Yamaha RX-A3000 subwoofer question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-11-2011, 04:22 PM - Thread Starter
Oldylr's Avatar
I am trying to get the setup right on my subwoofer and I am not getting any signal going to the sub at all.
Some details:
Front Speakers are set to small
Single sub-connection via audioquest sub cable
Setup as 5.1 system with Subwoofer "on"
Fronts are crossed at 120 Hz
Sub is crossed at 150 Hz
I can't even generate a test tone through the sub and the gain is maxed.
Any suggestions? The yamaha manual and website are pretty worthless.
Oldylr is offline
post #2 of 9 Old 01-11-2011, 04:28 PM
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
Ho Oldylr, how do you have the sub cable connected to the reciever?
Sub cable should be connected to "Pre Out Subwoofer" and not "Multi Ch Input Subwoofer"
JChin is offline
post #3 of 9 Old 06-26-2011, 01:52 PM
pidass's Avatar
Having this same issue with my A3000 + Klipsch SW-450. Trying to narrow the issue with either the receiver or the sub. Setup has worked previously for a few months.
After an effort to clean up the rats nest of wires behind the tv stand, I noticed the sub wasn't doing anything. After looking noticed the sub connection was in the subwoofer input rather than the preout. Though even after switching it back to the correct connection it still doesn't work.
Tried swapping my subwoofer cable with another cable. Even tried switching to the 'Front' subwoofer preout but to no prevail. I can ground out the subwoofer wire against something metal and the sub will sound off but that's the only time it will work. Any suggestions?
pidass is offline
post #4 of 9 Old 07-01-2011, 05:47 PM
bratcliff7_2's Avatar
Any update on this? I am having the same issue..no subwoofer sound. Plugged in to Pre-Out...made the mistake of trying it in Multi Channel In...still nothing when corrected.
Please help!
bratcliff7_2 is offline
post #5 of 9 Old 07-01-2011, 07:51 PM
schan1269's Avatar
After making sure the sub is connected to the correct OUTPUT...
Make sure you are on a 5.1 source and don't have it set up direct in the receiver. Also make sure that whatever source you have is set-up to send 5.1 and not 2.0 PCM.
schan1269 is offline
post #6 of 9 Old 07-02-2011, 08:27 AM
pidass's Avatar
ended up calling Klipsch, they diagnosed it as a bad amplifier in the sub. After playing with the settings in my reciever, I cranked up the gain on the subwoofer to +10dB (highest it would go) and finally could feel the sub doing something but still not right.
they are sending me a new one for me to swap out.
pidass is offline
post #7 of 9 Old 01-11-2012, 10:56 AM
razzy3's Avatar
i have a similar problem...when i listen to music the sub does not play but when i watch a blu ray movie the sub works...any ideas?
i just got a new subwoofer and now i want another one...what in the world is wrong with me?!
razzy3 is offline
post #8 of 9 Old 12-28-2012, 04:54 PM
roblin's Avatar
After digging through the manual, I have finally figured out why my subwoofer does not make sound when listening to music without any surround sound processing - you have to activate "extra bass" feature under manual speaker setup (scroll down past subwoofer setting all the way to the next screen) - when "extra bass" is on the low frequency is played through both the front speaker and subwoofer; when "extra bass" is off then subwoofer does not engage if you set front speaker to large. However when you turn on any surround mode then the subwoofer will be used no matter if "extra bass" is on or off.
roblin is offline
post #9 of 9 Old 01-26-2013, 04:03 AM
PreOut's Avatar
Tag
PreOut is offline
