Banana Plug for Marantz SR7005? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-21-2011, 04:51 PM - Thread Starter
motoharu's Avatar
I am setting up SR7005 with Focal Chorus 8s.
Thinking about buying banana plugs as a set (20 piece)
But it seems to me that Focals have a bigger hole for bananas to be inserted than marantz.
Do i have top get different products for speakers and receiver?
What size of banana plugs, Marantz owners here use?
Are they really smaller than general or my eyes deceive me?
Thanx..
motoharu is offline
post #2 of 3 Old 02-22-2011, 04:50 PM
dsmith901's Avatar
AFAIK all banana plugs are the same approximate size, and all should fit the standard 5 way binding post. How do you know the receptacle holes are bigger/smaller? Making comparisons using pictures on a website are not likely to be accurate. In the unlikely event they don't fit firmly, where are you buying from, and what is their return policy (just in case). You might contact the people at Monoprice for their advice; they also have good prices on these, in case that is not where you are buying. Or buy at RShack and return if there is a problem.
"The truth is out there!"
dsmith901 is offline
post #3 of 3 Old 02-22-2011, 08:25 PM
Blue Rain's Avatar
Quoted: 140 Post(s)
Liked: 40
Thanx..
I don't own a Marantz (Onkyo) but these plugs are great !
Great customer service and answer emails the next day .
I thought my package got lost and they offered to send me a new
one no questions ask but the package showed up the next day.
You won't find them cheaper anywhere..be sure to check out how they work and you will see they will fit all AVR due to their design.
http://www.speakerrepair.com/mm5/mer...y_Code=locking
http://www.amazon.com/GLS-Audio-Lock...8431197&sr=8-3
Polk 7.1
Samsung PN60F8500
73" 73738 Mits DLP
Onkyo TX-NR3008
Panasonic AE4000 Projector
Blue Rain is offline
