Pioneer VSX-1021 Owners' Thread - Page 64 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1891 of 2750 Old 02-18-2012, 06:31 PM
Scrondar's Avatar
Just getting my VSX-1021-k setup; I have my DVD audio going to the COAX 1, and when I switch to that source, the display says "Analog" until I start a disc, and then it says Digital and plays the audio fine. However, my Airport Express uses an optical toslink cable, which is connected to Optical 2 (which I chose because it's assignable), but when I switch to that source (renamed AEX in setup and assigned to Optiical 2), the display says Analog and stays there, even when I am streaming to the device. I am getting no audio from the stream, so I'm assuming if the receiver is not getting a signal from the AEX. Any ideas what to try?
And no, I haven't even gone near Airplay yet, as I am going slowly here to get all the components I had connected to my VSX-409 up and running before I venture into new waters. Any help is appreciated.
Scrondar is offline
post #1892 of 2750 Old 02-18-2012, 07:22 PM
amfca's Avatar
Setting up 5.1 system and need advise for proper settings.
In Wall Fronts: 8"; Theater Solutions TSS8W Symphony Series
In Wall Center: 5.25" x 2 Theater Solutions Center Channel TSLCR5
In Ceiling Rears: 8"; Theater Solutions TSS8C Symphony Series
Sub: RW-12D
My Questions:
MCACC run set fronts, center, and rears to LARGE. Should I change this to small? I was assuming the automatic setup would set all this up in the best fashion, but maybe I am mistaken.
If I leave them set to large, is it advisable to also allow passing of low frequencies to them as well as SUB since they can produce decent base? If so, how is that set up?
The SUB does not have a LFE labeled input, but manual says to connect LFE output to left speaker input. Is there an advantage to split the SUB output from the 1021K and connect to both Left and Right inputs of sub?
This sub has a digital cross over setting. Should it be bypassed or set to off since receiver is managing?
In general, what would the experienced members of this forum do for your setup in this configuration? (other than get rid of in wall and in ceiling speakers )
amfca is offline
post #1893 of 2750 Old 02-18-2012, 08:03 PM
Five28's Avatar
Quoted: 49 Post(s)
Liked: 40
@ Dante1
The difference between component cables and HDMI is ever so slight. I doubt you'd be able to see any difference unless you have eagle eyes or something.
Can't help you with your other questions though. I hope you find the answer.
BenQ W1070 front projector, Definitive Technology BP2002 towers, Def Tech CLR2002 center, Def Tech BP2X surrounds, Def Tech PF15 subwoofer, Denon AVR3300 receiver, Panasonic Blu-Ray player, Apple TV, Roku device, Monoprice HDMI switcher
Five28 is offline
post #1894 of 2750 Old 02-18-2012, 08:33 PM
dante1's Avatar
I was reading that maybe an HDMI splitter may do the trick
dante1 is offline
post #1895 of 2750 Old 02-19-2012, 08:29 AM
apaulct's Avatar
Try the SIGNAL SEL button on the remote (see OM pg. 36). Set to AUTO, it will select the first available signal in the order HDMI, Digital, then Analog. You can force it to digital by selecting that option.
Allen
apaulct is offline
post #1896 of 2750 Old 02-19-2012, 09:02 AM
apaulct's Avatar
All recommendations I have read suggest setting the speakers to SMALL and letting the AVR handle the base management. Even if your speakers are good down to 30 to 35 Hz, your sub will handle the bass better.
Setting them to LARGE will pass the bass frequencies to the speakers, not to the LFE sub output. The only way I can think of to get bass to both speakers & sub is to connect the sub via the speaker output, not using the AVR's LFE output.
If the manual says to connect the LFE output to the Left Line input of the sub, I would assume that input doubles as the LFE input. Don't split the LFE input, just connect it to the Left Line input.
IMHO, set all speakers to small and crossover to around 80 Hz, let the AVR handle bass management. Since the AVR is handling it, bypass the sub's crossover. Run MCACC with these settings. Tweak to your own preferences.
Allen
apaulct is offline
post #1897 of 2750 Old 02-19-2012, 02:08 PM
amfca's Avatar
Thanks Allen for your thoughts and advise.
How do I run MCACC this way? I ran the auto MCACC and thats what set everything to large. So I guess I am asking how to set up all to small, and then how to run MCACC that way?
What are the steps to take in order?
Thanks..Alan
amfca is offline
post #1898 of 2750 Old 02-19-2012, 02:08 PM
Scrondar's Avatar
It turned out to be there were two devices assigned to Optical 2. I removed the other, and all is well. Heck, I even have this sucker on the network and it shows up in iTunes for streaming. Now, if I can just figure out why the audio (music from CD and streaming) sounds so "muddy." Not sure how else to describe it, except to say it sounded a lot cleaner coming out of my old VSX-409. I'll keep fiddling till I get it right.
Scrondar is offline
post #1899 of 2750 Old 02-19-2012, 03:41 PM
ChronoMATT's Avatar
Hi all,
I just picked up a 1021 the other day and have had fun playing around with it so far. My unit's manufacture date is September 2011 and has none of the major issues I have seen discussed in the preceding near 2,000 posts. The only problem I am having that is common among many is with HDMI Pass Through capability, specifically playing my cable box when the 1021 is turned off.
I have followed manual instructions (turning HDMI Control "on", etc,) and those found from others here, and got this far: When turning off the 2021 while watching my cable box, the cable's video signal will remain on and the sound switches to TV's speakers for a few seconds and then both turn-off. During this process, the front face plate's red HDMI light remains on for the few seconds and then turns off as the cable signal does. There is obviously a switching issue going on here.
So, I am almost home! The cable box's video and audio signals are able to pass through -- a major step forward -- but only for a moment. Has anyone been through this and can pass through some advice?
I am close to considering a Y-splitter between my 2021, cable box and TV.
ChronoMATT is offline
post #1900 of 2750 Old 02-19-2012, 06:35 PM
harpo1's Avatar
Well I've had my 1021 for 2 1/2 months and today I went to turn it on and nothing. I unplugged it then plugged it back in and still nothing. A couple times in the past it would just shut itself off for no apparent reason but it would power back up . I guess the power supply took a dump. Anyone know what pioneer does if I don't have a service center near my location?
harpo1 is offline
post #1901 of 2750 Old 02-19-2012, 07:20 PM
Bruce/Fl's Avatar
If someone could show me the way, it'd be great. I just did a search for "surround", pages of results, went thru the first 2, no luck.
Just put together the new HT, New Panny Plasma, and VSX-1021. Using old DTV and PS3 slim, for Blu-ray content.
I can't find the setting for getting all the surrounds working. I'm getting nothing out of my rear's, or center (and sub, I assume). I did the MCAAC and they're all there, but for the wifes pleasure, were watching the new Twilight on Bluray. It says it is Dolby Digital 5.1 (Why not the newer lossless modes I have no idea) Anyways, all I am getting are the front left and right.
I tried auto surround, and it simply gives me stereo. What gives?
(And I just know this is probably answered somewhere in here, I just couldn't find it, and the wife says we've wasted enough time, so......)
Thanks all, I really appreciate it. Hopefully it's a simple fix.
And it's PS3 to the receiver on high speed HDMI. PS3 set to go out on HDMI, all modes selected.
Bruce/Fl is offline
post #1902 of 2750 Old 02-19-2012, 07:37 PM
froghunter's Avatar
I have good and bad news. The good news is that I had the same issue (maybe even the same time period since I bought it). There is probably a flashing light on the top left of the front display. You can exit this mode by holding the tune down (-) button and multi zone on/off button for two seconds. The unit is in some sort of protection mode which is why it isn't turning on.
When I did this reset, it powered back on, and I got to see smoke rise from inside the unit. And then it went back off. I am now going to get to see how good the warranty is. Best of luck with your problem and hope it turns out better than mine.
froghunter is offline
post #1903 of 2750 Old 02-19-2012, 07:58 PM
JChin's Avatar
Quoted: 381 Post(s)
Liked: 210
Hi Bruce/Fl, check PS3 settings.
In the PS3 XMB, set "BD/DVD Audio Output Format (HDMI)" to Bitstream which is found under Video Settings.
Also make sure to set "Audio Multi-Output" to Off which is found under Sound Settings.
And also note sometimes a Blu Ray disc will default to the standard DD/DTS track, so you might have to manually select the DTSHD-MA soundtrack. Normally this will be found under Audio or Language Setting.
JChin is offline
post #1904 of 2750 Old 02-19-2012, 08:18 PM
harpo1's Avatar
Thanks for the info. No flashing light on my unit but I did try holding down the two buttons you mentioned with no luck. I wish I would have bought the Denon 2112CI now. I'm calling pioneer tomorrow to see what they say.
harpo1 is offline
post #1905 of 2750 Old 02-19-2012, 09:33 PM
Bruce/Fl's Avatar
Thanks for the quick reply!
I tried that, it didn't work. But after the movie was over, I slipped in another disc (Fantastic Four) and it put out DTS Master HD, as it should have, so I guess it was just that Twilight disc. Heh.
Thanks again. I love this place.
Bruce/Fl is offline
post #1906 of 2750 Old 02-20-2012, 05:31 AM
Undrpsi's Avatar
ChronoMATT,
EXACTLY same here. I also tried everything and the closest I got to HDMI pass-through was EXACTLY the same as you...power off the rcvr and you get the TV saying "Switching Audio to internal spkrs" and then you get 1-3 seconds of it working..then.....LOS (loss of signal)...
My TV is specifically marked with "ARC" on HDMI 1...but it must be a 'different' implementation cause it's a black hole to the 1021. Funny thing though...no matter WHICH HDMI the PS3 is on (rcvr or TV) it will turn everything on and do audio/video pass through...(Sony TV has some kind of incestious thing going on....just kidding...I know it's the Bravia link)...This 'share the love' almost made me take the 1021 back for a Sony rcvr...almost. (see internet / air play apps comment)
I just ran the HDMI from my TW cable box to the TV then optical from TV to the 1021...works but not happy. Here's my setup...
Sony KDL55EX700
HDMI...........1021
Cable...........HDMI---PS3
1021............XBOX
optical
This works for what I want it to do....I actually jam in a set of Bose headphones a lot...especially if I want to play XBOX and the house is asleep. I have the bluetooth Sony headphones for the PS3.
I got the killer VSX-521 deal on Woot! for $139 shipped when they had the blowout sale 2 weeks ago. I was going to install it when I said the HE77 with it and bought an open box 1021 at BB for a lot more....but I really like the airplay, internet radio, and the iPad control apps. To me that was worth the $$$ for the upgrade.
I am LOVING sitting on the couch and listening to songs on my network through airplay then jumping over to listen to trance music from Algeria...way cool. Have had NO stutters or drops and I bet I put 3 hours straight on mine as soon as I could get Deadmau5 to load.
So...everyone...I am picking my speakers and I usually stay 'in brand'...I am tone deaf so I don't need $1000 reference speakers...here's what I have snagged so far for a inexpensive 5.1 system...(under $200)
1x Pioneer SW-8 Powered Sub (NE sale last week for $79)
4x Pioneer SP-BS21 (NE sale last week for $49 per pair)
I might pick up a pair of Pioneer SP-FS51 floor speakers and replace the front BS21's. Not because they suck but because I like the 'old school' look of the floor standing ones...
What I need help with is...my center channel...I HATE the size and roundness of the Pioneer SP-C21...YECH!....
Anyone have suggestions?
Pics to follow...I know the rules...no pics-no happen...
thanks!
Undrpsi
Originally Posted by ChronoMATT View Post
Hi all,
I just picked up a 1021 the other day The only problem I am having that is common among many is with HDMI Pass Through capability, specifically playing my cable box when the 1021 is turned off.
Undrpsi is offline
post #1907 of 2750 Old 02-20-2012, 05:28 PM
iafzal's Avatar
@undrpsi,
Pls read the Vsx-1121,1021 and 52 threads and you will find that standby pass thru does not really work in practical terms for these AVR.
I have 1121 and I spent a number of hours and gave up. The issue is that Pioneer implementation requires all devices source, AVR and TV need to support CEC-HDMI protocal. Usually the source (mainly BD or Sat boxes) are not compatible so you have no hope it will work.
If you have Ps3 slim than it may work if you follow the procedure in the manual. I have been following this thread for 3 months and only found one person using PS3 slim as source claiming it to work.
Btw, The 2-3 seconds delay is not that it is trying to pass through signal but just the lag(delay in relay turning off) as the AVR shuts down.
iafzal is offline
post #1908 of 2750 Old 02-20-2012, 05:51 PM
Carpaccio's Avatar
I'm looking for suggestions on the best scenes to use as a reference when comparing different audio configurations and settings.
Ideally, I'm looking for scenes that have a good representation of the full audio spectrum produced in the highest quality possible so I can listen to and compare the bass, mids, and highs between the possible audio configurations.
Any suggestions?
Carpaccio is offline
post #1909 of 2750 Old 02-21-2012, 08:24 AM
apaulct's Avatar
Run AutoMCACC but select "Keep SP System" in place of "ALL".
Allen
apaulct is offline
post #1910 of 2750 Old 02-21-2012, 10:27 AM
Undrpsi's Avatar
iafzal..
Thanks..I too have read this forum (and 521)...knew the HDMI pass through was vapoware on this rcvr. I could get the PS3 to do it...but not the cable box. I got it sorted by running the STB to the tv and using optical for audio. It's probably my cheapo cable box....
EVERYONE...New Egg has the 1021 for $349 (free shipping - no tax). I called Best Buy and, of course, they don't price match an online reseller. I told them bluntly that I was going to order it, pack up the one from BB, and bring it back. He said "I understand".
Also..to go along with my speaker question...New Egg is having a fire sale on Pioneer speakers. I got the subwoofer for $79 (doh..it's now $99). I got the Pioneer SP-FS51-LR floor standing speakers for $149....so now my Deathstar is almost fully operational.
Again, anyone have a center speaker reccomendation? Most of these are freaking huge and block some of the screen (my LCD's on it's stand not mounted).
Has anyone used an inexpensive sound bar for a center speaker or do they make one that's not $700 that's also a center speaker?
I listened to both iTunes and internet radio for almost 5 hours last night...I had one blip of dead air that lasted about a second and it was on an internat radio station out of Belarus...could have been a bandwidth fart...not rcvr per se.
Thanks to this board I am starting to get the hang of this complicated monster!!
Jay
Undrpsi is offline
post #1911 of 2750 Old 02-21-2012, 12:07 PM
robertw11's Avatar
Quoted: 74 Post(s)
Has anyone tried using the usb port on the back of the receiver to power a usb fan, for example one of these kits? http://www.coolerguys.com/840556090595.html
On the receiver it says it's for the lan adapter (not using), but I would like to install a fan onto my stand to try and keep my ps3/360/cable box cool.
Kuro'd
robertw11 is offline
post #1912 of 2750 Old 02-21-2012, 01:11 PM
Upgrader's Avatar
Quoted: 38 Post(s)
I just ordered one of those myself today from the cooler guys for the exact same reason. Plan to use the USB port behind my Onkyo TX-NR3009 receiver to keep it cool. Hopefully it will work and will turn on/off automatically with the receiver.
Let me know if you find out first.
Upgrader is offline
post #1913 of 2750 Old 02-21-2012, 02:01 PM
iafzal's Avatar
Originally Posted by Undrpsi View Post
iafzal..
Jay
1021 has gone as low as $299 @ neewegg.
If you are looking for Sat system then I can recommend going with MartinLogan MLT-2 from Newegg. Usually they go down to $300 for the 5.1 system once a month.
Great speakers for being just a sat system and in my opinion will easily be better than any sat system under $500. They have 4.5" woofer and 1" tweeter so they are not to shabby.
iafzal is offline
post #1914 of 2750 Old 02-21-2012, 05:04 PM
Carpaccio's Avatar
I picked my 1021 up for $294.99 ($289.99 + $5.00 shipping) from Woot back in December.
post #1915 of 2750 Old 02-21-2012, 05:24 PM
harpo1's Avatar
Hopefully you don't have any issues where you need warranty work because woot isn't an authorized dealer.
harpo1 is offline
post #1916 of 2750 Old 02-21-2012, 05:52 PM
Five28's Avatar
Quoted: 49 Post(s)
Liked: 40
"Again, anyone have a center speaker reccomendation? Most of these are freaking huge and block some of the screen (my LCD's on it's stand not mounted)."
I just picked up a Definitive Technology ProCenter 1000 last week for $220. It's just under 15 inches wide and 5 inches high and 5 inches deep. It fits neatly above my BluRay player while still staying out of the TV screen's field of view. It's not quite broken in yet but it sounds great. I had trouble understanding some dialogue when I was running a pair of Def tech ProCinema 800 speakers but after adding this center channel I can hear everything. I am very pleased with this center channel, and all of the Def tech products that I have purchased.
Five28 is offline
post #1917 of 2750 Old 02-21-2012, 10:17 PM
Carpaccio's Avatar
Mine has a two year warranty as I purchased it with a Costco American Express.
post #1918 of 2750 Old 02-21-2012, 11:07 PM
Vdawgs22's Avatar
Few questions.. i've fun the mcacc test a few times but i'm still trying to tweak my audio settings... I'll start by saying i'm not using a subwoofer. I have 5 speaker setup. Typically I listen to music with just the front 2 channels which are jbl 180's. I like some bass I have setting for large speaker, but i can't seem to get the highs and treble i want. It also doesn't allow me to adjust bass and treble specifically in audio paramaters.
I also have the iphone app to adjust the equalizer but i'm not sure which levels adjust what!
any opinions for optimal settings for loud volume house/techno music would be appreciated! Stream Direct? Auto Surround? etc etc....Thanks!
Vdawgs22 is offline
post #1919 of 2750 Old 02-22-2012, 05:52 AM
robertw11's Avatar
Quoted: 74 Post(s)
I decided to go with a cheapo fan http://www.amazon.com/gp/aw/d/B00080...=10ML8QKXH1L5D since I wasn't sure if the receiver would power a fan to begin with, I just need a fan to pull the hot air out the back of my stand. It comes in Friday, I will post my findings.
Kuro'd
post #1920 of 2750 Old 02-22-2012, 05:55 AM
robertw11's Avatar
Quoted: 74 Post(s)
I generally keep everything on stream direct (still uses mcacc settings), and for music from my ipod I use advanced surround - ext. stereo.
Kuro'd
Pioneer , Pioneer Vsx 1021 K 7 1 Home Theater Receiver , Receivers Amplifiers
