Amplifier FAQ - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #271 of 290 Old 09-22-2015, 01:37 AM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
Originally Posted by lovingdvd View Post
Good point.
Yes. I ran it with one speaker for the reason you cited. I get 99 dB with 250w that way, when not located near a wall. Basically they give you a +6 dB bonus for being in a baffle wall, which is what I heard previously (actually I heard +3 dB to +6 dB benefit from baffle wall).
So yes, at just 250 watts I can hit 105 dB reference. However my concern is that if I don't go with something higher, like at least 300 or 350w, then there may not be any (or enough) headroom as needed. For example, as pointed out here, speakers can change their impedance at different frequencies. So if the KEFs drop to a 2 Ohm or whatever load then all of the sudden the 250 watts is no longer enough. Maybe it delivers 125 watts for those times which then drops things by 3 dB. So its nice to have at least the piece of mind that there is extra watts available as needed.
That said, even if it drops to a 2 ohm load with 250 watts then becomes 125 watts and the loss is only 3 dB. So essentially - if I have this straight - if I am OK with knowing that I can always play movies just fine at 3 dB below reference, that's acceptable to me. Realistically I won't listen at reference anyway - to my aging ears its painful and makes them ring. I like the idea of knowing I can play perfectly fine at reference because it then means I can play perfectly fine at any level below reference. But if I can be 100% confident that with 250w of power I can play with no problems at -3 dB or -5 dB below reference, I think I'm good to go. I really can't imagine watching a full movie any louder than that anyway.
It would be great to know what numbers they have for power compression as well, which Mike Garret says can account for 3 dB to as much as 9 dB of loss depending on the speaker.
What about a ATI 6012 for all surround channels, with a ATI 6003 for L/C/R.
fatbottom is offline
post #272 of 290 Old 09-22-2015, 09:28 AM
lovingdvd's Avatar
Quoted: 2214 Post(s)
Liked: 360
Originally Posted by bigguyca View Post
When compared in dB's, and that seems the relevant comparison, the output of all these ATI amplifiers is similar. It's hard to get excited about a dB or two from an engineering standpoint.
Agreed, from a dB output standpoint when the impedance is around 4 ohms. My concern is about having the headroom and trying to figure out how much is enough. For instance in this case its not so much about "my speakers can play 2 dB louder if I have that extra 200 watts" but more like "for passages where the impedance is lower, and/or for reduced efficiency at the speaker when the coils are hot (power compression), having that extra 200 watts should help me be able to MAINTAIN the same loud listening level".
So IOW its not so much the extra watts for being able to pick up an extra 2 dB, but more about the extra watts to be able to properly maintain loud levels when conditions exist the require more power from the amp, such as peaks or dips in impedance or power compression etc. Does this make sense?
That said, my personal choice is for big amplifiers. I don't think I ever use their full capability, but I get satisfaction in owning them; who knows why. I don't own a Corvette, but I doubt most owners drive 150 mph very often, if ever, but they like owning the beasts.
The car - that's a great analogy. In my case I'd prefer to have the exact amount of power that I'd ever need, without having wattage in reserve that is wasted. That's the challenging part, because without specific tests and data from the manufacturers (or others that have tested) its very difficult to know. So what I think I've learned in this process is that a) its very hard to predict exactly how much you many watts you may ever need beyond what a SPL calculator tells you, and b) to cover all bases people recommend 1.5-2x the speaker max wattage is to account for this overhead and "unknown" amount of watts really needed - and perhaps a fair or large amount of that 1.5-2x winds up never being used but is there for those times (perhaps very short or specific passages etc) when needed.
To be clear: I have no experience with high-end Class D amplifiers. Likely my iPhone, and the audio system in my car use them, but that's my limit of experience. I've read about Class D amplifiers and have a basic idea of how they work...
Thanks. It would be really interesting to audition both types of amps in my room. I am almost tempting to get the speakers in place and try a two channel class D and class A/B rated at the same watts in the room to see if I could hear any differences (beyond would could be EQ'ed) and if one seemed to run out of power before the other... I wonder if others have done so. I have to image they have...
lovingdvd is offline
post #273 of 290 Old 09-22-2015, 09:32 AM
lovingdvd's Avatar
Liked: 360
Only 90 watts per channel.
post #274 of 290 Old 09-22-2015, 09:39 AM
Stereojeff's Avatar
Quoted: 112 Post(s)
Liked: 60
How about the BGW VXi8.8. Fully balanced, 200W RMS at 8 ohms and here's the big one----16 channels. Or the VXi8.4. 200W x 8 plus 400W x 4 at 8 ohms.
www.bgw.com
Jeff
Stereojeff is offline
post #275 of 290 Old 09-22-2015, 09:40 AM
fatbottom's Avatar
Liked: 518
Which is plenty for side/surrounds/ceiling. Saying that, I have a 2004 for side/rears which is a bit stupid.
Still if I was going atmos (I'm not) I'd probably get the 6012 for side x2, rears x2, ceiling x 4 maybe front effects, VOG channel, with a decent 3 channel.
post #276 of 290 Old 09-22-2015, 11:12 AM
lovingdvd's Avatar
Liked: 360
Originally Posted by Stereojeff View Post
How about the BGW VXi8.8. Fully balanced, 200W RMS at 8 ohms and here's the big one----16 channels. of the VXi8.4. 200W x 8 plus 400W x 4 at 8 ohms.
www.bgw.com
Jeff
Looks like a great amp - they are owned by ATI. It would be nice to have 16 channels of power all in a compact chassis (probably around a 6U) like this. However the VXi is really intended more as a commercial cinema amp and as such it has fans which are rather loud. The AT2000 series puts out similar power and 16 channels of that would cost less than the VXi so I'd prefer the 2000 series.
post #277 of 290 Old 09-22-2015, 11:58 AM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
in real content, afaik, there is no passage where the total impedance is significantly lower. There are frequencies at which the impedance is lower. So for a millisecond to (let's imagine) a second, if 20 perceent of the total power requirement is at 2 ohms and the rest is at an average of 6 ohms or more, you'e likely in no trouble. The amp has to push the total impedance, and never, unless you are sitting around listening to sine wave test tones, is anywhere like the majority of the power requirement going to be at the speaker's impedance minimum . . . . onaccounta that's not how sound works.
JHAz is offline
post #278 of 290 Old 09-23-2015, 04:55 PM
garygarrison's Avatar
Quoted: 507 Post(s)
Liked: 535
Although your post makes perfect sense to me, I'm still wondering why reviews in Stereophile and elsewhere sometimes say "this amplifier may have difficulty in driving a low impedance load." Why would those of us who listen to music care about that? I tend to see these comments in Atkinson's technical section of a review. I've also heard that some speakers that are rather efficient may still not deliver much "umph" (usually in the mid bass, for some reason) because of "impedance problems."
Of course, maybe that's for the benefit of people who do sit around and listen to sine waves, instead of music.
garygarrison is offline
post #279 of 290 Old 09-23-2015, 10:06 PM
lovingdvd's Avatar
Liked: 360
Originally Posted by garygarrison View Post
Although your post makes perfect sense to me, I'm still wondering why reviews in Stereophile and elsewhere sometimes say "this amplifier may have difficulty in driving a low impedance load." Why would those of us who listen to music care about that?...
I am not sure, but I think the answer is that speakers have different levels of impedance at various frequencies. Take for example the KEF R700 - specs here: http://kef.com/html/en/showroom/hi-f...700/index.html . Its nominal impedance is 8 ohms, but it also says minimum 3.2 ohms. I'm still pretty new to this, but I *think* this means that the speaker can dip down to those lower ohms, and that is where amp performance at lower impedance lows can come into play. Perhaps 3.2 ohms can be handled by most quality amps but some speakers can go even lower to 2 ohms or even less which could be problematic for some amps.
post #280 of 290 Old 09-24-2015, 07:00 AM
DonH50's Avatar
Quoted: 1790 Post(s)
Liked: 1323
Most speakers have peaks and valleys in their impedance and "nominal" impedance may mean very little. If there is a broad dip in impedance in the midbass, say to 3 or 4 ohms, and your amplifier has fairly high output impedance and/or limited current capability and you listen loudly, you may notice the lack of bass. Similarly, a lot or planar dynamic and ribbon speakers drop to 3 ohms or lower in impedance at high frequencies, and many ESLs drop below 1 ohm at 20 kHz, so with some amps you might notice the drop in HF energy. I would guess the majority of us would never tell in a blind test using most source material, but there are certainly real cases out there.
Tube amps generally have high output impedance and thus the overall system response depends upon the speaker's impedance.
And the amp and speaker do not care if it is music or movies. If your cymbals or kettle drum are lacking it is just as vexing as when a big explosion fizzles out or car chase sounds wimpy.
Over on WBF I wrote a little article showing how amplifier and speaker impedances interact.
IMO - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #281 of 290 Old 09-24-2015, 04:58 PM
Quoted: 507 Post(s)
Liked: 535
I agree that they may point it out for exactly the reasons you stated, but I infer from the post by JHAz that, even though at a certain frequency the speaker impedance may be quite low, in music ("real content," as he said), because more than one frequency is presented at once, i.e., one or more (usually more) fundamental, as well as all of the overtones of such fundamentals, the amplifier would only "see" a speaker load as low as 2 Ohms quite rarely, perhaps only for a few milliseconds, and would recover before it knew what hit it. Also, I would think that big climaxes that tax amplifiers are composed (pardon the pun) of quite a gaggle of fundamentals and overtones, therefore a more normal (higher) impedance would be presented, more like the speaker's "nominal" impedance, or many times higher, in some cases.
That being said, I still wouldn't want an amp that would freak out while sending a high intensity sine test tone to a speaker that happened to have a low impedance at the particular frequency of a test tone.
Some people have accused several popular speakers (no names please) of not delivering "punch" with small amplifiers because of impedance problems. Whether this a bald guess, a respectable hypothesis, or a confirmed result, using music as a source, I don't know.
post #282 of 290 Old 09-24-2015, 05:21 PM
Quoted: 507 Post(s)
Liked: 535
IMO - Don
Can you give us a linc to that article? Thanks.
post #283 of 290 Old 09-24-2015, 06:27 PM
DonH50's Avatar
Liked: 1323
No, the last time I posted a link to another forum I received a warning from an AVS Moderator. Google What's Best Forum then look in the technical section. There is, or was (haven't been there in a while), a sticky at the top with links to all my little babbles. I think you have to join to see the pictures, however.
DonH50 is offline
post #284 of 290 Old 10-10-2015, 08:18 PM
Liked: 1
I'm not sure where to post this.... but does anybody have a recommendation for a dedicated Audio 5.1 or 6.1 Amplifier ?
I use a video processor and don't need any Video capabilities that come with A/V Receivers.
garygarrison likes this.
surfin is offline
post #285 of 290 Old 10-14-2015, 06:14 PM
Quoted: 507 Post(s)
Liked: 535
Search for info on whatever NAD has in multichannel amps. I've had good luck with their amps.
What kind of speakers do you have, what is their sensitivity rating, and how big is your room? How far will you sit from your main front speakers?
post #286 of 290 Old 12-15-2015, 06:27 PM
Geek_Monkey's Avatar
Liked: 0
Originally Posted by Bidniz View Post
Just wanted to say thanks for taking the time to write all that up. It was a great read for me and very interesting!
Ditto...
That was a really good ....
I learned from it
Geek_Monkey is offline
post #287 of 290 Old 08-07-2016, 11:03 AM
rajdori's Avatar
Quoted: 13 Post(s)
Hi, An owner of Energy RC30 and RC70, but using Mirage speakers in main HT.
I was considering to setup stereo pair in bedroom. I was going through portable stereo Amps.. like SMSL SA50, or Topping vx3, or Topping TP22 etc. These are rated approx 35-50w per channel at 8ohm. Would they have enough juice to a pair of RC30s or RC70s? Both are 8ohm, recommended power approx 200w RMS.
Also, most of these AMPs come with only L and R output posts.. Any way to connect a powered subwoofer, like Mirage 8"...?
These amps are very portable, well-reviewed, and under $75. Or any other suggestions?
thanks in advance...
rajdori is offline
post #288 of 290 Old 08-07-2016, 11:52 AM
DonH50's Avatar
Liked: 1323
You should create a separate thread for those questions; this one is focused on explaining how they work and what they do.
You could buy a passive summer/attenuator to change the L/R outputs into a line-level signal for your sub, but you'll lose the benefits of rolling off the mains.
DonH50 is offline
post #289 of 290 Old 11-23-2016, 09:30 AM
1_1_1's Avatar
Quoted: 48 Post(s)
Still reading the thread so if someone has mentioned this sorry.
How about a section on RMS vs Max as it relates to amps and speakers.
I know I was told long ago that exceeding the RMS would cause there to be distortion (might be wrong but that's what i was told) so I've so far always wanted to be able to (in a desecrate setup) set the amp to just below it's RMS and for that to also be somewhere below the speaker's RMS and then use the preamp to adjust the volume.
A more informed bit on info on the topic would be great.
1_1_1 is offline
post #290 of 290 Old 11-23-2016, 10:55 AM
1_1_1's Avatar
Quoted: 48 Post(s)
based on what I've read I wouldn't aim for them to be rated at the same power output since most Class-D AFAIK are based on the tripath chip which due to patent issues and the original patent holder going out of business is limited in availability other than from china.
If you're trying to compare the QUALITY then use a sound level meter and match them to the same level, as the D-class will likely have a lower max rating I'd aim for just under the RMS of the lowest amp and match the sound level on all to that level.
If you just want to see which will be loudest then AB for sure.
Personally I have a TP-60 2ch 60wpc amp and I've very happy with it, since for me I'm not trying to go deaf just have good quality and 60wpc is plenty for me even with my KF-28's (actually on switching from KB-15's to KF-28's I had to turn the volume on the pro-pre down for most things.
1_1_1 is offline
