar
Quoted: 27 Post(s)
Can the MRX 310 ARC competently manage sub woofer calibration/location?
smile is online now
post #16669 of 16672 Old 11-12-2014, 03:41 PM
JustABrah's Avatar
Quoted: 71 Post(s)
Liked: 66
Originally Posted by larod241 View Post
Hi,
Regards.
No 4K on the MRX 00, the newer ones will pass it. How are you running 4k? There's nothing out there for it outside of streaming?
Sierra-2 LCR
HTM-200 rears
Rythmik E15HP
Anthem MRX-300
Samsung 8550 UHD
-$8500ish : (
JustABrah is online now
post #16670 of 16672 Old 11-15-2014, 10:28 PM
viper008's Avatar
3D pass through
Hi All,
I have a GT640 GPU in a HTPC running JRiver -> HDMI to MRX 500 -> 3D capable projector
Is this possible?
Roh
EDIT just found out JRiver doesn't support 3D
viper008 is offline
post #16671 of 16672 Old Yesterday, 08:38 AM
TJG55's Avatar
Absolutely! Run QM first to establish best sub location (fewest large dips, ignore peaks). Experiment a lot until you are sure. Then run ARC, it will be superb. For even better, find Dmsoke's (sp.) method of correctly setting phase (likely in D/AVM section). If the sub is even competent it will be a true revelation. Especially listen with well recorded music.
TJG
TJG55 is offline
post #16672 of 16672 Old Yesterday, 10:49 AM
Canary_Jules's Avatar
Hi guys. Quick question. I recently ran Arc again after installing new speakers. Last night I was looking through my settings and I found that while Treble etc were at zero the Bass was on +4. I can't remember manually changing this but I possibly did so some time back and forgot the adjustment. My question is whether ARC adjusts this setting and if not whether having Bass set at +4 will have affected the ARC results? I've reset Bass to 0 but should I run ARC again?
Canary_Jules is offline
Anthem Mrx500 , Anthem Mrx300 , Anthem Mrx700 , Receivers Amplifiers , Component Amplifiers , 3d Hdtv , Speaker Systems
Gear in this thread - Mrx500 by PriceGrabber.com
