new amp, speakers buzzin?? - AVS Forum | Home Theater Discussions And Reviews
Old 02-14-2011, 06:09 PM - Thread Starter
mccobra's Avatar
just got a Rotel RMB 1095. sounds amazing with my polk rti A9s when watching a movie or listening to CDs. When i have nothing playing i can hear a slight buzzing sound from my speakers.. all 5 channels. it does get worse when i turn on all my lights and does not completely go away when i turn them all off. just curious as to what is causing this annoying buzz. any help greatly appreciated
thanks
justin
mccobra is offline
Old 02-14-2011, 06:53 PM
Blue Rain's Avatar
Quoted: 140 Post(s)
Liked: 40
thanks
justin
Ground loop ?
Try disconnecting and connecting equipment one piece at a time to see which piece of equipment is causing the hum..
OR
Try a different electrical socket other than the one the lights run off of.
If you don't know whats running on what turn everything off in the house than go to electrical panel and turn off one breaker at a time to see what can't be turned on (No Power).
That is how I found out whats running on what.Mark everything down for future reference.
Simple explanation here and how to troubleshoot.
http://www.psaudio.com/ps/wiki/Hum/
Polk 7.1
Samsung PN60F8500
73" 73738 Mits DLP
Onkyo TX-NR3008
Panasonic AE4000 Projector
Blue Rain is offline
Old 02-15-2011, 09:29 AM - Thread Starter
mccobra's Avatar
thanks man appreciate it
mccobra is offline
Old 02-15-2011, 11:26 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Are your lights on dimmer switches? That could explain why it gets worse when the lights are turned off.
"But this one goes up to 11"
MichaelJHuman is offline
Old 02-15-2011, 01:44 PM
wwinkler's Avatar
Quoted: 23 Post(s)
Liked: 31
A few years ago, a buzzing-type of sound caused trouble with a subwoofer in my basement HT room. I got rid of the buzzing by removing a dimmer in an upstairs dining room.
wwinkler is offline
Old 02-15-2011, 07:39 PM - Thread Starter
mccobra's Avatar
yes they are..... its like dimmer central in my house. apparently very popular in the 80s when my house was built
mccobra is offline
Old 03-11-2011, 11:42 PM - Thread Starter
mccobra's Avatar
ground loop hum it was...... cheater plug into a different outlet solved the problem. seems like i tried it the other day but it didnt go away. oh well fixed now. thnks
mccobra is offline
Old 03-12-2011, 05:47 AM
ccotenj's Avatar
Liked: 101
no, it's identified, not fixed...
don't just leave the cheater plug in place... that ground is there for a reason...
now that you know what the issue is, take the proper steps to fix it...
safety first...
- chris
ccotenj is offline
