Amplifier FAQ - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 32Likes
post #121 of 303 Old 07-07-2011, 03:03 PM
cougar75's Avatar
Quoted: 39 Post(s)
Liked: 32
In the sentence above that you state "distortion is lower at less power output".
cougar75 is offline
post #122 of 303 Old 07-07-2011, 03:09 PM - Thread Starter
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
One sentence says distortion is less at lower power. This is true as a ge
neral rule (except at very low power.)
The other says that a more powerful amp means less distortion (all other factors being the same.)
Both are true.
"But this one goes up to 11"
MichaelJHuman is offline
post #123 of 303 Old 07-07-2011, 03:22 PM
cougar75's Avatar
Quoted: 39 Post(s)
Liked: 32
In general, would the difference in distortion measurements between a 250wpc and a 500wpc amp (class D) justify a 30% difference in price?
cougar75 is offline
post #124 of 303 Old 07-07-2011, 03:53 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
Subjective, really. If 250 watts is enough to play your system as loudly as desired then 500 watts would be a waste of money. Remember there's also a limit to what speakers can handle.
If you have sufficient cash, and think you need more power than 250 watts, and your speakers can use it, it might be worth it to you.
post #125 of 303 Old 07-09-2011, 07:13 AM
airboe's Avatar
Since a couple of month I am the owner of a DENON AVR-1611 receiver.
One of the reasons to buy this receiver was the possibility to connect an iPod doc station. For this reason I bought the ASD-11R.
For completion, I also bought an iPod touch (4th generation).
Believe it or not, but this combination doesn't work. When I put the iPod touch in the station, it's impossible to get connection.
With an iPhone (4th generation) it's not a problem and also an ipod touch (3rd generation) doesn't give problems.
A visit to the apple store confirmed this. They went deeper into specifications etc and con-firmed.
Because I can hardly imagine that this is true. The latest IPod touch and it doesn't work. I post this mail in the hope someone can help me out.
Here are the questions:
Has anybody experience with this and know how to handle this?
Is there one or the other way a connection or adjustment I forgot?
Hope someone can help me out, thanks in advance.
Leo
Beverwijk
The Netherlands
airboe is offline
post #126 of 303 Old 07-09-2011, 10:21 AM
Hugme1's Avatar
^^ I think you posted in the wrong thread.
Hugme1 is offline
post #127 of 303 Old 07-12-2011, 07:45 PM
gh02's Avatar
Thank you for the details!
gh02 is offline
post #128 of 303 Old 07-18-2011, 12:18 AM
mattsplat's Avatar
Nice FAQ - I once asked an NHT engineer about what power he recommends for their speakers, and I got the response "power is tricky thing" - he was right! So kudos for stepping into a potential minefield. Thought I might add my $.02 to the discussion as well.
- "Best sound for my budget?" Purely my opinion, FWIW: better speakers first. Good speakers with a decent AVR are likely to sound better than average speakers with a good amp. Balance is good, but the scale should favor speaker quality over power. Good advice for the less informed, perhaps?
- There are reasons other than volume (loudness) that can justify a higher-rated amp. A lot of folks pick up way more power than they need (i.e. they aren't trying to make their system louder) for the purpose of improved dynamics. You might consider mentioning something about capacitance (more power "ready to go" in a higher-rated amp) and how a 500W amp can deliver more of a "kick" or punchier sound than a 100W amp at a given loudness. While the need for power is often overstated, many claim to hear the difference with more power, especially in the dynamics. Does that make it so? No, but this view is widespread enough for consideration. I've never done A/B testing myself and can't comment.
- Might also correlate the term "headroom" with the lower distortion you'd expect to see from a higher-rated amp at a given loudness.
- I'd clarify the "power damages speakers" discussion. Driving speakers with too much current (power) can damage them. Using a higher-rated amp will not, by itself, damage speakers. Certainly there's a higher potential for damage with more wattage, because the amp can drive the speaker louder. Assuming no clipping, at 100dB, a 1000W amp is no more harmful than a 100W amp. (Likely less, considering the lower distortion.) The reason a 1000W amp is a bad choice for a 100W-rated speaker is that some jackass can come along and crank your stereo to the max: a 100W amp will do bad things in this scenario, but a 1000W amp will likely blow the speaker outright.
- In absolute terms, ACD measurements aren't helpful as they don't accurately represent how power is used in a 5.1/7.1 setup ... but in relative terms, they DO allow us to compare one amp to another. In that sense, ACD is helpful for judging amps and more manufacturers should include it. Another way to look at it: if an ACD measurement is given, it's likely a much better amp than one without an ACD figure. As you mentioned, most AVRs drastically reduce their per-channel output when using all channels, and an ACD figure would give us some indication of the real-world output.
- Consider this link for those concerned about matching the impedance of their speakers: http://www.audioholics.com/education...ector-switch-1
mattsplat is offline
post #129 of 303 Old 07-29-2011, 07:35 AM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
Thanks for the comments.
Addressing a few of them...
Why would a 500 watt amp give you more "kick" than a 100 watt amp, providing the 100 watt amp was not overdriven? By overdriven I am covering clipping, or current limiting. You would have to provide technical reasons for that claim.
I admit to disliking the term headroom, because I feel it's misunderstood. Headroom, by common definition, is power beyond what you think you need to deal with unexpected signal peaks. Say you wanted 100 dB SPL at your listening position for each speaker. You factor in speaker sensitivity and loss due to distance. You decide 200 watts / channel will do the trick. Well, maybe you got it a bit wrong. Knowing this is possible, you decide you want headroom. So you double the power. But that gets expensive! Maybe it's cheaper just to reduce volume a bit. Headroom, IMO, is not dynamics. You should factor in dynamics into your planning - for example using THX's stated 20 dB of dynamic range.
I have probably done a better job with the power vs speaker damage discussion. But I did not see anything wrong with what I said there. It says you can damage speakers with too much power, which is obviously true (but perhaps not common.) You can clearly exceed the speakers mechanical limits or thermal limits, which I did not get into (perhaps the AVR FAQ does a better job with that distinction.) I believe I mention that having more power can be a good thing to avoid clipping.
I won't address ACD Been there, done that. Suffice to say, there's vehement anti-ACD people out there, and vehement ACD people out there. The truth probably lies in between the extremes
Anyway, thanks again for the feedback. I always appreciate it.
post #130 of 303 Old 09-06-2011, 02:15 AM
YeuEmMaiMai's Avatar
Personally I find that the power output of my ancient HRT-6535 is overkill I do not listen to music or movies at really loud volumes and even when I have pushed the amp it has never produced any oddities...
Seems like even the good amplifiers are getting pretty lightweight now so I am not sure that heft is a good means of judging quality anymore
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
post #131 of 303 Old 09-11-2011, 09:26 AM
amosfella's Avatar
One think you didn't address in the FAQ was the use of a pro audio amp in a home theater setup... If one is using a pro studio reference grade amp, would that be quite suitable for a home theater amp??
amosfella is offline
post #132 of 303 Old 09-11-2011, 11:29 AM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
It's a good idea. A lot of people happily use pro amps in their HT setups.
post #133 of 303 Old 09-11-2011, 01:34 PM
amosfella's Avatar
For what a home theater amp costs, I'd think the pro amp is the way to go... example, a 2 channel 110W per channel at 8 ohm home amp costs about $650 here, while a behringer 2 channel 300W @ 4 ohm studio reference amp is $250 and change....
I can run my 4 ohm speakers (the whole 5.1 setup) for aprox $100 more than a 2 channel home amp costs... Just need a receiver with preouts...
post #134 of 303 Old 09-16-2011, 08:17 AM
AndreSP's Avatar
There are even bigger PKN amplifiers, the newest one has 40.000Watts output power and THREE PHASE(!) 400Vac line. I bet this is the largest amp ever... really, really impressive
AndreSP is offline
post #135 of 303 Old 09-22-2011, 01:58 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
40k watts does not make sense to me even with 3 phase. But I am not sure how that math works.
If each phase could pull 120 volts (not saying this is true,) and 25 amps, and somehow that equates to 360 watts with 75 amps, that's 27,000 watts continuous. I guess you could pull more from each phase without tripping the breakers for a short time. And I would guess it has some capacitor storage, but that has to be limited by a one space form factor.
Interesting, in any case
post #136 of 303 Old 09-22-2011, 08:53 PM
Gooddoc's Avatar
Quoted: 3118 Post(s)
Liked: 2424
But if the voltage is at 240 or 480 then it's doable.
Gooddoc is online now
post #137 of 303 Old 09-22-2011, 11:09 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
I know Crown's 10,000 watt amp used something like 3 phase. I never did the calcs on that one, but I am sure that one was pretty legit...I think one of it's main uses was to drive some medical imagry equipment (MRI? CAT?)
post #138 of 303 Old 09-29-2011, 08:47 AM
EricST's Avatar
Quoted: 116 Post(s)
Liked: 52
I have a Yamaha V571 . Would I benefit from a amp?
60" Samsung KS-8000
Oppo 203 UHBD
Denon X6300H eceiver
PSB X series 7.2.4
SVS Dual PB-1000
SVS Prime Elevation
EricST is offline
post #139 of 303 Old 09-29-2011, 04:47 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
Try posting to the main forum for more responses on that.
post #140 of 303 Old 12-19-2011, 07:05 AM
hidefpaul's Avatar
Quoted: 125 Post(s)
Liked: 79
Hello everyone, I have been looking for a decent 5 Ch amp for a while now, and over the weekend I walked into a local high-end audio dealer and may have made an impulse buy!
I purchased a Parasound Halo A52 5 channel amp....its being used with my Integra 7.6 DTR receiver which has unbalanced pre-outs, so it will "act" like a pre-pro and both amp & Receiver are driving Elac's FS 247's LRC SR SR in a 5.1 configuration.
I set it up over the weekend and WOW, I can truly hear a difference especially at louder volumes (no distortion or muddiness) as compared to before.
Anyway, I am not here to talk about that but to ask if it is necessary to run the Integra's audio calibration set up again. In all honesty everything sounds "right", I just want to know what the concensus is on this!
PS. I paid $ 800.00 Can for the used A52 in the box absolutely flawless, and it included 5 "Canare" 3' cables, I think that's how its spelled, did I pay it too much?
Paul
5.1 Home Theatre
Pioneer 60" Kuro
Integra DHC 80.3 Pre Amp
Parasound Halo A51 5 Ch Amp
Speakers : Elac's FS-247's (L,C,R SR, SL)
Sub: Velodyne SPLR1000
hidefpaul is offline
post #141 of 303 Old 12-20-2011, 09:43 AM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
Repost this in the forum. Posts in this thread should be about the FAQ (and you will get better responses by posting to the AVR/Amp forum.
post #142 of 303 Old 02-05-2012, 12:30 PM
bdizzle's Avatar
I just want to say a big thanks to the OP for writing this FAQ. I always wondered what the hell a amp/prepro was and what it was used for. Reading the sticky clarified a lot of questions I had.
bdizzle is offline
post #143 of 303 Old 02-05-2012, 12:35 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
Glad it helped
post #144 of 303 Old 02-24-2012, 03:58 PM
mond817's Avatar
If I want to build a 2.0 system for now and perhaps 5.1 in the future, will a 7.1 AVR overkill or it doesn't matter? It's for the bedroom and not going to be too loud at most of the time. Thanks in advance for your comment?
mond817 is offline
post #145 of 303 Old 02-24-2012, 09:00 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
Repost your question to amp/receiver forum. Posts in this thread should be about the FAQ (and you will get better responses by posting to the AVR/Amp forum.)
post #146 of 303 Old 03-09-2012, 01:26 PM
rnrgagne's Avatar
Quoted: 65 Post(s)
Liked: 65
Is there sort of a standard range for external amplifier input sensitivity and gain?
Or if not, does anyone know how big of a swing in gain there can be with typical HT amps?
Current Gear: Anthem AVM60, D-Sonic 3500/7, Oppo UDP-203, PS Audio Nuwave Phono Pre, Technics SL1210 w/ Denon DL103, Dune Duo 4K, LG Oled55e6, Paradigm Sig. S6 & C3 v.3's, Monitor ADP's, Velodyne SPLR1200.
rnrgagne is offline
post #147 of 303 Old 03-10-2012, 06:24 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
Most are in the 1 V to 1.3 V range for input sensitivity.
post #148 of 303 Old 03-10-2012, 06:28 PM
rnrgagne's Avatar
Quoted: 65 Post(s)
Liked: 65
What about gain, is there a similar range and is it tied to wattage?
rnrgagne is offline
post #149 of 303 Old 03-10-2012, 08:51 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
If I recall, it's something like this...
Gain = 20 * log ( v1 / v0)
So 28 dB of gain is 25 time voltage?
Say the amp was 120 watts...
p = v^v / r [ into 8 ohms]
So then voltage is 31 Volts at peak wattage? (Never can remember if I have to factor in peak vs average)
So if voltage gain is 25 times, then input sensitivity must be ... 1.25 volts?
post #150 of 303 Old 03-13-2012, 09:01 AM
72.sudhakar's Avatar
Dear Friends,
My name is Sudhakar and I need some help in making a decision to buy a good Amp/Receiver.
I have decided to buy the BOSE 901 Series VI with EQ.
I wanted to know what is the ideal AMP / Receiver that I should buy to get the best performance out of 901 series. Here again, I did some study (to my limited knowledge) and have an inclination to buy Yamaha product but considering the variety of options available, I need help to decide on a particular model that complements Bose 901 to its best.
As an alternative to Yamaha, if you have suggestions for other brand/models, please do give me your thoughts.
Price is not a constraint here and I am only looking at getting the best combination for Bose 901.
Looking forward to suggestions and inputs.
Regards
Sudhakar
72.sudhakar is offline
