Sony STR-DG820 Set Up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 03-01-2011, 12:24 AM - Thread Starter
Adam2001's Avatar
Quoted: 13 Post(s)
I just got a new surround sound system and was wondering people opinions on my amp the Sony STR-DG820. Any little tweeks or setting I should do to make my Energy Take Classic system be at it's very best??
Adam2001 is offline
post #2 of 11 Old 03-01-2011, 12:52 AM
WiWavelength's Avatar
Quoted: 29 Post(s)
Liked: 24
In the spirit of "Snatch"...
http://www.youtube.com/watch?v=jZoYUQSU38E&NR=1
"Any little tweaks?"
"Yeah, don't use entry level Sony AVRs."
AJ
WiWavelength is offline
post #3 of 11 Old 03-01-2011, 08:03 AM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 336
Run the auto calibration and make sure all speakers are set as small and have a 120-130hz crossover
crazyrob425 is offline
post #4 of 11 Old 03-01-2011, 11:03 AM - Thread Starter
Adam2001's Avatar
Quoted: 13 Post(s)
AJ
Love Snatch, but this amp is not an entry level sony. Not the top of the line but it's a cheap one.
Adam2001 is offline
post #5 of 11 Old 03-01-2011, 11:21 AM
Quoted: 29 Post(s)
Liked: 24
For Sony, unfortunately, any AVR that is not Sony ES is effectively entry level. And even Sony ES AVRs lag behind those from the likes of Denon, Onkyo, Yamaha, and Pioneer in actual power output, digital room correction, etc.
AJ
post #6 of 11 Old 03-01-2011, 03:18 PM
samsurd2's Avatar
Gotta love those Sony haters.
samsurd2 is offline
post #7 of 11 Old 03-01-2011, 03:25 PM
Quoted: 29 Post(s)
Liked: 24
Sony made unmatched CRT TVs and still manufactures top notch LED LCDs & disc players. But Sony has never made industry leading AVRs.
AJ
post #8 of 11 Old 03-01-2011, 05:46 PM - Thread Starter
Adam2001's Avatar
Quoted: 13 Post(s)
AJ[/quote]
AJ
I understand it isn't a Onkyo etc.. But the reviews are solid and that many tech sites can't be wrong. Some say kills comparable high end receivers in comparison.
Adam2001 is offline
post #9 of 11 Old 03-01-2011, 07:47 PM
Quoted: 443 Post(s)
Liked: 336
Hate budget Sony's all you want but my STR-DH700 out lasted my buddies onkyo tx-sr507 and now his new tx-sr508
And the Sony has plenty of clean power to push my Polk RM6750 5.1 speaker set, along with Monitor 30's and CS1 which took over the front sound stage
It may not be the best but on a budget it gets the job done
post #10 of 11 Old 03-02-2011, 02:25 PM
Zhera's Avatar
Adam,
Like what was mentioned before. Run the calibration setup for the receiver. Test the sound with different audio media sources (TV, DVD/BLRY,Music..etc). If the sound is to your liking, then leave everything as the calibration set it. If not then go into the Sony menu and start making small adjustments, like crossover freq setting and a good place to start is about 80Hz and increase to the next setting until you get the right bass to treble response from your speakers and Sub that you like.
Next check out individual speaker level adjustments or volume output levels and different sound and surround sound fields for what works best with your room environment.
Also remember that speaker placement is critical to achieving optimal sound quality from whatever type of AVR you own.
And for WiWave, why don't you go out and spend your money and buy Adam the kind of AVR you would like him to have because none of your input here was of any use in helping addressing the question asked.
Zhera is offline
post #11 of 11 Old 03-02-2011, 11:58 PM - Thread Starter
Adam2001's Avatar
Quoted: 13 Post(s)
Originally Posted by Zhera View Post
Adam,
Ahaha! Thanks man, good point! I would love a top of the line Onkyo if your taking requests WiWave!
@Zhera I'm waiting on my speaker stands and mounts to get the speakers in their final spots. I just can't seem to get it exactly how I want it. i'll get the xbox sounding great then music is lacking bass etc. Hard to balance for my different components.
Adam2001 is offline
