Anthem MRX Receivers - 300, 500, 700 Owners Thread & Tweaking Guide - Page 568 - AVS Forum | Home Theater Discussions And Reviews
 36Likes
Old 10-05-2016, 01:55 PM
bjfh's Avatar
Originally Posted by SimpleTheater View Post
I'll sell you my MRX-700 cheap. It's doing nothing since I bought my Yamaha 3060 last month.
Thanks, but the voltage difference and shipping wouldn't be good
Ben (in Australia)
bjfh is offline
Old 10-05-2016, 04:04 PM
bjfh's Avatar
Originally Posted by grasshoppers View Post
You are correct, 6 inputs that can be configured.
Thanks grasshoppers, is it possible to have multiple audio connections for the one configured source if they will not be on at the same time? eg - for the BDP input source:
A bluray player connected via HDMI for video and audio
An audio device (eg Squeezebox) connected via analogue audio
Basically will the analogue audio inputs of a configured source work while the device that is configured for the digital input is turned off?
If so, then I could get a few analogue devices connected to sources where the digital device is off when not in use.
Ben
bjfh is offline
Old 10-05-2016, 04:57 PM
grasshoppers's Avatar
Quoted: 829 Post(s)
Liked: 526
Ben
I can't honestly answer that. All my sources are digital.
On second thought, you'd have to go into the set up menu
And change it every time. When I got a smart TV i used
Optical in for the 'aux' which is by default analog. It's now
DOA unless I redo the set up.
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is offline
Old 10-05-2016, 10:04 PM
bjfh's Avatar
Actually that is a really good scenario to test if you have the time:
1. In the Anthem's Advanced Source Setup for the "Aux" Source, set the "Main/Rec Analog Audio Input" to "Front Analog".
2. Get out of the menus and set the Anthem to "Aux" with the TV on and make sure you can hear the sound of the TV
3. Turn the TV off and plug any audio device (phone, ipod etc) into the front audio inputs and play something and see if you can hear it (you may need to up the volume on the player or amp).
If you have time to do that test I would appreciate it.
Ben
bjfh is offline
Old 10-06-2016, 01:03 AM
bjfh's Avatar
Ben
Actually no need to test this. I found my answer here:
So it seems this generation is only good if you have a maximum of 6 sources
Ben
bjfh is offline
Old 10-11-2016, 12:55 PM
sbr100's Avatar
Quoted: 14 Post(s)
ARC Update
Couple quick questions...
1.Anyone know if there was a recent ARC update and if so what changes were made?
2. If there was once I download the new file will I need to rerun calibration?
I cant remember the last time there was a software update.
sbr100 is offline
Old 10-11-2016, 05:00 PM
Legairre's Avatar
Quoted: 589 Post(s)
Liked: 324
1) The latest ARC-1 is version 3.0.2
2) Not unless you you recently added center back channel speakers because the only change from 3.0.1 to 3.0.2 was adding the option of using the back channels as a single speaker instead of just both together.
There haven't been any software updates since 3.0.2. The MRX 00 series is Gen1 and they are now on Gen3. Anthem stopped all software updates for Gen1 not long after Gen2 was released.
"What do you mean it's too loud? My ears aren't even bleeding yet!"
Legairre is online now
Old 11-08-2016, 08:06 PM
EndersShadow's Avatar
Quoted: 566 Post(s)
Liked: 890
Ok guys I'm very frustrated and need some help.
I consider myself a "somewhat smart" guy when it comes to AVR's but I cant figure this out.
I have a MRX-500 with a BAD HDMI output. Not a problem I thought since the rest of everything works.
I have a Roku 3 connected via HDMI to a Insignia TV. The Insignia then feeds a optical signal into the Anthem. NOT ideal, but its what I have to work with.
I am running a 2.1 setup as I JUST got a sub TODAY.
ARC calibrated it no problem, I uploaded the settings no problem......
I can't get it to actually make sound when watching YouTube, PLEX (7.1 or 5.1 encoded movies), or Netflix.
Roku Audio settings are set to Auto (Dolby D). Insignia TV Audio output can either be PCM or Pass-through. Neither make a difference to the Anthem it appears. The bass management on the Anthem is set to 80hz and under quick setup Subwoofer is set to YES.
The Anthem appears to ONLY show 2.0 PCM on the display
HELP!!!!!!!!!!!!!!!!!!!!
My Setup | FS: Nothing right now
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is offline
Old 11-08-2016, 09:25 PM
Quoted: 566 Post(s)
Liked: 890
Nevermind. I finally figured out I could use the composite connection to at least get the OSD to show up on the TV to help things along.
The new sub's auto sense HAS to be on Auto for it to work for some reason. I was also confused as on the display on the Anthem if you put the speakers to "Small" you lose the sub option. Because it becomes ON and you cant turn it off.
So now I'm happy and listening to some really good music with the sub blended in quite well.
Old 11-10-2016, 08:56 AM
PhanofPhunk's Avatar
Quoted: 26 Post(s)
Good morning folks!
I have a quick and hopefully easy question regarding the Analog audio processing option. First off, I ran and use arc. Second, my set up.is 2.1 with paradigm monitor 9's and a m&k sub.
So the question is why do I get better bass when I turn OFF the analog processing? The sub has been tested down to 17hz, and obviously the paradigms get nowhere near that.
Michael
Sent from my SAMSUNG-SM-G930A using Tapatalk
PhanofPhunk is offline
Old 11-10-2016, 10:37 AM
Legairre's Avatar
Quoted: 589 Post(s)
Liked: 324
Originally Posted by PhanofPhunk View Post
Good morning folks!
Michael
I'm sorry I understand your question, but I don't understand how you are turning off analog processing. The MRX are digital receivers and even analog inputs such as iPod, CD etc.. are still still converted to digital before being output. The MRX doesn't have a "pure" mode that you can turn on/off bypassing the digital processing and turn on/off analog mode. The MRX is always in digital mode with no way to turn analog mode on or off.
Old 11-10-2016, 11:07 AM
Quoted: 26 Post(s)
Apparently there is. this is their version of pure direct.
Old 11-10-2016, 12:34 PM
Legairre's Avatar
Quoted: 589 Post(s)
Liked: 324
That looks like the Gen2 software run on the MRX 310,510 and 710. Not the Gen1 software run on the MRX 300, 500 & 700. Are you asking about the MRX 310,510 or 710 in the MRX 300, 500 & 700 thread? I'm asking because that screen doesn't exits in the Gen1 software, but it is part of the Gen2 MRX x10 series that does have a pure mode.
PhanofPhunk likes this.
Old 11-10-2016, 01:55 PM
Quoted: 26 Post(s)
Oh my. I didn't realize this was a x00 only thread. Sorry!
Old 11-10-2016, 02:00 PM
Legairre's Avatar
Quoted: 589 Post(s)
Liked: 324
Hey no problem. Sorry, not many of us in here are going to be able to help with the x10 models. I know the x00 models pretty well, but I'm out of my league when it comes to the x10 series.
Old 11-10-2016, 02:46 PM
Quoted: 26 Post(s)
Good morning folks!
Michael
Old 11-10-2016, 02:49 PM
Quoted: 26 Post(s)
^^^^please ignore
Old 11-10-2016, 02:57 PM
Legairre's Avatar
Quoted: 589 Post(s)
Liked: 324
^^^^please ignore
I think this is the thread you want: Anthem MRX Receivers - 310, 510, 710 Owners Thread & Tweaking Guide
Old 11-11-2016, 06:46 AM
Quoted: 26 Post(s)
Thanks for your help.
Old 11-21-2016, 07:02 PM
Liked: 0
i pod
Hi guys, I just picked up one of these awesome receivers, MRX 500, but am having trouble setting it up.
I started by putting everything back to factory defaults, and proceeded to program the outputs and such...
My question is why wont my i pod play?, it plays on other analogue gear that I have via rca cables.
What am I doing wrong?
vintageo is offline
Old 11-21-2016, 07:55 PM
Quoted: 829 Post(s)
Liked: 526
You have to assign the analog inputs to a source.
Rythmik F12 subs
Old 11-22-2016, 04:39 AM
Liked: 0
I thought that's what I was doing by setting the input to analogue...
I'm beginning to wonder if there isn't something wrong with this unit, I have to set one channel much higher than the other so that they sound even, would there be a DC offset adjustment inside?
The only reason I'm keeping it so far is because it sounds great!
Any help is appreciated
vintageo is offline
Old 12-04-2016, 03:26 PM
Liked: 0
Does anyone have a service manual for this receiver? I want to set the outputs
vintageo is offline
Old 12-04-2016, 05:37 PM
jmacari's Avatar
Quoted: 128 Post(s)
Liked: 157
Don't know if you mean Owner's Manual, or as you posted, Service Manual(?)-but maybe this page will help-
http://www.anthemav.com/support/manuals-literature.php
Anthem MRX-500,Outlaw 7500 5ch amp
Oppo BDP-103, Sony XBR-65X930D, Rotel RP-855, Phillips BDP-7501
Paradigm Studio 100 Fronts,Paradigm Studio ADP-590 Surrounds
Paradigm Studio cc-590 Center, Martin Logan Dynamo subwoofer, DefTech Supercube 4000
Roku Ultra, DIRECTV Genie DVR, OPPO Sonica DAC
jmacari is offline
Old 12-14-2016, 10:26 AM
hydrotex's Avatar
Quoted: 16 Post(s)
Will the MRX 500 pass 4k video?
hydrotex is offline
Old 12-14-2016, 12:13 PM
Legairre's Avatar
Quoted: 589 Post(s)
Liked: 324
No, the MRX 300, 500 and 700 will not pass 4K.
Old 12-17-2016, 07:01 AM
jmacari's Avatar
Quoted: 128 Post(s)
Liked: 157
Trying to figure out how to set up Zone 2 for my secondary DIRECTV viewing...
Currently, I connect my DIRECTV HR-44 to my MRX-500 via HDMI, has worked great since day 1; with this setup, i use the full 5.1 setup, 1080I/1080P (check my speakers in signature)
What I was thinking of doing was the following, for casual TV watching (and to give my speakers a little down time, i.e., preventing them from being used so often), was setting up a cheap soundbar for my casual TV viewing......the speakers on my Sony 930D aren't very good, so I thought a soundbar would be a reasonable substitution....just can't figure out how to set up cabling for this approach. I assume it would have to be Audio analog out from the DIRECTV HR-44 to my MRX-500...but what about video? I believe I only have 1 HDMI output on the DIRECTV HR-44 (that goes directly to Anthem,i.e. 1080P; Anthem can't pass 4K); I believe the HR-44 has component video connections that could probably be connected to the Sony as another input (I use a Roku through another one of the Sony HDMI's, optical out to MRX-500 for 4K streaming)
Anybody got any thoughts on how to set this up?
jmacari is offline
Old 01-10-2017, 12:01 PM
BEACHIN' CHRIS's Avatar
Cannot access menu
PLEASE HELP
Cannot setup my MRX 500 after a move. The TV input shows Coax for sound. My new cable box does not have coax. Cannot access the settings to change. Tried the remote and buttons on receiver with no luck. Ran HDMI and composite direct from TV for audio. Zip. Did the default setting and now lost audio on the blu-ray input.
Asking for help, opinions, etc. Thanks in advance.
Chris
BEACHIN' CHRIS is offline
Old 01-10-2017, 12:16 PM
Legairre's Avatar
Quoted: 589 Post(s)
Liked: 324
Originally Posted by BEACHIN' CHRIS View Post
PLEASE HELP
Chris
Does anything show up on the MRX 500's display screen or is it just blank? Everything that can be done with the on screen menu can be done using the MRX 500's display.
Old 01-10-2017, 01:22 PM
Thank you for your prompt reply.
Here's the settings:
TV: HDMI3/HDMI3
SAT:HDMI4/HDMI4
These are different as the audio settings on those inputs (before default) were Coax. If I could access menu and change settings, I'd be golden.
Thanks again.
Anthem Mrx500 , Anthem Mrx300 , Anthem Mrx700 , Receivers Amplifiers , Component Amplifiers , 3d Hdtv , Speaker Systems
