Pioneer VSX-1021 Owners' Thread - Page 65 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
Old 02-22-2012, 07:17 AM
Undrpsi's Avatar
Originally Posted by Carpaccio View Post
Mine has a two year warranty as I purchased it with a Costco American Express.
Paid extra for the New Egg 3 year 'no worries' replacement warranty...was $59 extra. I also use AMEX for any electronic purchases for the extra year warranty.
Still paid $150 less than BB for a NIB 1021 without 3 years coverage...just saying...
Jay
Undrpsi is offline
Old 02-22-2012, 07:25 AM
Undrpsi's Avatar
Five28
Ok..I put Definitive Technology ProCenter 1000 on my list. It's only 5.2" high versus the Pioneer's 7.9"....but I didn't like the look of it online. Local stereo shop has them...will try to get out there this weekend. You're right this is more in line with what I am looking for as far as size.
Anyone using JBL Cinema Sound Series CSC56 ? This slightly taller than Five28's suggestion but only 4" deep. How does it sound? Looks (online) to be shiny black..which matches the stand on my Sony....not that asthetics are dominant but it would blend in more.
Any info would be appreciated.
Jay
Undrpsi is offline
Old 02-22-2012, 10:59 AM
filmgene's Avatar
Just for comparison, I use the Polk Blackstone 250 5.1 set-up with a Polk 10" woofer and set it to auto for everything except stereo music (classical and pop) which I set to extended stereo. Admittedly not a high end system, but I get spectacular results which is confirmed by everyone who has heard it. I use the iPad Pioneer controller and used MCAAC to set it up.
filmgene is offline
Old 02-22-2012, 12:50 PM
Scrondar's Avatar
So, this may sound like a silly question, but what settings would you folks recommend for this receiver connected only to two large front speakers (Polk towers)? That's all I have right now, so I want to get the best stereo sound from them I can with CDs and DVDs (no BD yet either). Right now they (or my bookies on Speaker B) just don't sound right, so I'm wondering is some default setting in the receiver is affecting the audio. BTW, all surround channels have been set to "NO." Thanks for any help you can lend.
Scrondar is offline
Old 02-22-2012, 01:52 PM
Vdawgs22's Avatar
Originally Posted by robertw11 View Post
I generally keep everything on stream direct (still uses mcacc settings), and for music from my ipod I use advanced surround - ext. stereo.
How bout normal tv watching? I've kept auto sound receiver on ...thoughts? And at night alc Dolby digital
Vdawgs22 is offline
Old 02-22-2012, 02:51 PM
ChronoMATT's Avatar
Thanks for the response. I have given up on this issue. I am going to get a $13.00 Y adapter from monoprice.com, run it off my cable box and switch back and forth between a TV and 1021 connection.
Maybe I'm strange, but I personally like surfing basic TV, watching news, talk shows, etc. without disturbing the household using my TV speakers and view select prime TV shows and DVDs that deserve the "big sound" through the 1021.
Originally Posted by Undrpsi View Post
ChronoMATT,
EXACTLY same here. I also tried everything and the closest I got to HDMI pass-through was EXACTLY the same as you...power off the rcvr and you get the TV saying "Switching Audio to internal spkrs" and then you get 1-3 seconds of it working..then.....LOS (loss of signal)...
ChronoMATT is offline
Old 02-22-2012, 03:22 PM
amfca's Avatar
Originally Posted by apaulct View Post
Run AutoMCACC but select "Keep SP System" in place of "ALL".
Thanks. I'll give that a try.
amfca is offline
Old 02-22-2012, 07:01 PM
tek55's Avatar
I hope someone can help me with this.
I am having a problem with my 1021 K, I am on #2 now as the first had problems.
youtube . com / watch ?v=b7YuOkGuPjI
youtube . com / watch ?v=94vK6sjjGuM
My VSX 1021K keeps sending a video reset signal, as you will see in the videos.
It annoys me to no avail and #2 seems to be doing the same that #1 did before I exchanged it at Costco.
I am at the point of giving up and going with another receiver altogether, is this a common problem and is there a solution?
Any assistance is appreciated tremendously, I am SO tired of seeing that black screen reset multiple times while trying to watch as it is so random and sometimes pops up at the most inopportune times when action movies get good.
By the way, sorry for the space in the link but apparently spammers have made it hard to send legitimate links .
tek55 is offline
Old 02-23-2012, 05:24 AM
Undrpsi's Avatar
ChronoMATT,
Nope you're not strange...I even use old school headphones a lot to keep from waking up the family. I usually watch TV without firing up the AV...do I really need 7.1 channel audio to listen to the news? Not usually....
Jay
Undrpsi is offline
Old 02-23-2012, 06:19 AM
mpsuda's Avatar
My unit is less than 30 days old. I have a problem if I turn the receiver off with ALC auto level control left on. When I turn it back on I get a pop through the speakers and then little sound. Each time I switch listening modes (standard, ADV SURR, AUTO etc) I here a pop through the speakers. If I switch to something other than ALC and turn the receiver off and on it is fine.
Do other units shutdown and startup OK with ALC left on?
Mike
mpsuda is offline
Old 02-23-2012, 10:50 AM
Undrpsi's Avatar
Anyone used Pioneer Elite TZ-MC09 Center Channel speaker?
This meets my height requirement for a center speaker....Any input?
Jay
Undrpsi is offline
Old 02-23-2012, 11:34 AM
mpsuda's Avatar
I called Pioneer and they said the firmware update should have fixed that. My unit had the dot on the box indicating the firmware was updated. I used AVNavigator to check-update my firmware. It said the receiver firmware needed to be updated. I downloaded it and put it on a USB flash drive and proceeded to update it. While going through the process the receiver told me my firmware was current and did not need an update. The tech thought that some how the firmware update "didn't take". He suggested I send it back.
I sent it back to NewEgg. I am going to fight them to pay the return shipping on a defective item. Even though there policy says they are not responsible.
I should have pressed the tech to see if there is a way to force an overwrite of the firmware even though it shows current. Maybe I should have taken it to a local authorized repair facility to see if they could have reloaded the firmware. I was however getting close to my 30 day return limit though.
Mike
mpsuda is offline
Old 02-23-2012, 12:43 PM
stevman17's Avatar
Question:
I am using my Pioneer VSX-1021-K with my PC, hooked up to an AMD HD6950 gpu via HDMI. I have video conversion off.
6950--->(HDMI)--->VSX-1021-K --->(HMDI)---->Monitor.
My problem is that when I startup my computer, the screen doesn't show an image until windows boots up. So, I am not able to access my BIOS.
Is there a setting I can change so that the video is always being seen? Or, should I just output audio via motherboard toslink, and send the video right to screen? If the latter, will I be losing anything? (I am running a 5.1 system for now)
stevman17 is offline
Old 02-23-2012, 12:52 PM
stevman17's Avatar
I would make sure that the crossover is off and that the speakers are set to large so that you are getting a full range of sound. Otherwise, the basic stereo setting should be fine.
Old 02-23-2012, 02:59 PM
weeber24's Avatar
Quoted: 49 Post(s)
Liked: 43
Originally Posted by stevman17 View Post
Question:
I'm doing the same thing, and have the same problem. As far as I know, the problem is due to the fact that the BIOS screen resolution likely doesn't match HDMI specifications. It's not until Windows loads and pops over to 1920x1080 resolution (or whatever) that the HDMI port starts to work. I'm using a NVIDIA GT430, BTW.
You can use the Toslink if you want, but you won't get the HD multi-channel sound. You'll be limited to dolby digital/DTS or uncompressed 2-channel PCM.
In my setup, if I just use the HDMI connection, the video card freaks out when the AVR switches input or is turned off (it doesn't think the monitor is connected any longer) and this causes problems with my HTPC software (SageTV). This is an EDID problem you can read about in the HTPC forum. You may or may not see the same problem. Here's what I do:
I have an HDMI cable connecting my GT430 to the 1021K and another HDMI connected from the 1021k output to HDMI1 on my TV. This is the primary cable that all sound and video runs through.
I then have a second connection using a DVI---->HDMI cable connecting my video card to HDMI2 on the TV. I don't use this connection to view any video. However, I set my video card to clone the display over the DVI port. When the receiver switches inputs or turns off, it has the DVI connection to fall back to and my video card doesn't flip out. If necessary, I can switch to HDMI2 on the TV to access the BIOS.
weeber24 is offline
Old 02-23-2012, 03:10 PM
Kolenka's Avatar
Quoted: 53 Post(s)
Liked: 66
I'll second stevman17's comments. I'm using this receiver with two Polk RTi4s and a CSi3 for a 3.0 apartment setup. Speakers really need to be set to large without any crossover or you will lose all your bass.
I might recommend going through the MCACC setup process if you haven't already since it seems to do a good job catching setup glitches and seemed to make the response a little flatter like it should be. It also detected the lack of a subwoofer and made sure all my speakers were set to large by default.
It does sound different than my Sony STR-DH800 I had before, but not in a bad way.
Sony 55HX929, Marantz 5010, Polk LSiM 703/704.
Kolenka is offline
Old 02-23-2012, 03:46 PM
robertw11's Avatar
Quoted: 70 Post(s)
Liked: 27
Normal tv as in cable? I just leave it on auto. I don't really care how cable television sounds or looks.
Kuro'd
robertw11 is offline
Old 02-23-2012, 04:10 PM
Scrondar's Avatar
Speakers are set to large, but I left the crossover where it was in setup, as I did not really understand its use (and only do slightly more now ). This receiver is replacing a fairly older one that sounded good right out of the box, but was an early 5.1 model with no video functions, so I imagine things have changed enough in that time that I am about as clueless as an owner can be. Thanks.
Yes, I have yet to run the MCACC (which was the first thing Pioneer tech support suggested), as I've been so busy since I got the unit. Will check these settings tonight. Thanks.
Scrondar is offline
Old 02-23-2012, 04:33 PM
stevman17's Avatar
Awesome, thanks man. Hopefully I can do the same thing with my hd6950
Old 02-23-2012, 08:35 PM
BirdRider's Avatar
Well I just bit the bullet on one of these. Got It on newegg for 350 + 60 for the extended warranty. Now I just need to build my Overnight Sensations and rock out.
BirdRider is offline
Old 02-24-2012, 03:09 AM
the rambob's Avatar
THe monoprice HDMI splitters were mentioned yesterday as a alternative for watching TV w/o using the receiver. I looked over their site and saw in the reviews (on the powered one i was looking at) that the signal/audio level will go to the lowest level to both the tv and receiver: so if your TV doesnt do 5.1 it wont pass 5.1 to you receiver?? Anybody have a spin on their products?
the rambob is offline
Old 02-24-2012, 07:32 AM
moxie1617's Avatar
If it were an HDMI splitter then it would receive the EDID data from the TV that it only supports stereo and your source would always send stereo. If it is a switch, then the TV shouldn't be communicating with the source if it is switched to the AVR and you would get your full multichannel audio. Make sure you pick a switch, not a splitter.
moxie1617 is offline
Old 02-24-2012, 01:17 PM
Upgrader's Avatar
Quoted: 38 Post(s)
I decided to go with a cheapo fan http://www.amazon.com/gp/aw/d/B00080...=10ML8QKXH1L5D since I wasn't sure if the receiver would power a fan to begin with, I just need a fan to pull the hot air out the back of my stand. It comes in Friday, I will post my findings.
I just got mine. It's the coolerguys version you had linked from amazon (for $16.90 delivered) and yes it works when plugged into the receiver's USB. I can't hear it from more than 3 feet away and it moves 44 cfm of air per fan. I actually bought 2 of them and the receiver is now ice cold. However, on the Onkyo receivers the USB ports seem to be always powered so I physically need to unplug the fans when I am done watching because they don't power down when the receiver is put on stand-by. This is a hustle though, an inconvenience.
So I just placed an order for a USB hub with a switch (this one):
http://www.amazon.com/Gear-Head-4-Po...0114884&sr=8-2
The goal is to keep the fans always plugged in but use the switch each time I turn the receiver on/off so that I can turn the fans on/off without unplugging them.
Upgrader is offline
Old 02-24-2012, 06:49 PM
Vdawgs22's Avatar
previously i've had my sony nx720 and my pioneer working together flawlessly.. the tv would stay on sat/bedroom and produce sound via hdmi to reciever.. and when i went to pandora on tv it would change reciever to sat/tv and use the optical out from tv to produce audio... now after 2 weeks i'm not getting any any audio to the pioneer via optical... not sure if it is the tv or the reciever... any ideas?
Vdawgs22 is offline
Old 02-24-2012, 06:51 PM
harpo1's Avatar
Originally Posted by harpo1 View Post
Well I've had my 1021 for 2 1/2 months and today I went to turn it on and nothing. I unplugged it then plugged it back in and still nothing. A couple times in the past it would just shut itself off for no apparent reason but it would power back up . I guess the power supply took a dump. Anyone know what pioneer does if I don't have a service center near my location?
Well I got word back from the authorized service center today that the digital main board was bad and the part is on order from Pioneer. Hopefully they get it in next week so I can be back in business. I hope no more issues after this.
harpo1 is offline
Old 02-24-2012, 10:22 PM
Setzer's Avatar
Quoted: 27 Post(s)
Liked: 29
I just got this receiver a couple of weeks ago from Newegg when they had their sale on it. Loving it so far. Having one problem though and I don't really know if its even a problem. I can stream music from Windows Media Player and iTunes to my receiver when its set to the HMG input. The problem I'm having is when I switch to the HMG input it connects to the server and then displays a list of folders(Internet Radio, my server, etc.) but I can't select any of the folders. The directional pad on the remote won't work. Actually nothing works on the remote except for the change input buttons. Is this normal? Am I not suppose to be able to select any of those folders?
Setzer is offline
Old 02-24-2012, 10:51 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi Setzer, did you put in it "Receiver Operation Mode" first by pressing the "Receiver" button? If not try that before using other function buttons.
JChin is offline
Old 02-24-2012, 11:23 PM
Setzer's Avatar
Quoted: 27 Post(s)
Liked: 29
Wow, I'm an idiot. I didn't even think of that. I pressed the HMG button on the remote and it works now. Thanks a bunch!
Setzer is offline
Old 02-25-2012, 11:36 AM
Five28's Avatar
Quoted: 47 Post(s)
Liked: 37
A easy way to determine whether an optical output is working is to simply unplug the optical cable from the input side (your receiver in this case) while the TV is playing Pandora and looking at the end of the cable to see if it's lit up with red light. If so, then you have an optical signal coming from the TV so the problem has something to do with the receiver.
BenQ W1070 front projector, Definitive Technology BP2002 towers, Def Tech CLR2002 center, Def Tech BP2X surrounds, Def Tech PF15 subwoofer, Denon AVR3300 receiver, Panasonic Blu-Ray player, Apple TV, Roku device, Monoprice HDMI switcher
Five28 is offline
Old 02-25-2012, 12:33 PM
gpost's Avatar
Problems with HMG
Has anyone had problems just getting HMG to start? I have my VSX-1021-K hooked up to my network via Ethernet and have verified that it has a good IP address and that the iPad app is able to control it with no issues, so I know it's on the network properly. However, when I switch to the HMG input, the iPad app and my TV display both say "Starting H.M.G. Please wait." No matter how long I wait, I'm stuck on this screen.
Any ideas how I can troubleshoot this?
Thanks in advance.
gpost is offline
Pioneer , Pioneer Vsx 1021 K 7 1 Home Theater Receiver , Receivers Amplifiers
