Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide - Page 557 - AVS Forum
post #16681 of 16714 Old 12-01-2014, 11:36 AM
Kensmith48's Avatar
Quoted: 14 Post(s)
I haven't ran arc yet because I can't get the sub to work. I checked the settings and all the speakers are set to small, 80hz, and I went back to bitstream. All of the speakers work, except for the sub. The sub is a SVS SB13-Plus with a STA-1000D amp. I checked the manual and there's nothing about a fuse. Anyone have any ideas to make the sub work? I have it set to auto on and the level input is set to normal.
Ken
Kensmith48 is offline
post #16682 of 16714 Old 12-01-2014, 03:26 PM
grasshoppers's Avatar
Quoted: 257 Post(s)
Liked: 182
Ken
Couple of things...
1) turn the sub from auto to ''ON"
2) check the sub trim in the MRX menu,make
Sure it is not turned down. Example.....-12...
Perhaps bump it to 0 or even +5.
3) I recently received a bad sub from SVS. As a final
Check they had me plug my iPod (with mini jack to rca)
Into the sub, turn the volume up on the sub and the
Device and check the sub for output.
Alternatively you could hook the sub jack into the MRX
Pre out for say the left speaker and test. Don't forget to
Turn the sub xover on the back to its highest value!
If you can't get any output from either of the above
Scenarios your sub could be bad. Let me know plz.
grasshoppers is online now
post #16683 of 16714 Old 12-03-2014, 08:11 AM
Kensmith48's Avatar
Quoted: 14 Post(s)
It looks like it might be something wrong with the MRX500. In the Anthem menu it says the sub is on (highlighted) but the word subwoofer isn't. Seems like the sub channel is bad. I think I'll contact Anthem Tech support and see what they say.
post #16684 of 16714 Old 12-04-2014, 03:25 PM
teevman's Avatar
Hey all.
I'm looking at some Paradigm Monitor 11 or possibly the Monitor 9's along with a Center 3 (which comes free). I also have my eye on an Anthem MRX-500. Does ARC work well with a 3.0 system or is it mainly intended for 5.1 or higher systems. Thanks.
teevman is offline
post #16685 of 16714 Old 12-04-2014, 04:51 PM
Quoted: 257 Post(s)
Liked: 182
Originally Posted by teevman View Post
Hey all.
It will work just fine with a 3.0 system. If you are
Going to do movies you should seriously think
About adding a quality powered subwoofer into
The mix...the sub will make your movies much
More 'fun'! (Works well with music too)
Nice Speakers!
(Former Paradigm Monitor 11 owner)
teevman likes this.
post #16686 of 16714 Old 12-04-2014, 06:22 PM
hasdfes's Avatar
I'm in Ontario too.. looking for a job at Christushealth.. I've wondered what Texas is like.. .
I've also intercepted the sub in transit to do some local testing..
hasdfes is offline
post #16687 of 16714 Old 12-04-2014, 06:41 PM
Quoted: 257 Post(s)
Liked: 182
Huh??
post #16688 of 16714 Old 12-05-2014, 04:39 AM
Canary_Jules's Avatar
Originally Posted by Legairre View Post
ARC doesn't adjust the Bass control and it won't mess with your ARC setup.
Thanks for confirming this.
Canary_Jules is offline
post #16689 of 16714 Old 12-05-2014, 09:17 AM
bryan338's Avatar
teevman,
i have the monitor 7s7 and center3 with mrx300. i love the sound. Love the ARC. Go get the monitor 11.
Hey all.
teevman likes this.
bryan338 is offline
post #16690 of 16714 Old 12-05-2014, 01:21 PM
Kensmith48's Avatar
Quoted: 14 Post(s)
It took some time and testing but I finally got the sub and speakers to work. I e-mailed Anthem & SVS subs and between the 2 of them I got everything working. Thanks for the suggestions on AVS also.
Ken
post #16691 of 16714 Old 12-05-2014, 01:37 PM
teevman's Avatar
Originally Posted by bryan338 View Post
teevman,
So how did you find Arc, was it difficult to run/setup, does the serial to usb convertor cause any problems? I would be using a laptop with windows 7.
Have another question about ARC. When you run the program (from what I have read) it shows the results of the sounds it emits on a graph. Then it sets the speaker levels etc to where they should be but after this is done does the program actually re-run the program with test sounds to verify the new settings actually work or is it just up to your ears to hear the difference. I'm kind of confused on this.
teevman is offline
post #16692 of 16714 Old 12-05-2014, 02:48 PM
bryan338's Avatar
I was using a denon 1910 (audyssey only) then upgraded to mrx300. I really like what arc did to my speakers, the sound is much more alive. Im using a really old macbook(2006 lol) with windows xp. I did not encounter any problems running arc. I bought this one http://www.tripplite.com/high-speed-...yspan~USA19HS/
teevman likes this.
bryan338 is offline
post #16693 of 16714 Old 12-05-2014, 02:58 PM
Quoted: 257 Post(s)
Liked: 182
Ken
If you don't mind...what was the issue(s)?
Just curious.
post #16694 of 16714 Old 12-06-2014, 08:24 AM
Kensmith48's Avatar
Quoted: 14 Post(s)
Since I rearranged the room I needed to use a different sub cable. I have a plastic tub full of cables. Turned out the one I picked was bad. I used an ohm meter to figure it out.
post #16695 of 16714 Old 12-06-2014, 09:11 AM
Quoted: 257 Post(s)
Liked: 182
Thanks for the reply. Glad it was something
Simple. Hope you enjoy your MRX.
post #16696 of 16714 Old 12-13-2014, 08:53 PM
Hostility's Avatar
Wondering if anyone could help me. I just added an amp and centre channel to my home theatre and need to re run arc. I own a mac, so i have to borrow a windows laptop. Im using a keyspan adapter and i installed everything onto this borrowed laptop, and doesn't matter what i try it keeps saying Cant find processor. So for some reason I'm having problems with the key span. any suggestions?
Hostility is offline
post #16697 of 16714 Old 12-13-2014, 09:25 PM
Quoted: 257 Post(s)
Liked: 182
Just guessing...did you download the drivers
For the Keyspan onto the borrowed laptop?
Try different USB ports too. There is more info
In this thread...buried somewhere. Try a search??
post #16698 of 16714 Old 12-13-2014, 09:41 PM
Hostility's Avatar
I downloaded the drivers off the cd, and off the website. I tried all 3 USB ports and still same results. I tried google search into this thread but didn't come up with much. And this thread is so big for page by page lol.
post #16699 of 16714 Old 12-13-2014, 10:50 PM
Quoted: 257 Post(s)
Liked: 182
Which version of Windows...just curious.
I used windows XP (company computer)
And it worked great. Had to turn in the computer.
Luckily, I haven't had to run ARC in a couple
Of years and frankly I'm scared to try.
Buried in this thread are some USB port settings
(Baud rate) that can be adjusted?
Are you using the orignal CD software the came
With the MRX?
post #16700 of 16714 Old 12-13-2014, 11:01 PM
Quoted: 257 Post(s)
Liked: 182
When I ran ARC on the XP laptop I actually
Used a "Dynex" USB to serial cable.
(Very cheap brand found at Best Buy for $9)
I didn't buy the Keyspan until after I turned in
The XP. Never used it though.
Sorry to get off track.
post #16701 of 16714 Old 12-14-2014, 06:47 AM
jproy13's Avatar
Liked: 25
I don't remember all the specific steps on top of my head, but after you plug in the keyspan, you need to either find where it installed and finish the installation process, or update the driver it's plugged in. I remember having the same issue when I re installed everything on my htpc.
I know it's not much of an explanation but it's where I would start.
cheers
jproy13 is online now
post #16702 of 16714 Old 12-14-2014, 07:14 AM
Hostility's Avatar
cheers
what do you mean finish the installation process? And the computer is a HP with windows 7. Maybe its not compatible with windows 7?
post #16703 of 16714 Old 12-14-2014, 08:31 AM
Quoted: 257 Post(s)
Liked: 182
Found this on the internet:
Pioneer & Historical Society, Ken Carter, who had some fun with the ARC system. Here’s his running commentary:
“I used a desktop computer running Windows 7 that has serial ports, but I thought I would try using the USB adapter as a test.
Tripp-Lite Keyspan USA-19HS USB Serial Adapter: -Ensure that you install the hardware driver using the provided CD (or a new downloaded version) before connecting the adapter to the computer.
-after installation of the driver and connection to the computer, check the COM port settings for conflicts
-click on the START button (bottom left corner); -click on CONTROL PANEL; -click on the SYSTEM icon; -click on DEVICE MANAGER
-looking at the list, click on PORTS (COM& LPT); -my Keyspan USB adapter came up as COM3 and I already had a COM3 (you can only have 1 of each device (only 1 COM1, only 1 COM2, etc.), so I disabled all the other COM ports except for the Keyspan adapter by right-clicking on each device on the list and selecting disable.
-this resolved the communication error I was receiving try to locate the Anthem processor.
-if you double click on the Keyspan device and then the Port Settings tab, you can change the “Bits per Second” to match the Anthem settings under Setup (I went with the fastest setting, 115,200)
-under the Advanced button, you can also change the COM# if necessary. The ARC software ran well and uploaded to the receiver fine and was very easy to use. I used a 25′ 9 pin “straight thru” serial cable with a BD9 female connector at one end and a DB9 male connector at the other end to reach my desktop computer. I did not use any other USB cable to extend the Keystone adapter as USB has issues with long cables.
If still having communication issues, one could try disconnecting all other USB devices except for keyboard, mouse and the Anthem microphone.”
I also have a PDF file if you run into trouble with the Mic.
4AlexF likes this.
post #16704 of 16714 Old 12-14-2014, 12:43 PM
hydrotex's Avatar
The connections to the keyspan and mic are all very loose. please check that all connections are snug. very easily dislodged.
hydrotex is online now
post #16705 of 16714 Old 12-14-2014, 01:29 PM
Hostility's Avatar
I tried to look to switch coms or bit rate but it won't let me on windows 7. I realized i had the wrong driver installed for it but even with the windows 7 driver it still doesn't work.
post #16706 of 16714 Old 12-17-2014, 05:04 PM
jproy13's Avatar
Liked: 25
Yes it works with Windows 7
post #16707 of 16714 Old 12-21-2014, 02:55 AM
pdg540's Avatar
MRX-300 - Was able to figure out that on-screen volume level will only display if "Auto" video is selected rather than "pass through" in the menus.....
I have a mits hc6000 projector that has an auto-zoom for my 2.35:1 screen. When zoomed to 2.35, I can just see the word "Volume" on my screen but not the numerical level below it. Does anyone know whether there is any way to display the volume level on a zoomed 2.35 setup?
unavol likes this.
pdg540 is online now
post #16708 of 16714 Old Yesterday, 07:34 AM
dacaesar's Avatar
Unhappy It's Christmas and my MRX 700 died
Hi,
My MRx 700 will not stay on. It immediately goes into power protection mode and shuts off. I disconnected all speakers, and it still happens. I opened a contact with Anthem, but I'm sure with the holiday, it will take a bit before they get back to me. Any suggestions would be appreciated!
dacaesar is offline
post #16709 of 16714 Old Yesterday, 08:04 AM
Quoted: 257 Post(s)
Liked: 182
Originally Posted by dacaesar View Post
Hi,
Slim chance, but, when you disconnected the speakers
Make sure there wasn't a "straggler" strand of wire left
Over causing a short??
Also maybe unplug your input device wiring from MRX too.
Basically you will have nothing connected.
Unplug MRX from power for 10 minutes.
Then try to plug it in and power it on with nothing
At all connected to it.
Good Luck!
post #16710 of 16714 Old Yesterday, 08:40 AM
dacaesar's Avatar
Thanks grasshoppers, I've tried it all to no avail.
I have absolutely nothing connected, and it was not plugged in for a long time before I tried again and still same result. I hope this isn't a complete fail!
dacaesar is offline
Anthem Mrx500 , Anthem Mrx300 , Anthem Mrx700 , Receivers Amplifiers , Component Amplifiers , 3d Hdtv , Speaker Systems
Gear in this thread - Mrx500 by PriceGrabber.com
