What receiver would be good as a Pre/Pro Setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-02-2011, 04:54 PM - Thread Starter
04rex's Avatar
Quoted: 117 Post(s)
Liked: 26
Hey Guys, i was thinking of gettign teh Anthem MRX300 as a Pre then using Emo amps. After thinking about it, i would be spending about $1200 for the MRX, but it has minimal connections. Only 4 HDMI, no 7.2 (which i was thinking of doing) etc. The only reason why i was thinking of going the Anthem route was becasue of ARC and the fact that its Anthem.
What would be a good receiver for under $1000 that i can use? I would like it to have HDMI connections, 7.2 in case i decide to do it and also some sort of room calibration system like Arc or Audyssey?
In case it matters, i would be running Paradigm Studio series speakers in a 7.1 setup for now.
04rex is offline
post #2 of 9 Old 03-02-2011, 05:00 PM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
Denon 3311....... Maybe a Yamaha A2000. The Denon will easily fit that budget. The Yamaha maybe, at the right place.
phantom52 is offline
post #3 of 9 Old 03-02-2011, 08:03 PM - Thread Starter
04rex's Avatar
Quoted: 117 Post(s)
Liked: 26
I like the Denon, but how does the 3311 compare to the Onkyo TX-NR708?
04rex is offline
post #4 of 9 Old 03-03-2011, 05:16 AM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
It doesn't for the fact alone that with the 3311 you get a better version of Audyssey(XT), whereas the 708 has Multi-eq only. Also the build quality, reliability, and its ability to closer meet its specs is in the Denon's favor. JMHO.
post #5 of 9 Old 03-03-2011, 05:21 AM
richr8's Avatar
you are going to get a lot of Denon recommendations I have and love Yammy's. but look at the activity on the Denon threads. We are highly out numbered.
Rich
richr8 is offline
post #6 of 9 Old 03-03-2011, 06:21 AM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
How true, but I'm a certifiable Yamaha nutcase. I feel in order to match what the 3311 has available though you would need to step up to the newer Yamaha's. the Aventage A1000/2000/3000 would all make excellent pre-pros. Another that may do alright for this service would be the RX-V867. Its just hard at this time to get an AVR that matches the quality and features of the Denon 3311 especially in its price range. I try to recommend Yamaha whenever possible but still IMO that 3311 is very hard to beat.
post #7 of 9 Old 03-03-2011, 07:15 AM - Thread Starter
04rex's Avatar
Quoted: 117 Post(s)
Liked: 26
Yeah, i thought the Denon was going to be the best choice. I currently like Yamaha as well, but for the price, the Denon seems to be the best.
04rex is offline
post #8 of 9 Old 03-03-2011, 07:49 AM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
Did you look at the Yamaha 867? It can be had for less than the 3311 at many sites.
post #9 of 9 Old 03-03-2011, 09:05 AM
phantom52's Avatar
Quoted: 27 Post(s)
Liked: 84
And this because most people don't know any better. We may be outnumbered but we are not being outsmarted. They just don't know what they are missing.
