Onkyo TX-SR707 Problem - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-17-2011, 05:27 PM - Thread Starter
braves2's Avatar
I have the above model receiver and have the cable box, dvd player, and cd player hooked up through it. A couple of weeks ago, I started having problems playing the dvd player through the receiver as when I selected the dvd input, it would flash on and off on the receiver's display screen and then I would have to turn the receiver off and then back on to get the dvd player to work through the receiver. Now, I can't get either the dvd player or the cable box to play through the receiver; but the cd player does work through the receiver. Is there a reset on this receiver or is there a possibility the dvd and cable inputs are burnt?
braves2 is offline
