Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide - Page 567 - AVS Forum | Home Theater Discussions And Reviews
 34Likes
post #16981 of 17007 Old 06-24-2016, 11:31 PM
subbass's Avatar
Quoted: 66 Post(s)
Liked: 29
Why does it show the respond to 20khz ? The AVM60 (ARC) only shows the response up to 10khz.
subbass is offline
post #16982 of 17007 Old 06-25-2016, 04:49 AM
sukumar's Avatar
Quoted: 12 Post(s)
Originally Posted by Apgood View Post
I have an ARC microphone that has a serial number that starts with 2 and I'm able to use it on windows 10, but only if I use a USB2.0 port. It does not detect properly on a USB3 port.
The usb2.0 hub I tried didn't work either but that might just have been because a very cheap one off of ebay.
Sent from my LG-D802T using Tapatalk
Thanks for sharing. My latop top has all usb 3 ports. I will find usb 2 hub and try and also will try with older laptop.
sukumar is offline
post #16983 of 17007 Old 06-25-2016, 05:36 AM
Apgood's Avatar
Quoted: 63 Post(s)
Liked: 27
I suspect the mic won't work via a usb2 hub if connected the hub is connected to a usb3 port, but who knows you might get lucky.£
Edit: Actually you might have better luck with a port replicator/docking station because the one for my surface pro 3 seems to work (i.e. if mic is connected to the usb2 ports on docking station then mic is detected a ARC microphone).
Apgood is online now
post #16984 of 17007 Old 06-25-2016, 11:57 AM
sukumar's Avatar
Quoted: 12 Post(s)
Thanks for sharing. It is working with windows 10 on laptop that has usb 2 port. I am able to run ARC successfully. It saves me to not to buy one more MIC. Appreciate for all the updates. It is good to know that some docking can be used.
I will post my results for any feedback on another post.
sukumar is offline
post #16985 of 17007 Old 07-11-2016, 05:30 AM
Bob_Collins's Avatar
Quoted: 16 Post(s)
Liked: 30
Originally Posted by Legairre View Post
Thanks DS-21. I was aware of the Dynamic EQ like part of Dolby volume, but I wasn't aware that it was implemented in the MRX receivers so I didn't mention it in my post.
Not sure it is there, based on the above statement taken from the posts you referred to (actually a couple of posts down, first on the next page).
Bob_Collins is offline
post #16986 of 17007 Old 07-11-2016, 09:21 AM
BigCoolJesus's Avatar
Quoted: 562 Post(s)
Liked: 262
Wrong thread lol
BigCoolJesus is online now
post #16987 of 17007 Old 07-12-2016, 11:57 AM
tsubasa83's Avatar
Hi everybody.
I may ask a stupid question, but one of the next days I'm having a look at an Anthem MRX 500 which is on sale for 650 Euro. (or maybe it's the MRX 700, the website is confusing, I need to see in person)
It would be my first receiver as I'm setting up a 5.0 (to be 5.1) home theater setup - main use - with some random music listening as well. I don't think that I will go 4k in the near future (4-5 years, mainly because I don't have streaming services nor intend to buy UHD).
Do you think it is a valid choice even if I understand it's about 5 years old?
What do you make of the price? (I haven't seen it yet, so I guess it's been used as demo)
Originally I had in mind to buy a Marantz SR-5009, which seems to me to be a good mid-range. How does it stand compared to it?
Thanks for your help
________________________________
Audio: JBL Studio 2 (230 L/R and 235 C), Technics SB-CH404 (Rears), Denon AVR-X1200W
Video: LG PA70G
tsubasa83 is offline
post #16988 of 17007 Old 07-16-2016, 12:00 PM
Jare's Avatar
Quoted: 30 Post(s)
HI, One question for all of you.
Is there any logic in adding DAC in the system, since Anthem digitizes everything anyway, in order for ARC to work?
Jare is offline
post #16989 of 17007 Old 07-16-2016, 12:02 PM
Jare's Avatar
Quoted: 30 Post(s)
Originally Posted by tsubasa83 View Post
Hi everybody.
Great choice, I have 700 and would not change it for anything.
For that price, its a steal. This is one of the best sounding receivers ever.
Jare is offline
post #16990 of 17007 Old 07-16-2016, 02:04 PM
grasshoppers's Avatar
Quoted: 745 Post(s)
Liked: 443
In my opinion NO. The DAC in the MRX is as good as
Any outboard DAC. ARC will have a much greater impact
On what you hear. On the x10 series you can do what you wish
With an external DAC. (If memory serves)
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is online now
post #16991 of 17007 Old 07-16-2016, 03:48 PM
Liked: 0
I just the MRX 300 hook up in my living room. I was planning to use this in my room as a simple 2.0 stereo system, but it's way to good for that. So I decided to remove my Yamaha RX-A830 that was in my main 5.1 setup, and put the MRX 300 instead. Wow, I was blown away by its immense power. Not only does it go louder, but I'm actually hearing bass coming from 12" floor standing speakers for the first time in over a decade. Wow my mains bump so good that it put my 10" subwoofer to shame which can't dig deeper than 40 Hz while my mains can go deeper to the point where it can actually shake the floor. The bass on the MRX 300 it's truly incredible. The Yamaha RX-A830 was way to tame, it was very poor for music because I couldn't get any bass out my 12" speakers even with the equalizer and bass set to max. I always needed the subwoofer for music and movies. For movies there is some LFE, but very tame. On the MRX 300, the LFE becomes ground shaking.
I wonder why it's like that for the Yamaha's assuming they all sound about the same? Did the RX-A830 lacked real power or it was designed to sound a certain way? I also had two Onkyo A/V receivers, and again my 12" speakers couldn't bump at all. So that's two different brands which couldn't produce real bass at all. I wonder if Denon or Marantz sound similar compare to Anthem and if they can pump real bass on very large speakers?
omarchafa is offline
post #16992 of 17007 Old 07-17-2016, 04:15 AM
Jare's Avatar
Quoted: 30 Post(s)
Why is there a difference between x00 and x10 in terms of DAC?
Jare is offline
post #16993 of 17007 Old 07-17-2016, 05:20 AM
rossi46's Avatar
Quoted: 32 Post(s)
Please pardon the "newbie" question, but I'll be upgrading my AVR this fall in order to support my new 4K setup. I already have the TV and will be purchasing the new Oppo 4K bluray player as soon as it's released.
How would you compare the Anthem 520 to something like Marantz's entry-level AVR? The Marantz 5011 retails for $900, while the Anthem retails for $1,400. What are you getting for that extra $500?
Thanks in advance!
LG OLED 55" B6 | Philips 4K BDP-7501 | Yamaha RX-A1060 | KEF KHT-3005 | BlueJeansCable
rossi46 is offline
post #16994 of 17007 Old 07-31-2016, 08:16 AM
sukumar's Avatar
Quoted: 12 Post(s)
I got new step in home theater and did anthem correction test. Appreciate your feedback.
My system
Speakers: Paradigm Studio 100 (front), 690 (center), ADP 590 (side surround; dipolar),
Subwoofer: Paradigm Sub 15
Receiver: Anthem MRX 700
ID:	1575449   Click image for larger version
sukumar is offline
post #16995 of 17007 Old 07-31-2016, 06:26 PM
Legairre's Avatar
Quoted: 356 Post(s)
Liked: 199
My system
Can you post your ARC target window and speaker levels?
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is online now
post #16996 of 17007 Old 07-31-2016, 08:28 PM
sukumar's Avatar
Quoted: 12 Post(s)
Thanks for quick reply. how do I get those? I have 3.0.2 version and can't find anywhere in the menus. I took these couple of days back. I am putting screen shot of ARC tool. Appreciate your help.
sukumar is offline
post #16997 of 17007 Old 08-01-2016, 07:15 AM
orange55's Avatar
Can you advise if it is possible change the volume display from -DB to showing just numbers.
I believe other manufacturers call this PreAmp mode as apposed to Cinema mode which is the -db figure from reference level.
Thanks in advance.
LG 55EC930V, Tag McLaren AV192R, Tag McLaren 100x5R, Linn Akurate 242 MK3, Katan & Trikan Loudspeakers, B&W PV1 Subwoofer, Tag McLaren DVD32R, Oppo BDP-103, Sky+HD RA upgraded, Lumagen Mini3D, Philips Pronto TSU9600, Chord Signature Tuned Array Cables, IsoTek Power, Spectral Stand.
orange55 is offline
post #16998 of 17007 Old 08-01-2016, 07:57 AM
Legairre's Avatar
Quoted: 356 Post(s)
Liked: 199
No problem the "Target" window is in the ARC software you ran to make the graphs. It's the second button from the left on the top. Also when you're in there take a pic of the "Advanced" window by clicking the advanced button on the lower right of the target window.
Legairre
post #16999 of 17007 Old 08-01-2016, 07:59 AM
Legairre's Avatar
Quoted: 356 Post(s)
Liked: 199
Thanks in advance.
Unfortunately there isn't any way to change the display from dB to just a numeric scale
post #17000 of 17007 Old 08-01-2016, 08:18 AM
orange55's Avatar
Great, thanks for the quick update.
orange55 is offline
post #17001 of 17007 Old 08-01-2016, 10:28 AM
sukumar's Avatar
Quoted: 12 Post(s)
Legairre
Thanks Legairre, I am attaching targets window and advanced window. Not sure where I find speaker levels. I can run one more time if I can capture these at that time. Appreciate all your help.
ID:	1577889   Click image for larger version
sukumar is offline
post #17002 of 17007 Old 08-03-2016, 06:24 PM
Britcanuck's Avatar
A Sad Day
I think my beloved MRX300, which I purchased new five to six years ago, has died. I think we may have an electrical issue in the house, as the screen "flashes" or goes purple whenever a light switch to the basement turns on or off, or recently whenever lightning strikes during storms (which we've had lots of lately). I have temporarily solved the issue by switching the inputs (ie to blu ray then back to tv) which normally fixed it. Last night during a thunder storm, it stopped working after I shut my system down following a few "purple" screens, and it hasn't come back on since (standby light isn't lit either). I have unplugged and plugged the power cord to see if that helped, unfortunately it didn't.
We moved housed five years ago, and I was very careful when I moved the receiver. It has been plugged into two surge different surge protectors, but suffered the same flashes or purple screen over the last five years.
Has anyone had a similar issue, and is my receiver basically fried? Just thought I'd check here and see before I go and purchase a new reciever to see if there's a cheap and easy solution.
Thank you.
**UPDATE** - Unplugged the receiver and took the top off to see if there was a fuse or something that had blown, took a chance and plugged it in to see....and it lives again (hopefully for a long time)!!! I'm still concerned about the flashes and purple screen issue though.
Xbox Live: Barrelcounter
Britcanuck is offline
post #17003 of 17007 Old 08-04-2016, 07:09 PM
Julio Castrejon's Avatar
Quoted: 106 Post(s)
On my MRX 300, I keep losing HDMI output signal whenever I turn it on for the day. The screen goes green or purple, or sometimes the video looks corrupted. I hear a faint electrical sound on the back of the receiver near the HDMI board. When I unplug the HDMI Out cable, it goes away. When I plugged it back in, the sound comes back sometimes and I don't get any output through my TV. I usually turn it off and on about two or three times before everything works perfectly again. It's like it needs to warm up before the HDMI output works flawlessly. Could this be a bad sign that the HDMI board might failed eventually or is it just being buggy? I have latest firmware installed. I also think that since it's really cramp in the back, a cable might cause it to malfunction like that. I tried to move things around, and it seems to work, but sometimes I screws up again.
Julio Castrejon is offline
post #17004 of 17007 Old 09-13-2016, 06:40 AM
pingas6's Avatar
Hi.
I would like to improve the equalization makes anthem in my living room, but I don't know how?
Or if I hang charts arc you help?
Anthem mrx 310
Thank you very much.
Regards.
pingas6 is offline
post #17005 of 17007 Old 09-18-2016, 07:47 AM
Billy p's Avatar
Quoted: 255 Post(s)
Liked: 588
I was raring to go this morning...only to find out I've misplaced the included 15' serial port cable that came with my MRX300 & ARC software....any recommendation on a compatible and cheap replacement solution.
TIA...
Bill
Ascend Acoustics Towers, STC w RAAL, 200 SE in espresso
54" of Panasonic Bliss, Anthem MRX 300, Oppo BDP-103,
Apple TV+ Giga 1800
Sub FA 18(Santos RW)
Old Indian proverb: We don't inherit the earth from our ancestors, but we borrow it from our children!
Billy p is online now
post #17006 of 17007 Old 09-18-2016, 08:38 AM
audit13's Avatar
Quoted: 36 Post(s)
Liked: 33
I believe any generic serial cable should work. The software can be downloaded using the microphone serial number.
Billy p likes this.
audit13 is offline
post #17007 of 17007 Old 09-20-2016, 09:48 AM
pingas6's Avatar
Hi.
Using measurements anthem to buy acoustic panels.
Thank you
pingas6 is offline
Anthem Mrx500 , Anthem Mrx300 , Anthem Mrx700 , Receivers Amplifiers , Component Amplifiers , 3d Hdtv , Speaker Systems
