Onkyo Amp/Reciever Repair Questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-12-2010, 03:31 PM - Thread Starter
jrmywstr's Avatar
I was recently given an older, broken Onkyo amp/receiver (is there a distinction between the two?), I don't have it with me now and do not know the model number and stats off-hand. If that's important info I can post it soon.
I took it to a repair shop and the guy fixed it for $80, if I remember correctly he said that he replaced some parts with a relay in the power supply. He had it running for a bit on his bench. However, when I took it home it wouldn't play sound--the relay that usually ticks on at power up wasn't clicking. So I brought it back and the guy was a bit confused but took a look. He ended up replacing a transistor and not charging for the extra labor. When I went to pick it up he turned it on and the relay clicked, he said he had played the radio through it for a day.
However, when I got home and plugged everything in it wouldn't work. No relay click. Is it possible that something is breaking while I transport it to and from the repair shop (about 30 miles)? My only other thought as to what is going on is that I live in a pretty old cabin with only two-prong outlets. Is it possible that the amp draws more current than my older electrical wiring can handle and is somehow breaking something inside the amp each time i plug it in and turn it on?
I'd hate to have to drive it back to the repair shop again, I'd feel like I was cheating him for doing the work and then me somehow breaking it each time.
Any advice/comments would be great!
jrmywstr is offline
