Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide - Page 562 - AVS | Home Theater Discussions And Reviews
post #16831 of 16838 Old 04-03-2015, 01:45 PM
04rex's Avatar
Quoted: 64 Post(s)
Hey guys, if you are running a 7.1 setup, what do you have your settings at to make the rears work even if it is only a 5.1 signal? essentially i want all 4 rears working even if it is only a 5.1 signal.
What do i leave, what do i change etc.
04rex is offline
post #16832 of 16838 Old 04-04-2015, 08:29 PM
Bachelor's Avatar
Quoted: 14 Post(s)
Push the audio button twice and scroll to pliix movie. You can also go through the menu and change default to pliix movie for 5.1 sources.
Bachelor is online now
post #16833 of 16838 Old Yesterday, 03:40 AM
Liked: 0
Hi
I've set up an MRX 300 for the first time and wondering whether anyone has any advice on settings, speaker placement etc. In particular I note that the fronts appear to have a large spike below around 100Hz. I was also surprised that the MRX has classified my fronts as small.
Iā€™m using the MRX 300 as a pre-amp to an Arcam A18 driving a pair of Spendor BC1 floorstanders. Centre speaker (Spendor C3) and surrounds (Monitor Audio Radius 45) are driven by the MRX 300. Sub is a BK XLS200 MK1.
Level calibration as follows:
Dolby volume off
DVCO 0
Front left +3dB
Center +1dB
Front right +1dB
Surround right -1dB
Surround left -2dB
Movie sub -2dB
Music sub -2dB
Movie/Music config:
Front small 100Hz
Center small 60Hz
Surround Small 120Hz
Aux None
Sub On
Thanks in advance for any help!
Name:	front speakers v2.PNG
ID:	669385   Click image for larger version
ID:	669393   Click image for larger version
Name:	center & sub v2.PNG
ID:	669401   Click image for larger version
abr1 is online now
post #16834 of 16838 Old Yesterday, 03:44 AM
fatbottom's Avatar
Quoted: 867 Post(s)
Liked: 321
Those Spendors have FR of around 55hz, so yes small is correct. I wouldn't set them any lower than 60hz.
The center wouldn't set lower than 70hz.
Pivetta Opera
Bose Jewel speakers.
fatbottom is online now
post #16835 of 16838 Unread Today, 08:33 AM
Liked: 0
Thanks. If I change the crossover do I need to run ARC again? I presume not.
Any other feedback or suggestions?
abr1 is online now
post #16836 of 16838 Unread Today, 08:58 AM
grasshoppers's Avatar
Quoted: 333 Post(s)
Liked: 202
The reason ARC set your main xover to 100hz
Is that you have a lot of boundary gain/reinforcement.
I would NOT lower the xover.
You need to work on the placement of your L/R speakers.
Try to pull them out from the walls and/or get them
Away from corners. Then redo the ARC program.
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is online now
post #16837 of 16838 Unread Today, 09:19 AM
Legairre's Avatar
Quoted: 114 Post(s)
Liked: 105
If you set yours up as follows in the Listening Mode Presets menu you'll use all four surrounds (except DD-EX and DTS-ES will use 3 or 4 surrounds depending on the mix).
It's very important that you set 5.1 DTS to Last Used and DTS-ES to None. If you have 5.1 DTS set as Last Used and DTS:ES set to Same as DTS 5.1 , your DTS-MSTR 7.1 movies will default to 5.1 and and you'll have to use the audio button to set them to 7.1 for every movie and turning off the receiver will reset to 5.1 for DTS-MSTR 7.1.
2.0 Dolby Digital Surround - PLIIx Movie
Muilti Channel PCM - PLIIx Movie
5.1 Dolby Digital - PLIIx Movie
Dolby Digital Surround EX - None
5.1 DTS - Last Used
DTS-ES- None
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is online now
post #16838 of 16838 Unread Today, 10:31 AM
Liked: 0
Thanks grasshoppers. I will have a play with the L/R placement and remeasure.
abr1 is online now
Anthem Mrx500 , Anthem Mrx300 , Anthem Mrx700 , Receivers Amplifiers , Component Amplifiers , 3d Hdtv , Speaker Systems
Gear in this thread - Mrx500 by PriceGrabber.com
