Help with Receiver - 9.2 sound to 7.2 receiver? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-26-2010, 09:29 AM - Thread Starter
TKGeek's Avatar
I was about to buy a new TV, (Finally getting flatscreen) but to take advantage of HD, I was also going to buy a new receiver. I was trying to keep it under $1,200 for the TV, wall mount, and receiver. Setting aside around $700 for the TV and wall mount, I have $500 or so for the receiver. However, we have 5.1 sound in one room, 2.1 sound in another room, and stereo sound outside. I checked at numerous stores, and all 9.2 receivers cost anywhere from $1200+, over double my price for the receiver. However, I found multiple 7.2 receivers for anywhere from $300-$500, well within my price range. We rarely use the outside stereo speakers at the same time as the 2.1 ones in the 2nd room, and when we do, they're always playing the same thing. So, I was wondering if there was some sort of speakerwire splitter, or something we could use to hook up the 2.1 speakers to the 2.0 speakers. Is there a way to, or am I out of luck?
TKGeek is offline
post #2 of 3 Old 11-26-2010, 01:14 PM
jdsmoothie's Avatar
Quoted: 14339 Post(s)
Liked: 6768
If you use an impedance matching speaker selector you can connect it to the Zone 2 speaker posts of a 7.X multi-zone AVR and then connect multiple rooms of stereo speakers to it.
jdsmoothie is online now
post #3 of 3 Old 11-26-2010, 05:07 PM - Thread Starter
TKGeek's Avatar
Hmm... that seems like it would work. Although it doesn't allow a subwoofer, according to its title, most music I have doesn't really use the subwoofer. So, it should work. Thanks.
TKGeek is offline
