Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide - Page 563 - AVS | Home Theater Discussions And Reviews
post #16861 of 16874 Old 05-05-2015, 07:08 PM
sharp10's Avatar
Apilon, I would try moving your sub around a bit. Run quick measure and try to get rid of that huge peak before it falls off. Try to get your cut off to 120 after running arc.
sharp10 is offline
post #16862 of 16874 Old 05-06-2015, 07:21 AM
vinodk's Avatar
Quoted: 32 Post(s)
Liked: 25
I am in the process of connecting 2 vintage Vandersteen 2W subs in the system which connect to the front speaker amp through parallel connection using inline high pass filters. In that case before running ARC do I configure front speakers as "full range" & sub to "no"?
Vinod
vinodk is offline
post #16863 of 16874 Old 05-06-2015, 01:37 PM
apilon's Avatar
Quoted: 17 Post(s)
Originally Posted by audit13 View Post
@apilon, set your sub to flat under the advanced settings, recalculate, and see if you get a better sub surve. Your sub looks like it will do fine at the lowest frequencies.
Here i changed the settings to flat and also since my sub design call for a HPF at 23hz i also tried that settings
i also change the cutoff to 100 hz and it seem to be better
what do you think
ID:	703242   Click image for larger version
ID:	703250   Click image for larger version
ID:	703258   Click image for larger version
ID:	703266   Click image for larger version
Alain Pilon
Montreal, Quebec
apilon is offline
post #16864 of 16874 Old 05-06-2015, 02:29 PM
audit13's Avatar
Quoted: 12 Post(s)
Liked: 30
The third and fourth subwoofer graph looks flatter as it approaches 20 hz.
What are the different settings? Did you manually set the cutoff to 100 hz or did ARC make it 100 hz?
audit13 is offline
post #16865 of 16874 Old 05-06-2015, 03:18 PM
grasshoppers's Avatar
Quoted: 357 Post(s)
Liked: 218
I'm wondering if the crossover adjustment on
The back of the sub is turned to its highest
Value. At 60hz the response falls off a cliff.
If it is at its highest value then apilon needs to
Work on different sub placements.
Simply changing the xover to 100hz is not doing
Much good in my opinion.
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is online now
post #16866 of 16874 Old 05-06-2015, 04:10 PM
sharp10's Avatar
I agree With grasshoppers. You should try to obtain 120hz naturally. Sometimes moving the sub even a little bit will help. Using quick measure to eliminate that hump at 60hz should do the trick. Once you find the better spot, rerun ARC and you are golden.
sharp10 is offline
post #16867 of 16874 Old 05-06-2015, 05:04 PM
apilon's Avatar
Quoted: 17 Post(s)
Arc set the cutoff for the sub at 80 hz as you can see in my first post, all other cutoff were set by arc as well
then i set the sub cutoff to 120 and 100 as you can see in my second set of message
The first image is the sub at 120hz with auto , second image is sub at 120hz flat , thirds is sub flat at 100 hz 4th is sub flat with 80hz and last is sub flat with hpf 23hz
sub is powered by behringer ep4000 with minidsp set with hpf at 23hz
i will try to move the sub a bit and see if i get better result
Alain Pilon
Montreal, Quebec
apilon is offline
post #16868 of 16874 Old 05-13-2015, 09:05 AM
dexth77's Avatar
Arc-2
Quick question, does ARC-2 support MRX 300/500/700? From what i read, ARC-2 is superior and easier to setup.
dexth77 is offline
post #16869 of 16874 Old 05-13-2015, 10:49 AM
Legairre's Avatar
Quoted: 142 Post(s)
Liked: 114
ARC2 was designed for the x10 gen MRX receivers. Not sure if you tried to load it on an x00 MRX if it would fail to load or brick your receiver. My guess is that Anthem has it coded to check for the receiver version and fail to load.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is online now
post #16870 of 16874 Old 05-14-2015, 01:23 PM
dexth77's Avatar
Originally Posted by legairre View Post
arc2 was designed for the x10 gen mrx receivers. Not sure if you tried to load it on an x00 mrx if it would fail to load or brick your receiver. My guess is that anthem has it coded to check for the receiver version and fail to load.
thx!
dexth77 is offline
post #16871 of 16874 Old Yesterday, 10:31 PM
viper008's Avatar
Has anyone placed the mic 1m infront of their main speaker and taken a measurement?
I did and was expecting a slightly flatter response curve?
I guess because in quick measure there is no smoothing the graph is going to look more jagged.
Has anyone else done measurements like this?
Name:	Front Right 1m.JPG
viper008 is online now
post #16872 of 16874 Old Yesterday, 11:26 PM
viper008's Avatar
I guess ARC can only improve things a certain amount.
Is there anything I can do to improve the curve beforehand and re-run ARC?
I've attached my initial 5 measurements
post #16873 of 16874 Old Today, 04:12 AM
Quoted: 151 Post(s)
Liked: 62
What model speakers are you using? Measuring 1m in front of the speakers might not be beneficial depending on the speaker. When measuring larger speakers the mic needs to be further away for near field measurements. Specs are often given at 1m but in reality many measurements are done further away and the data extrapolated for 1m.
For your room try moving your speakers (or seating) and see if you can get a better starting point before applying ARC. Look for measurements without any big dips, peaks are easier to fix.
Ellebob is online now
post #16874 of 16874 Unread Today, 06:04 PM
viper008's Avatar
Thanks for the feedback. That's a good point about measuring 1m away. I'm using floorstanders that are around 1.1m tall. I was just doing it out of interest.
I'll focus on speaker position as my seating position is fixed. However, I don't have much wiggle room for the speakers either. I'll try toeing them in slightly and see what affect that has.
Anthem Mrx500 , Anthem Mrx300 , Anthem Mrx700 , Receivers Amplifiers , Component Amplifiers , 3d Hdtv , Speaker Systems
Gear in this thread - Mrx500 by PriceGrabber.com
