Pioneer VSX-1021 Owners' Thread - Page 51 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
Old 01-12-2012, 01:12 AM
f00j00's Avatar
Originally Posted by afrogt View Post
Basically you cant do it. Not easily anyway. You'll be going thru a lot of menus and reassigning of audio inputs.
Stuff like this was a lot easier when audio and video were analog.
Specifically what video and source are you talking about?
This is a disaster to me...well i have my PC connected via optical IN and i sometimes watch other sources via HDMI and just want to listen to music at the same time...how this is not easily possible?
f00j00 is offline
Old 01-12-2012, 01:19 AM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi f00j00, sure its possible ... just assign the optical port to the same HDMI video input. Then use "Signal Sel" button to cycle from HDMI to Digital audio.
JChin is offline
Old 01-12-2012, 01:31 AM
f00j00's Avatar
Thank you , but that way the default input for the HDMI source (say for my satellite receiver) will be the Optical and when i want to change the source to my satellites' audio i will have to press Signal SEL to select back to HDMI audio...is that right?..Can't it be the other way around?
I would also highly appreciate someone can easily describe to me what is the Zone 1 & 2 and how to use them..i really tried to read the manual to get it to work..but i think im not getting the right picture....
Thanks a lot
f00j00 is offline
Old 01-12-2012, 04:59 AM
maskedavenger's Avatar
Do you need the bluetooth dongle for AirPlay or will it work through the network?
maskedavenger is offline
Old 01-12-2012, 05:09 AM
f00j00's Avatar
Over the network...
f00j00 is offline
Old 01-12-2012, 06:40 AM
REL77's Avatar
Originally Posted by REL77 View Post
Thanks, I have a Fat PS3... What should the reciever display be when i have it outputting LPCM? Last question is with the setup i posted above, should I only select Speakers A?
Anyone know this?
REL77 is offline
Old 01-12-2012, 06:41 AM
ccotenj's Avatar
Liked: 101
only over the network...
- chris
ccotenj is offline
Old 01-12-2012, 07:40 AM
Justind123's Avatar
anybody found a cheaper (non Pioneer) bluetooth dongle yet? I want to use it with my droid items and for party stream...
Justind123 is offline
Old 01-12-2012, 09:55 AM
rdclark's Avatar
Quoted: 287 Post(s)
Liked: 560
Originally Posted by pilyo143 View Post
Im trying to set up my receiver, but I'm confuse the manual doesn't explain it very good for rookie like me. What I want is 7.1 in the living room and have a zone 2 with different source than the main room. It look likes you can only do 5.1 if you want to have zone 2. If I stick with 7.1 front heights only do i connect the back speaker to the surround or to the surround back on the receiver? The front height or wide connects to the front height/wide on the back of receiver?
Is this receiver only limited to front height or front wide setup if you want 7.1?
If you aren't using zone 2 you don't connect anything to the surround back? Thanks in advance.....
The receiver has 7 channels of amplification. If you use all 7 of them in one room, there are none left for anywhere else. To have Zone 2, you would need to use a separate amplifier for the speakers in Zone 2, and feed it with the Zone 2 line-level outputs.
The extra channels for 7.1 can be back surrounds, front heights, or front wides. Pick one. You need front L/R, C, LS, RS before you can add the 6th and 7th channels.
"Surround" are the surround speakers in a 5.1 system, located to the sides and just behind the listening position, aimed inwards. "Back Surround" are the additional surrounds in a 7.1 system, located behind the listeners and aimed towards the front. You cannot have back-surrounds without surrounds.
Wide Awake
on the Edge
of the World
rdclark is offline
Old 01-12-2012, 10:16 AM
thechronic04's Avatar
I have not tried it myself, but have read that TRENDnet 300Mbps Wireless-N Travel Router Kit TEW-654TR or Netgear WINCE2001 (around $45 each) may work instead of spending $150 on the Pioneer one.
Has anyone had success with eiher one of these two, or some other solution?
Thanks much in advance.
thechronic04 is offline
Old 01-12-2012, 11:48 AM
KGD_007's Avatar
Originally Posted by redzone View Post
Is it possible to control the Speaker A/B function via a remote?
Check out pioneercustom.com. They list hex codes for speakers a, b and a+b. I just got my receiver and haven't tried them yet. It will depend on the remote you are using though. The factory remote won't do it. I have a Home Theater Master remote that will allow you to use hex codes for programming.
The are a ton of discrete codes listed for this receiver which can make Zone 2 control must easier.
Hope that helps.
KGD_007 is offline
Old 01-12-2012, 11:59 AM
rdclark's Avatar
Quoted: 287 Post(s)
Liked: 560
Those are wifi routers, not Bluetooth adapters.
Wide Awake
on the Edge
of the World
rdclark is offline
Old 01-12-2012, 12:08 PM
rdclark's Avatar
Quoted: 287 Post(s)
Liked: 560
Zone 1 is the room where the multichannel audio system fed by digital sources plays. Its functionality is controlled by first pressing the "receiver" button on the remote.
Zone 2 is some other place where you have a pair of speakers. You can play any *analog* source connected to the 1021 in Zone 2, independently of what's playing in Zone 1. Those analog sources can be the same devices whose digital outputs are also connected to the AVR, or they can be different ones.
Zone 2's speakers can be powered from the 1021 *if* you limit Zone 1 to 5 channels. Alternately, connect the 1021's line-level "Zone 2" output to a separate stereo amplifier to power the Z2 speakers.
Control Zone 2 by first pressing "Zone 2" on the remote. Zone 2 needs to be powered on separately, so remember to press "zone 2" and then "power."
Wide Awake
on the Edge
of the World
rdclark is offline
Old 01-12-2012, 12:19 PM
rhregis's Avatar
rdclark,
Let me ask you this, currently I have a 5.1 setup (Zone1), with a separate amp (Zone2) powering the kitchen and outside speakers. If I plug the bedroom speakers to be powered by the 1021 using the speaker outputs for 7.1 or also Zone 2, will the volume control for Zone 2 control all these speakers (accept the 5.1 of course)?
rhregis is offline
Old 01-12-2012, 01:15 PM
Justind123's Avatar
Am i missing something? Im NOT talking about the ethernet or Wifi of the AVR.... Im talking about the BLUE TOOTH dongle for Air Jam or android air play....
THanks Rdclark
Old 01-12-2012, 01:20 PM
rdclark's Avatar
Quoted: 287 Post(s)
Liked: 560
Originally Posted by rhregis View Post
rdclark,
No, the volume control never affects the Z2 line-outs, as you already know from your current setup. In your scenario, it will only affect the bedroom speakers, which you could then adjust using the app if you have it.
Wide Awake
on the Edge
of the World
rdclark is offline
Old 01-12-2012, 01:42 PM
rhregis's Avatar
I actually did not know that the volume control did not control Z2 line-outs, which explains why I could not do this with my ipod. Thank you for your input. You just saved me a bunch of time trying to troubleshoot this.
rhregis is offline
Old 01-12-2012, 04:37 PM
mikeybe's Avatar
Hi all,
I just ended up buying a used vsx-1021-k. So far so good, but it didn't come with the CD and I can't seem to find a way to download the AV navigator software online. Can someone:
1. Tell me where I can download this software?
OR
2. Make an ISO of the CD and upload it for me so I can burn it?
ftp.mikebeccaria.com
user: vsx1021k
pass: vsxupload
I would really appreciate it!
Mike
mikeybe is offline
Old 01-12-2012, 05:40 PM
bigshot82's Avatar
1 - what is the best way to use cable box remote(Cox) to control volume/input select on 1021? I am trying to eliminate need for receiver remote, at least for basic functions of input select and volume. There is probably more than one way to do this(using HDMI control, etc) I am wondering if someone has tried this before.
2 - I only have two front speakers(planning to add a center in the future). Can I use MCACC at all to calibrate? customer support told me I cannot; all I can do is to go to manual SP setup and disable speakers other than front.
I noticed that vocals (e.g. in movies) are somewhat overshadowed by music... is it because I don't have a center? (mains are polk M70) or is it a cal issue?
bigshot82 is offline
Old 01-12-2012, 05:44 PM
pilyo143's Avatar
Which is better for 7.1 setup? Surround back, front height, or front wide ?
If I choose front height speaker setup, whats the best surround setting ?
If I choose front wide, whats the best surround setting?
How about when the source is not 7.1, what do you guys use ?
If you set it on auto does the receiver still output 7.1 even the source is only 5.1?
If you set it on auto and the source is 7.1 which surround setting does it use ?
I'm planning on running zone 2 and just switch the speaker connection when I'm gonna watch a movie. I don't mind 5.1 when I'm only watching DTV. Do i still have to setup all over again every time I do this. Can I run the Mcacc for a 7.1 save it and run another one for 5.1 save it with a different name and just switch back and forth.
pilyo143 is offline
Old 01-12-2012, 06:39 PM
Carpaccio's Avatar
Why does my plasma (PN59D6500) automatically come on when I turn on the Blu-ray player (DMP-BDT210)?
Even when I put a CD in the Blu-ray player and play it, the TV comes on automatically. When I turn the TV off, the Blu-ray player turns off. When the music is paused for a while, the TV and Blu-ray player automatically turns off.
The reason I'm posting this here is because I'm thinking it's the receiver that's causing this since I have everything connected via HDMI to the receiver: Blu-ray player -> receiver -> TV.
Carpaccio is offline
Old 01-12-2012, 06:45 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Originally Posted by Carpaccio View Post
Why does my plasma (PN59D6500) come on when I turn on the Blu-ray player (DMP-BDT210)?
Hi Carpaccio, most likely its the HDMI-CEC feature thats enabled. Try turning them off in the receiver (Kuro Link HDMI Control), BD player (Viera Link) and Tv (AnyNet+).
JChin is offline
Old 01-12-2012, 08:56 PM
Carpaccio's Avatar
Thanks for your guidance. From the little I've read so far in the manual, I think you're right.
However, now I just need to figure out which of the three (TV, receiver, and BD player) I should turn off. I'm thinking the AnyNet+ because I only want to disable the automatic turning on and turning off of the TV and I don't want to lose any of the other features (whatever they may be) that Kuro Link offers with regard to the TV and BD player.
I'll do some more research and post what I did.
Old 01-12-2012, 09:09 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
^^^ Did this happen after adding a recently new component (tv, receiver or BD player)? If so try turning the new added component off first.
JChin is offline
Old 01-12-2012, 09:17 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
It can be cycle back and forth (HDMI -> Digital -> HDMI).
Connection example:
satellite receiver -> HDMI cable -> receiver (DVR/BDR)
pc -> Optical cable -> receiver (OPT-2 DVR/BDR)
JChin is offline
Old 01-12-2012, 09:19 PM
f00j00's Avatar
Tonight i was in the process of plugging in all my devices after the first day of usage until i plugged in my PS3 to the DVR/BD INPUT..i found the screen flickering and weird noises coming out of the speakers...i turned it off...tried a different cable...same thing...i turned the device off and plugged out the power cord..plugged in a different device with a different cable...nothing was detected...
So i reset the device by holding enter while turning on the device...same issue, when i plugin any device to that particular input...sometimes it gets detected but with like dimmed brightness / vertical lines or dots everywhere then the tv says no signal...
Could that be defected or is there any kind of a fix?
f00j00 is offline
Old 01-12-2012, 09:31 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Should display PCM and the symbols (L,C,R, SL,SR,LFE) on the front show the number of channels in the input signal.
JChin is offline
Old 01-12-2012, 10:19 PM
Carpaccio's Avatar
Not really. I got all three things for Christmas and hooked them up all at the same time.
Old 01-12-2012, 10:26 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Ok, I guess BD player first then .
JChin is offline
Old 01-12-2012, 10:40 PM
Carpaccio's Avatar
Hmmm, OK. I was thinking TV since it's the TV that keeps turning on and off automatically, but you're saying the BD player. I'm guessing because it's the BD player that's causing the TV to turn on and off automatically?
However, I thought that Viera Link was for universal control with the remote control. The TV comes on when I manually put a BD in the BD player and hit the Close button on the BD player - no remote involved.
Upon further research, my BD player doesn't have Viera Link, it has Viera Cast.
Any ideas on what my next step is?
Pioneer , Pioneer Vsx 1021 K 7 1 Home Theater Receiver , Receivers Amplifiers
