Integra DTR 7.8 - Unit Display Not Working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-26-2011, 12:24 PM - Thread Starter
FLPat's Avatar
I have a two year old Integra DTR 7.8. When I turned it on yesterday the display on the front of the unit did not light up, and hasn't since. The unit appears to be working fine otherwise, just no display. The only light working on the front is the red stand-by/IR monitor LED.
I tried the dimmer button on the receiver (and the remote) but no luck.
Does anyone know if I'm missing something simple, or if displays usually have a dedicated fuse that may be easy to replace etc?
Appreciate any feedback.
FLPat is offline
post #2 of 10 Old 02-03-2011, 09:06 PM
alanl715's Avatar
the unit is still under the 3 yr warranty ( u've had it 2 yrs )...have a servicenter replace the defective resistor in the display for free.
alanl715 is offline
post #3 of 10 Old 02-04-2011, 02:09 PM - Thread Starter
FLPat's Avatar
Thanks for telling me about the resistor. I got it refurbished, so I think the warranty was for 90 days or something like that. Sounds like it is a fairly simply fix, but it will cost me..!
FLPat is offline
post #4 of 10 Old 02-04-2011, 09:10 PM
alanl715's Avatar
Integra refurbs have a manf 2 yr p&l warranty fyi.
alanl715 is offline
post #5 of 10 Old 02-05-2011, 07:31 AM - Thread Starter
FLPat's Avatar
Dang, I bought it 12/6/08. The display died the next month, January, of course. Maybe they will have pity. Thanks for that info!
FLPat is offline
post #6 of 10 Old 03-13-2011, 08:55 AM - Thread Starter
FLPat's Avatar
I called Integra and they offered to warrant the repair. I took it to the local repair shop, they replaced a bad resistor, and now everything is working again - woo hoo!
It was a lot of work for a bad resistor. I thought it was pretty nice of Integra to warrant the repair even though I was a month out.
FLPat is offline
post #7 of 10 Old 12-06-2012, 12:46 PM
drsung's Avatar
Do you have any additional information on the resisitor? I have a 7.8 that is now long out of warranty that the display screen does not come on. The rest of the receiver works fine. I would like to attempt the repair myself.
drsung is offline
post #8 of 10 Old 01-22-2013, 02:36 PM - Thread Starter
FLPat's Avatar
I wish I could help you but I did not get any of that information from the repair shop. Alanl715 sounds like he might know. Good luck!
FLPat is offline
post #9 of 10 Old 01-22-2013, 02:36 PM - Thread Starter
FLPat's Avatar
FLPat is offline
post #10 of 10 Old 10-01-2013, 01:25 PM
GANDDALFF69's Avatar
I have the same problem with the same model, I'm in Miami and can't find anyone here. can fix or sell the parts
Thank for any information
GANDDALFF69 is offline
Integra
