Pioneer VSX-1021 Owners' Thread - Page 90 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #2671 of 2750 Old 05-12-2014, 07:27 PM
mg09383's Avatar
Can't get out of Multi-Zone Mode on the remote
I think my kids pressed a button by mistake and now the remote is incapable of doing anything other than adjusting Zone 2 (I don't have a Zone 2).  I consulted the manual and I can press the Multi-Zone button on the front of the receiver and turn off Zone 2 and adjust the volume, inputs etc from the front panel but the moment I try to use the remote it's back to Zone 2/Multi-Zone operation.
I can't find how to toggle this off.  Any help would be much appreciated.
Thank you,
Mark
I believe I've encountered this before but can't find the solution this time.
mg09383 is offline
post #2672 of 2750 Old 05-15-2014, 10:59 AM
mg09383's Avatar
I believe the solution is the Receiver button although I was pushing the Source, Multi-Zone and Power buttons when the problem resolved itself.  I can use my remote again!
Receiver - Switches the remote to control the receiver (used to select the white commands).Switch to perform operations in the main zone. Also use this button to set up surround sound.
mg09383 is offline
post #2673 of 2750 Old 05-20-2014, 05:01 AM
TreyS's Avatar
A friend of mine has the 1021 and it has no sound. I get over there and there is a UE33 code. I read here that its trying to update so I get a flash drive, load the latest firmware start the update and it fails at 20%. I then run a cat-5 cable from the router, across the floor, to the 1021 and plug it in and try again. Same deal, fails at 20%. Any suggestions?
TreyS is offline
post #2674 of 2750 Old 05-22-2014, 04:52 PM
mountainbike2001's Avatar
Zone 2 issues!!! Speakers working but only with TUNER output at a low volume. No other devices work at all. Can't be speakers??
Thanks !!!!
mountainbike2001 is offline
post #2675 of 2750 Old 06-10-2014, 12:04 PM
rsoares28's Avatar
Quoted: 118 Post(s)
Liked: 27
Hello, I had this receiver for over 2yrs and now out the blue airplay has stopped working. I can still see my receiver as an airplay devices and connect to it but it only plays for 10 secs until it drops the connection. 10 secs on the dot.... every time.
I have 4 other airplay devices on my network and they all work flawless. I called pioneer and they advised I have to send it in. The funny thing is I live about 15 mins from the pioneer head office but they don't accept drop offs... I have to take the receiver to a depot about 45 mins from me and they in turn will send it to pioneer. Common Sense aint too common.
Anybody having similar issues?
rsoares28 is offline
post #2676 of 2750 Old 07-18-2014, 01:52 PM
Liked: 0
Greetings,
My VSX-1021-k cannot reach the home network / internet anymore. I went into the settings and it gets to "Applying network settings" and will go no further.
I have reset the unit per the manual instructions and I know it resets as my demo mode returns. Unfortunately network settings still show the same message.
Has anybody experienced this and know how to resolve it please?
Cheers.
MichloIW is offline
post #2677 of 2750 Old 07-19-2014, 01:19 PM
Liked: 0
Applying Network Settings
Mine just started doing this yesterday too. Very coincidental. Any luck on your end? Do you use DHCP or a static IP address?
Originally Posted by MichloIW View Post
Greetings,
Cheers.
Tisun22 is offline
post #2678 of 2750 Old 07-21-2014, 01:05 PM
robertw11's Avatar
Quoted: 74 Post(s)
Thread from the dead.
A few quick question, hopefully quick, regarding video processing.
1. Using a htpc, better to have video processing turned on, or off?
2. Gaming, video processing on or off?
3. Cable box, processing on, or off?
4. What exactly is video processing do when it's on vs off? lol Seems like a silly question, but what I mean what are the benefits to having processing on over off?
Thanks guys, hopefully someone's still around to help me get some answers.
Kuro'd
robertw11 is offline
post #2679 of 2750 Old 07-22-2014, 09:16 AM
rdclark's Avatar
Quoted: 348 Post(s)
Liked: 651
You only care about video processing when you're upscaling a source that doesn't have its own video processing -- which, these days, is almost nothing.
Basically, if you're sending an HD signal from the source, keep the Pioneer's video processing turned off. (It's not very good anyway.)
If you're sending an SD signal from a source that doesn't itself upscale and process it, then it might benefit from the Pioneer's processing. But these days, even your TV probably has good enough upscaling built right in.
Wide Awake
on the Edge
of the World
rdclark is offline
post #2680 of 2750 Old 07-23-2014, 01:08 AM
dbbd's Avatar
I leave the video processing on all the time. It does not damage HD content. It works pretty well on SD content (and our public TV broadcast is SD or even less).
Dan
dbbd is offline
post #2681 of 2750 Old 08-11-2014, 12:40 PM
Liked: 0
Unable to connect to network
I'm having the same problem. Used to work great as a Airplay device. Couldn't connect, so I checked Ethernet connections, no problem. The receiver was reporting a local IP address (not on my subnet), so I toggled DHCP on and off. It is now stuck in a dialog from A/V receiver that saying "Applying Settings". This conditions survives turning the receiver on and off. The receiver gets stuck "STARTING H.M.G Please Wait..." on power up, and if you go to the Home Menu Network Information is greyed out. Going to Network Setup and selecting IP Address, Proxy returns to the afore-mentioned dialog box.
Amazingly coincidental that others are having the same problem in such a time bound window?
sircoolio is offline
post #2682 of 2750 Old 08-30-2014, 06:00 PM
Utendar's Avatar
My receiver has been working ok for 2 years. Just today however the receiver powers up as normal and I have no sounds coming out of the speakers. The sub output seems fine since I can play a BD and scenes with a lot of LFE and I can hear the effects from the powered-sub.
Is the amp section gone on the receiver? I tried different inputs (cable box, game systems, BD, Airplay, etc.) and all the same problem.
Utendar is offline
post #2683 of 2750 Old 10-04-2014, 09:23 AM
dgeary's Avatar
Liked: 0
VSX-1021 - No sound at all
I have no sound coming from this receiver in any way. I didn't change anything, and the only way anyone in my house accesses the receiver is through iPad or iPhone (its buried in the basement). Here is what I have tested so far: Tested speaker buttons, surround modes using various sources including iPad plugged into front USB, Airplay, working DVD plugged into various inputs in the back, zone 2 pre-amp out goes to a second receiver on a different floor and even that doesn't work.
I can hear the amp switching inside as I cycle through the modes, and when the iPad is plugged into the front the song playing displays on the screen. the iPhone app appears to be working as normal, Airplay finds the receiver... just no sound from anywhere. I have done a reset.
I went as far as opening up the amp and looking for signs (and smells) of burn out (none) and tested the two fuses. I cut a new piece of speaker wire and tested with a local speaker. Nothing. Nada. Zip.
I hope I have missed something dumb, easy or hard, and that it's not repair depot time.. any clues?
Thanks for your help.
dgeary is offline
post #2684 of 2750 Old 10-04-2014, 09:25 AM
dgeary's Avatar
Liked: 0
Were you able to solve this? It sounds like I am experiencing the same issue as you, except I don't hear anything out of my sub, or any of the other pre-amp outputs.
dgeary is offline
post #2685 of 2750 Old 10-12-2014, 07:48 AM
Ryan02Stang's Avatar
Same thing happened to mine like you guys are experiencing. I replaced it with another brand and swore off Pioneer.
Ryan02Stang is offline
post #2686 of 2750 Old 10-13-2014, 06:03 AM
Doug Schiller's Avatar
I'm getting worried. I'm probably close to 2 years on this receiver.
If I may ask, which brand and model did you decide on?
I really love my Pioneer, especially the features. Is there something similar in that price range?
Doug Schiller is offline
post #2687 of 2750 Old 10-28-2014, 01:42 PM
MameJunkie's Avatar
Quoted: 31 Post(s)
For those with the UE-22 error. What did you end up doing?
Tried the various recommendations but it didn't help.
Contemplating between getting it repair VS. just getting a new one (non-pioneer).
MameJunkie is offline
post #2688 of 2750 Old 10-29-2014, 12:16 PM
rsoares28's Avatar
Quoted: 118 Post(s)
Liked: 27
Glad I checked this forum, my receiver has been having airplay issues for the past 3 months. I still see it as an airplay device and can select it, it will start up playing but stop 10 sec in to the song... No idea what could be wrong.. All my other airplay devices work fine
post #2689 of 2750 Old 11-01-2014, 10:27 PM
Iron Condor's Avatar
Mine is still dead, but I can't seem to bring myself to toss it in the trash. Is this thing worth anything as parts?
Iron Condor is offline
post #2690 of 2750 Old 11-02-2014, 06:15 PM
benmuss's Avatar
Looks like another junk Pioneer vsx-1021 here today with the ue22 error. I'll never buy another Pioneer product!
LForteleoni likes this.
benmuss is offline
post #2691 of 2750 Old 11-10-2014, 08:56 PM
PhatJD's Avatar
I'm also having an issue with zone 2. It stopped working about a month ago. It will turn on with the remote and I'm able to change inputs. However the master volume does not work and I have no sound coming out of my zone 2 speakers. Is there another setting that may have been changed i'm not thinking of?
Everything works fine with the receiver outside of this zone 2 issue.
Thanks...
PhatJD is offline
post #2692 of 2750 Old 11-11-2014, 08:22 PM
jjg247's Avatar
So I am having an issue with a Klipsch sub and the 1021. Auto MCACC recognizes the sub and I can hear bass coming from the unit during the test. However, as soon as I try another source nothing is coming from the sub. I tried changing the front speaker settings to 'small' but that didn't fix it. Any ideas?
Sub is hooked up via digital coaxial cable if that matters.
jjg247 is offline
post #2693 of 2750 Old 11-14-2014, 06:14 AM
LForteleoni's Avatar
Originally Posted by rmars View Post
...I have to hold the power button to restart... Any suggestions?
Sell, sell, sell! I really wanted to love my 1021K, (and I did love it for exactly 2.5 years) but when I started having the same exact issue, I moved on to Yamaha and I am very happy.
The truth is, Pioneer should be fixing these for free. Apparently they're not interested in long-term customer relationships.
Sadly, you'll get pennies for parts for this ****box – just look on eBay. I have heard of people getting these things fixed for a reasonable fee. Apparently the faulty part isn't really that expensive, (ahem, Pioneer) and replacement doesn't require a MSECE.
Good luck
Referencing this thread:
Pioneer VSX-521-k / 821-k / 921-k / 1021-k - Power-On problems?
Credit: thx1138a
AVR: Yamaha RX-A840FL/R: Os3-SATCC: Os3-CCSUR: Mirage NanoSatSUB: Mirage Omni S8DISP: Samsung F5300
LForteleoni is offline
post #2694 of 2750 Old 11-20-2014, 11:28 PM
fsafadi's Avatar
The only way I know how to emphasize center channel for voice is to use the app on the iPad. the next time I start the receiver the voice is back to low and I have to use the app again.
How can I save the setting so it is always the same for Action movie.
fsafadi is offline
post #2695 of 2750 Old 11-23-2014, 10:35 AM
Liked: 0
Anyone have success with DLNA Renderer functions?
I am able to play a track from my PC (with Mediamonkey as the controller) to the VSX as the renderer, however, no other functions work (pause, next track, etc) on the controller. Also, when the song ends, I have to manually play the next song on the controller. I believe it is an issue with the VSX, because I am able to use my Xbox One as a renderer with full control in the same setup.
debar is offline
post #2696 of 2750 Old 11-30-2014, 08:52 PM
snarshad's Avatar
Also having center channel problems
I'm having the exact same problem with the center channel. (Except the sock trick isn't working) @turnpike 17 - any luck figuring this out?
Originally Posted by turnpike17@aol.c View Post
Hi Guys,
My 1021 for the most part has been great. However, for over a year now, while watching any program or movie in 5.1 surround, sometimes the center channel will go out and all you'll hear are the surrounds. The lightest touch on the receiver will get it working again. I could throw a sock at the receiver and the center channel will start working again. There is no rhyme or reason on when it does it, as sometime we can get through several movies before it does it, or sometimes it will do it constantly throughout one movie.
Switching to Stereo completely fixes the problem, as obviously the center channel isn't used.
Anyone have any suggestions? Thank you in advance!
snarshad is offline
post #2697 of 2750 Old 12-06-2014, 10:43 AM
bob886's Avatar
Liked: 0
Most of these amps / receivers have speaker protection relays that delay the application of the signal until after any transients have settled. This is important when the unit is turned on and the power supply is applied to the output amp. This can be a 30 - 60 volt spike which could damage the speakers.
The disadvantage of this is that relay contacts get dirty. Bumping the receiver can make a poor contact good because it ever so slightly jostles the contact on the relay. The cure is to remove the covers on the relays and clean the contacts, or replace the relay.
bob886 is offline
post #2698 of 2750 Old 01-08-2015, 03:04 PM
Mark Oliver's Avatar
Quoted: 71 Post(s)
I had this receiver since the week it was released and for the most part it worked well.
I finally got rid of it today for the following reasons.
1) the new AVControl app is the worse user interface I have ever used. It's worse than windows 3.1 and shows what happens when you let some designer go pseudomorphic design overboard. Everything is random, makes no sense, shifts locations, overly animated etc. Just a really horrible horrible design. The older version worked much better and easier and I stuck to it but on iOS8 much of it crashes.
2) I had MAJOR HDMI Control handshake issues with my new XBR Sony TV. It would control some things and not others. The ARC would also randomly work or not. I spent about 5 hours fiddling with everything I could before finally giving up.
3) The built in GUI for the receiver is horrible. Looks like its from the early 90's and the options are highly confusing.
4) Airplay didn't work for MONTHS until Pioneer finally upgraded the firmware.
Anyway, got a Sony Receiver instead and it has non of the above issues.
God speed everyone.
Mark Oliver is offline
post #2699 of 2750 Old 01-19-2015, 06:18 PM
thisgsx's Avatar
Quoted: 75 Post(s)
Liked: 32
I need help! Subwoofer isn't working. I've checked settings multiple times. Speakers set to small, sub is yes, crossover at 80hz, etc..etc... when I run MCACC or when I go into level calibration, it detects the sub and adjusts accordingly to the level I adjust to or when MCACC is setting up, it detects my sub and you can hear thump for the testing. I am completely out of ideas. Source material doesn't matter, cable, bluray, cd, etc... no sub. The subwoofer works fine, hooked it up to my living room setup and it powers on and works fine. I am noticing that the subwoofer icon isn't displayed on the receiver's screen. I've also switched listening modes, and no matter which listening mode I switch to, nothing. So what the heck is wrong???
Receiver: Pioneer VSX-1021-K
thisgsx is offline
post #2700 of 2750 Old 01-20-2015, 07:34 PM
SoCalJake's Avatar
Zone 2 wattage and pre-outs
Sooo, I'm prepping to use zone 2 to run patio speakers that are in ceiling. I intended to run them off the speaker level terminals and then to run a sub off the pre-outs. Like all my plans, a few things have popped up.
Mainly, is there a distance the line level pre-outs for zone 2 should not exceed? Since I need to run the wire, what should I run? It's about a 35 linear feet run to the sub location, as the wire runs. Sub is powered BTW.
Next, will the zone 2 pre-out volume adjust with the speakers or is it fixed? This may foil my plans some if it's fixed.
I just found out I can AirPlay to both zones after years of not knowing it. Who knew. I still love this 1021.
Thanks in advance.
SoCalJake is offline
Pioneer , Pioneer Vsx 1021 K 7 1 Home Theater Receiver , Receivers Amplifiers
