Onkyo 804 HELP - no video over HDMI, just audio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-11-2010, 09:30 PM - Thread Starter
ryan_lesser's Avatar
Hello-
I have an Onkyo 804 that is not showing video on sources using HDMI. I have a 360 and Cable hooked through Component/Optical and it works fine. I bought an Insignia Blu Ray player today and tried to hook it up with the single HDMI and no luck. The weird thing is that I do get audio.
I then swapped spots and put cable tv in the HDMI and the BR player in Component/Optical. Now the BR works and tv does not.
I am setting everything in the Settings to the appropriate ins/out but nothing fixes the issue.
Any ideas? Thanks.
ryan_lesser is offline
post #2 of 4 Old 12-12-2010, 07:22 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi ryan_lesser, try setting the source to output at a low resolution (720p or 1080i). Or try turning off "Immediate Display" found under OSD Setup menu.
JChin is offline
post #3 of 4 Old 12-12-2010, 09:02 AM - Thread Starter
Ok. I just tried both of these with no effect.
post #4 of 4 Old 12-12-2010, 09:17 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hmm, how do you have the Xbox 360 and cable box assigned? And are both of these component being upconverted to HDMI Out or Component Out?
JChin is offline
