Can't get sound from Marantz A/V to Sonos - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-02-2011, 09:13 AM - Thread Starter
Ejmc's Avatar
I have a new Sonos system that I am trying to hook up to my Marantz AV receiver (SR7001) I can't seem to get any sound out thru the multi out or through the preamp out. Does anybody have any idea how I can get a line out to my Sonos. I would use the headphone out but that shuts off the sound to the speakers on the Marantz and I am trying to get the sound pumped into multiple rooms.
Ejmc is offline
post #2 of 5 Old 01-03-2011, 12:06 AM
M.Alex's Avatar
What you try to do?! If you want to get sound from Marantz just connect pre-out to line in on sonos, if you want to connect sonos to the system just connect line out from sonos to any available input on receiver. But to understand completely you need to explain what you try to do with your system .
M.Alex is offline
post #3 of 5 Old 01-03-2011, 07:52 AM - Thread Starter
Ejmc's Avatar
I found out that I need to connect all my devices to the Marantz with analog cables. I am currently only using digital connections (HDMI)
Ejmc is offline
post #4 of 5 Old 01-03-2011, 11:40 AM
M.Alex's Avatar
Of course! multi out just analog audio.
M.Alex is offline
post #5 of 5 Old 01-03-2011, 08:07 PM
fuzzybk's Avatar
I would use a digital co ax cable from the Sonos to your Marantz. This way you are using the DAC's in the Marantz instead of the ones in the Sonos for better music reproduction.
Cheers from the Great White North.
My gear: ANTHEM AVM50v, STATEMENT A5 - ARCAM DV139, CD17 - PANASONIC 65VT30 (THX Calibrated) - SONY BDP-S5000ES - PANAMAX 5500EX - M&K V1250THX sub - TANNOY EYRIS DC3, DCC, DC1 - AUDIOQUEST Cables - SHUNYATA RESEARCH Power cords - HARMONY One - PRIMACOUSTIC Recoil Stabilizers - BLUESOUND Node
fuzzybk is offline
