Pioneer VSX-1021 Owners' Thread - Page 91 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #2701 of 2750 Old 02-13-2015, 05:01 PM
Liked: 0
PC Stream to Amp - No Itunes
Hi guys,
have been trying everything to work out how to stream from my windows PC to my 1021vsx without using my itunes airplay. I am connect wirelessly and Ethernet cable to my amp and it shows in my network folders. However i want to be able to play online music / personal music with using itunes.
I find it easier to find internet radio stations on my PC than i do the tuner, as well as i dont want to always relay on my iphone to play music to the amp (which we always do) as sometimes it drops out.
we are having a party tonight and i want to make sure the music is seamless without drop out etc, this can be acheived by PC directly to amp.
any help greatly appreciated.
Cheers
JB
Jaybee750 is offline
post #2702 of 2750 Old 02-13-2015, 05:10 PM
Liked: 0
sorry guys typing to quickly. Do not want to use Itunes. I can stream over my PC to amp using Itunes airplay, however cannot stream things like pandora from PC to amp without using iphone.
hope this makes sense.
post #2703 of 2750 Old 02-13-2015, 05:12 PM
Deihmos's Avatar
Quoted: 46 Post(s)
You cannot stream something from a web browser to the receiver.
Edit. This actually worked in win 8.1 using the IE modern app.
Deihmos is offline
post #2704 of 2750 Old 03-09-2015, 04:32 PM
Liked: 1
Hi,
My VSX1021-K has been working well for years. Recently it has been stalling out at 1-2 minutes when playing internet radio. I've ordered a new network cable to eliminate that possibility but I'm pretty sure that's not the problem. It plays a station fine for a minute or two and then stops. The buffer indicator on screen goes from 100 to 30 and the it hangs. I can reload the station and the same thing happens. I use it on Zone 2 RCA out to an FM transmitter for radio (which I can change stations from anywhere with my phone) throughout the house. I kind of miss having it. Anyone else encountered this?
dgerst is offline
post #2705 of 2750 Old 03-22-2015, 03:32 PM
texraider's Avatar
Originally Posted by thisgsx View Post
I need help! Subwoofer isn't working. I've checked settings multiple times. Speakers set to small, sub is yes, crossover at 80hz, etc..etc... when I run MCACC or when I go into level calibration, it detects the sub and adjusts accordingly to the level I adjust to or when MCACC is setting up, it detects my sub and you can hear thump for the testing. I am completely out of ideas. Source material doesn't matter, cable, bluray, cd, etc... no sub. The subwoofer works fine, hooked it up to my living room setup and it powers on and works fine. I am noticing that the subwoofer icon isn't displayed on the receiver's screen. I've also switched listening modes, and no matter which listening mode I switch to, nothing. So what the heck is wrong???
Receiver: Pioneer VSX-1021-K
I know this is months late, and you've probably figured it out already, but set your sub to "Plus" and see if that helps.
texraider is offline
post #2706 of 2750 Old 03-30-2015, 11:28 AM
Liked: 0
Vsx-1021
Okay so I finally came out of the dark ages and mounted my TV on the wall. Somehow now when a AppleTV 4 outputs in stereo the 1021 only plays the .1 sub and not the 5ch!? I'm thoroughly confused. Any insights?
HDMI 1 set to AppleTV with HDMI control on
TV/SAT running from LG TV plays OTA broadcasts 5.1 whether or not source audio is stereo or 5.1 digital.
Shakypuddin is offline
post #2707 of 2750 Old 04-02-2015, 03:43 PM
thisgsx's Avatar
Quoted: 75 Post(s)
Liked: 32
Never figured it out. I've tried everything and this POS won't output the sub. I've since given up and I am saving up for a better receiver.
thisgsx is online now
post #2708 of 2750 Old 04-05-2015, 07:01 AM
Doug Schiller's Avatar
Well, the day finally came and mine died (I think).
My wife wanted to redo the floors so I had to unhook everything.
After an hour of hooking everything up I turn on to do the speaker test.
Everything is going good but the right rear extra surround is not making a sound.
I go back to look at the wires and my UPS must have tripped because I moved something.
Try turning on and hear some pops, then it shuts off.
Now when I plug it in, the red MDACC light just blinks, nothing else.
Tried almost every combo in the book to reset but to no avail.
I think it is toast.
Am I crazy to want to replace it with the VSX-1024?
Other then it not lasting as long as I expected it to, I loved the receiver.
Doug Schiller is offline
post #2709 of 2750 Old 04-09-2015, 11:04 AM
Liked: 1
I finally figured it out. My router was dying. I replaced it and all is well. Receiver works perfectly now. It was only stalling on live streams, not on podcasts which is what led me to believe it wasn't a network problem. It was. I know many have had issues with this receiver but my experience has been good. And I've had it since they first came out. Anyway, if you're having internet radio problems try another router.
Originally Posted by dgerst View Post
Hi,
dgerst is offline
post #2710 of 2750 Old 04-10-2015, 01:49 PM
Liked: 0
Screen Flash (frequent loss of picture)
Hi Folks,
Hoping someone has come across a fix for my issue.
I've had my vsx-1021-k for 3.5 years so far and it's been working great. Recently, however it has started doing something very annoying. While watching anything on the TV the signal seems to cut out momentarily. Sometimes its just a quick flicker and other times there's no signal for maybe 0.5-0.75 seconds... just long enough that when the signal returns the TV shows the signal information (as if I've just plugged in the HDMI). Sometime this will happen like 10 times in a row and then it wont happen for hours.
I've replaced the HDMI cable, tried different inputs on the TV, and used different sources on the received. All have the same issue. What does not seem to have the same issue is if I have the home menu up or am using HMG.
Has anyone encountered this? Otherwise it's working fine but this is so annoying that I'm thinking about getting a new one.
qwicker is offline
post #2711 of 2750 Old 04-12-2015, 07:06 PM
nyguy4u's Avatar
Can a VSX-1021 support 4K?
So here is my thing - I love my VSX-1021. Currently have my 1080p video ran through it. With that said, I am purchasing a 4K TV. Will that render my 1021 useless? Can it support 4K pass through? Or do I need to buy an all new receiver?
nyguy4u is offline
post #2712 of 2750 Old 06-03-2015, 05:10 PM
matthorn's Avatar
I just purchased a HP Stream 200 to use as a HTPC. Everything seems to be working fine except I'm only getting PCM audio on my receiver. I'm connected using a HDMI cable, I've set my VSX-1021 to direct audio, and I've set up the HP Stream speakers as 5.1, so I'm at a loss as to what I need to do to get my files with DTS for example to output the full DTS audio and not just a PCM stream to the receiver.
Thanks in advance for your help.
matthorn is offline
post #2713 of 2750 Old 07-12-2015, 02:22 PM
Liked: 0
HDMI video + RCA audio?
Greetings,
I have an unique problem and I seek your help.
Trying to set up a karaoke machine for my in-laws. The Karaoke machine comes in 2 parts:
- a touch-screen monitor (basically a PC) with all the software. It has a HDMI output for video/audio.
- a mixer that takes RCA analog audio from the said monitor, and 2 MICs. It outputs (through RCA analog) the original songs + MICs
The machine is from asia. According to my in-laws, most people connect the touch-screen PC to a regular TV through HDMI for the video. They would mute the volume on the TV.
They will then connect the mixer to an audio speacker/receiver, and use the audio from there instead.
In my setup I have vsx-1021k connected to a projector through HDMI (inside the wall/ceiling). If I am to use the above methods, it either will be ugly or expensive.
My question is: does vsx-1021k has the ability to mix video/audio of difference source? That is, can I use the HDMI video input from the touch-screen PC and the analog audio from the mixer? According to post #24 of this very own thread it seems possible and I have not been able to achieve it.
any help is very much appreciated,
Elvis Chen is offline
post #2714 of 2750 Old 07-12-2015, 03:46 PM
JChin's Avatar
Quoted: 381 Post(s)
Liked: 210
Hi Elvis Chen, connect the touch-screen PC to HDMI (VIDEO-1) input and the analog audio to AUDIO (VIDEO-1) L/R inputs. Now on the remote press "Receiver" and then press "Signal Sel" button a few times to cycle it to "Analog".
JChin is offline
post #2715 of 2750 Old 07-24-2015, 06:18 PM
Liked: 0
Hi guys,
Just tried updating the unit via internet (4f5a.Update) and it stayed stuck at 20%, then gave me error message "Update error 1". I restarted the unit and it appeared to work correctly except that it does not emit any sound from any of the inputs (even iTunes sees it and connects to it successfully), neither from the speakers nor the headphone jack.
Troubleshoot steps I have taken so far are:
1. Resetting the unit to its factory settings.
2. Tried installing the update (1-205-081-111-089) via a USB key but it also gets stuck at 20%.
Alas, nothing will do
Any tips are welcome. Thanks in advance.
jeanpascal.beaudoin is offline
post #2716 of 2750 Old 08-01-2015, 06:54 AM
Liked: 0
Originally Posted by TreyS View Post
A friend of mine has the 1021 and it has no sound. I get over there and there is a UE33 code. I read here that its trying to update so I get a flash drive, load the latest firmware start the update and it fails at 20%. I then run a cat-5 cable from the router, across the floor, to the 1021 and plug it in and try again. Same deal, fails at 20%. Any suggestions?
TreyS, was your friend ever able to solve his update stuck at 20% problem?
I ran into exactly the same issue
post #2717 of 2750 Old 08-01-2015, 07:32 AM
TreyS's Avatar
Two friends with the same issue now. Both replaced their receivers. Panasonic support could not assist them.
TreyS is offline
post #2718 of 2750 Old 08-01-2015, 08:48 AM
mfeferman's Avatar
Mine also doesn't play any sound. I've done the same line of testing. Did you ever find a solution?
Originally Posted by dgeary View Post
I have no sound coming from this receiver in any way. I didn't change anything, and the only way anyone in my house accesses the receiver is through iPad or iPhone (its buried in the basement). Here is what I have tested so far: Tested speaker buttons, surround modes using various sources including iPad plugged into front USB, Airplay, working DVD plugged into various inputs in the back, zone 2 pre-amp out goes to a second receiver on a different floor and even that doesn't work.
I can hear the amp switching inside as I cycle through the modes, and when the iPad is plugged into the front the song playing displays on the screen. the iPhone app appears to be working as normal, Airplay finds the receiver... just no sound from anywhere. I have done a reset.
I went as far as opening up the amp and looking for signs (and smells) of burn out (none) and tested the two fuses. I cut a new piece of speaker wire and tested with a local speaker. Nothing. Nada. Zip.
I hope I have missed something dumb, easy or hard, and that it's not repair depot time.. any clues?
Thanks for your help.
mfeferman is offline
post #2719 of 2750 Old 08-12-2015, 01:25 PM
COMPUTIAC's Avatar
Hi Gent's,
I have this UE33 flashing out of the blue. It started 10 day's ago. I tried to do the update thru the onscreen UI, it start's to go and then stop's.
To be clear, I do have sound and the unit VSX-1021, appears to be working OK.
I bought this shortly after it came out in 2011 along with a 55LG6500 TV. One thing I did notice on the TV is, once in a while I get a black screen flash. Its super fast.
Is this flash related to the 1021 ?
I'm going to take a wild chance and try to do the update via USB. I did do this update once before when it was first released.
Has any one found a real fix for this ?
Is this the beginning of the end for this machine ?
COMPUTIAC is offline
post #2720 of 2750 Old 08-12-2015, 02:28 PM
COMPUTIAC's Avatar
Update to my post above.
I went here to download the latest firmware update: http://www.pioneerelectronics.com/PU...K?tab=firmware
It is # 1-205-081-111-089 which was Updated 07/28/2014
I found if the unit displays UE33, you can't update thru the UI thru the 'net.
If you read the changlog here: http://www.pioneerelectronics.com/ep...Y_FY12RegH.txt
It state's this:
Countermeasure against UE33 error (* If UE33 is displayed on FL display, network features become unavailable.)
I entered the update with a USB drive and this time it worked. No more flashing UE33.
Obviously I had an older update on the machine.
I will still watch to see if any problem's come back.
post #2721 of 2750 Old 08-16-2015, 11:05 AM
Liked: 0
Angry Menu button doesn't work
Hi, I have the UE33 flashing. I downloaded the firmware update but when I press the menu button on the remote nothing happens. Any suggestions? All the normal functions seem to work fine, just can't access the menu.
skibum458 is offline
post #2722 of 2750 Old 08-16-2015, 12:26 PM
COMPUTIAC's Avatar
Do you mean the "Home" button on the remote ?
Are you following the instruction's here : http://www.pioneerelectronics.com/ep...update_USB.pdf
post #2723 of 2750 Old 08-29-2015, 05:14 PM
xbsd's Avatar
I am writing because I finally got rid of the "applying settings" and "starting hmg" frozen screens and had the same plight that man here seem to be experiencing. My fix was simple - unplug the receiver physically from the back of the receiver for ~ 20 seconds and plugging it back in.
In my case, this happened whilst I was trying to debug a network issue. I went back to the network screen and it did say "applying settings", but this time it went away after some time and really did apply the settings. It seems that the screen ("applying settings" and "starting h.m.g) gets frozen if it is not able to reach the network.
xbsd is offline
post #2724 of 2750 Old 10-18-2015, 10:26 AM
Liked: 0
Pioneer VSX 1021 loses HMG selection - goes to Internet radio
The VSX1021 keeps changing from HMG to Internetradio with a few seconds.
So I am unable to send audio from my laptop or iPad to the Pioneer.
The latest firmware is installed.
Has this happened to anyone else?
Any solutions?
Ksynth is offline
post #2725 of 2750 Old 01-24-2016, 04:53 PM
bigshot82's Avatar
how to control volume using Appletv HDMI
appleTV gen 4
VSX-1021K with latest firmware
HDMI control on
Is there a way to control volume using HDMI (ATV remote Bluetooth instead of IR)? I like not having to point the ATV remote directly at the receiver in order to change volume
bigshot82 is offline
post #2726 of 2750 Old 01-29-2016, 08:06 PM
jab3384's Avatar
Not sure if anyone is still around, but are there any settings you need to change on my receiver? I just moved and can't use a wired connection anymore. I bought a wifi adapter (panda wireless USB), set it up with my laptop, but the receiver isn't recognizing it.
Any help would be much appreciated!
Jay
jab3384 is offline
post #2727 of 2750 Old 01-29-2016, 08:07 PM
jab3384's Avatar
Jay
jab3384 is offline
post #2728 of 2750 Old 02-17-2016, 03:26 PM
hcl1's Avatar
I have a VSX-1021. About 1 year after purchase, the network started to go out. At first, it would come and go - now the NETWORK INFORMATION option is grayed out in the UI. When I go to SYSTEM SETUP - OTHER SETUP, Software Setup is also grayed out. So, no way I can update the software, even through USB. I tried a factory reset, but no go. Any ideas??? Pretty stupid - if the network is screwed up, then there is no option to update the software locally.
hcl1 is offline
post #2729 of 2750 Old 02-20-2016, 07:33 AM
mike808's Avatar
Jay
You'll need to dig around but Pioneer programmed their receiver to a specific WiFi adapter chipset. You'll need to either buy their adapter or the easier way to go is to get a bridge adapter (i.e. a wifi dongle with a short ethernet and a power supply, since there is no power from the ethernet port on the receiver. You should have an access point that has some spare ethernet ports to hook up to your receiver. Or get one and put it into bridge mode and park it next to your receiver.
mike808 is offline
post #2730 of 2750 Old 03-13-2016, 05:54 PM
Liked: 0
automatic spontaneous switching to HMG
totally new to forum here, did a quick search and didn't see anything obvious.
when i'm on DVD input, the receiver will spontaneously switch to HMG setting without me pushing any remote or buttons. it was less frequently a few weeks ago (1x/week) but now it just happened 3 times in 20 minutes. thoughts?
Jason Yeh is offline
Pioneer , Pioneer Vsx 1021 K 7 1 Home Theater Receiver , Receivers Amplifiers
