which to use for HDMI switch hub. amp.or TV or both? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-17-2011, 05:05 AM - Thread Starter
stevethebrain's Avatar
Quoted: 108 Post(s)
Liked: 25
I read that most TVs will not output 5.1 sound from either toslink or HDMI output. the TV only outputs 2.1.
so this means all sources should be connected to amp. in w/HDMI then
out of amp. w/ HDMI into TV. (TV is Samsung PN58c500).
?1.so in order to get 5.1 sound on 3 sources (for me 1.TV, 2.DVR,3,DVD player)
this requires a amp. w/ a minium of 3 HDMIs in correct?
?1.5. connected like this is a Tosh link still required?
?2.so I could'nt use both the TV and the amp. as switching hubs and expect 5.1 on all three sources?
edit: I would like to use the Samsung remote to control TV,DVD player and amp. volume though it's anynet link.
reason I ask I'm concidering a Denon1609 amp. and it only has 2 HDMI inputs. when I ran out of USB ports on my laptop I added 3 w/ an extrenal hub.
are there simiarial HDMI expandable hubs?
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #2 of 3 Old 02-17-2011, 07:34 AM
Beemer533's Avatar
That is correct, most if not all TVs will only output 2 channel.
I'll assume when you say 'amp' you mean 'reciever'.
1. Yes you are correct.
1.5. No, with an HDMI connection Toslink or SPDIF is not required
2. not 100% sure what you mean but, I don't see why you would want use both the TV and reciever as a switcher...
Yes, there are external HDMI switches that will work.
Just looked at your post again... is there a reason you are calling the TV a source? The only reason I can think of is if it has Netflix or you are using the tuner?
Otherwise the TV wouldn't be considered a source... just an output. In this case you need a reciever with 2 inputs and one output (not 3 inputs).
Whiskey Tango Foxtrot, Over.....
Beemer533 is offline
post #3 of 3 Old 02-17-2011, 10:27 AM - Thread Starter
Quoted: 108 Post(s)
Liked: 25
I'll assume when you say 'amp' you mean 'reciever'.yes
my TV Samsung pn58c500 has a switcher of it's own called anynet, a source list is whatever is connected to TV w/ HDMI cable is reconized as a source, TV is also reconized as a source, I have a inexpensive universal remote however I would prefer to use the Samsung TVs tuner & remote (and not use the DVRs tuner because it's not a 1080 signal).
The TVs guide (whats coming on in future) go'es well in advance where the universal remotes only displays what's currently playing.
as far as using both the TV and reciever as a switcher...
I sometimes just watch TV w/out having to turn on DVR &DVD
also the amp (reciever I'm concidering only has 2 HDMI inputs
Just looked at your post again... is there a reason you are calling the TV a source? The only reason I can think of is if it has Netflix or you are using the tuner? yes using the tuner
responses in bold
