Official Pioneer VSX-521k owners thread - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 751 Old 09-24-2011, 03:25 PM
garold's Avatar
I used MCACC to set up my vsx 521-k, set the receiver to "auto surround" and it seems the only speakers putting out any sound are the two front speakers and a little SW. I turn on HBO to watch a movie and same thing, just the two front speakers and maybe a little SW.
I tried many different channels and the same thing, whether I'm watching sports, or a movie. Now when I use the ALC/Standard button and set the receiver to "Dolby PLII Movie" I get surround sound on every channel. Is something wrong with the receiver? Or is this normal for "Auto Surround"? Also, is there any way to get more Bass out of the receiver? I have a SW plugged into the subwoofer out on the receiver, but just don't get enough thump for my liking. I moved to this receiver from a Denon which gave me lots of thump on my SW. Thanks
garold is offline
post #152 of 751 Old 09-24-2011, 03:33 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Does the receiver display Dolby Digital when you're watching a HBO movie? If not do you have a HD cable box? If so it doesn't sound like you have the audio output set correctly on the cable box.
Afro GT
afrogt is offline
post #153 of 751 Old 09-24-2011, 03:55 PM
garold's Avatar
With receiver set on "Auto Surround" there is no display showing Dolby Digital. I know when I put a DVD in to watch, the receiver switched to Dolby Digital, but that was while it was set on "Dolby PLII Movie". I do have a Directtv HD DVR connected to the receiver with an HDMI cable, then from receiver to tv with HDMI cable. I'm not sure what you mean by audio output setting on the cable box (DVR)?
garold is offline
post #154 of 751 Old 09-25-2011, 05:55 AM
toofart's Avatar
I had to configure my cable box to output Dolby Digital. Even then, most of the channels are simply 2.0 not 5.1 so although the DD symbol lights up, it's 2 channel, and Imust use DPLII to get surround.
Make sure your components like the DVD player are connected to the receiver via HDMI, and that each component is set to send bitstream audio, not PCM.
Also, make sure your rear speakers are plugged into the surround rear, not the SURROUND BACK connectors.
toofart is offline
post #155 of 751 Old 09-26-2011, 07:44 AM
garold's Avatar
I'm not sure how to set a unit to send bitstream audio, I'll play around with it and figure it out. I'm pretty sure the rear speakers are plugged into the surround rear because they do output some sound, but I will check that also. Thank you
garold is offline
post #156 of 751 Old 09-26-2011, 06:36 PM
toofart's Avatar
MCACC hadn't set the rear speakers loud enough for my taste. On the Pioneer I went to the advanced setup, speaker setup and raised the volume of the rears a few notches. World of difference.
Setting your devices to ourput bitstream depends on the device. If it has a menu or an on-screen config of some kind, go into the setup and audio options. Check the manual if you're not sure.
toofart is offline
post #157 of 751 Old 09-27-2011, 12:19 AM
ivsh's Avatar
Hi all,
I consider buying the VSX-521 but I am a little worried about something...
I know that this particular model is supposed just to pass the video without modifying it at all (it doesn't even overlay an OSD) but does that really mean the picture quality will not change...
The thing is... I have read a lot of reviews of people complaining about serious HDMI noise issues. They say the receiver is introducing some amaount of noise in the form of black dots.
So, is there such an issue with yours?
ivsh is offline
post #158 of 751 Old 09-28-2011, 12:40 PM
g4s
g4s's Avatar
Originally Posted by ivsh View Post
Hi all,
Yes. I took mine in for service this morning. I should hear what they're going to do about it in a couple days.
This is my 6th Pioneer receiver since the early 70's and the only one I've had any trouble with. Pretty good record overall.
g4s is offline
post #159 of 751 Old 09-28-2011, 07:42 PM
ivsh's Avatar
Thanks a lot man...
Then, I think I am going for the VSX-520. Here in Europe, I think it actually comes equipped with MCACC, so the only difference (that concerns me) between the old and the new one is the PSU.
The VSX-521 has a much better power supply I think... at least its power rating is better.
I know that the new model has OSD, but since it is analog only, I don't think I would make any use of it anyway... so...
Any other advantages of the VSX-521 over the VSX-520?
ivsh is offline
post #160 of 751 Old 09-29-2011, 07:55 AM
g4s
g4s's Avatar
Thanks a lot man...
Not that I know of.
I doubt the video problem is that widespread on the 521 though. If the European 520 doesn't have MCACC, I would get the 521. The 521 sounds a lot better than my previous receiver. I think it's because of the MCACC setup feature.
g4s is offline
post #161 of 751 Old 09-29-2011, 09:31 AM
ivsh's Avatar
Not that I know of.
It does have MCACC here in Europe...
What was your previous receiver by the way? Just curious...
ivsh is offline
post #162 of 751 Old 09-29-2011, 10:02 AM
g4s
g4s's Avatar
It was a VSX-D710S http://www.pioneerelectronics.com/PU...vers/VSX-D710S
We had a lightening strike that ruined the optical inputs on it. (and killed a lot of other electronics around here) It still worked though. I set it out on my driveway with the remote, manual and a note that described the problem and said FREE. It disappeared fast.
g4s is offline
post #163 of 751 Old 09-30-2011, 12:42 AM
balboa dave's Avatar
Quoted: 17 Post(s)
To all of the current (or former) owners: Overall, are (were) you happy with this receiver? Would you still buy one today, or recommend it to a friend?
balboa dave is offline
post #164 of 751 Old 09-30-2011, 05:05 AM
toofart's Avatar
I am very happy with it. I would buy one again, especially considering their price when they're on sale at Best Buy.
toofart is offline
post #165 of 751 Old 09-30-2011, 07:20 AM
Charles R's Avatar
Liked: 536
I returned mine...
http://www.avsforum.com/avs-vb/showt...1#post20885851
http://www.avsforum.com/avs-vb/showt...7#post20964607
It was the cheapest at well under two bills but I punted anyway.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #166 of 751 Old 09-30-2011, 09:34 AM
Iteki's Avatar
Ok, this is on sale at one of the major daily deal sites. Is between 100-200 a good deal for one?
I'm no expert....so your mileage may vary
XboxLiveID: archie68
Iteki is offline
post #167 of 751 Old 09-30-2011, 09:49 AM
alpha21's Avatar
I bought 2 from the deal
1 will probably be a gift to the parents, who desperately need an upgrade and the other I'll probably be using in my non theater setup, unless it is equal to my Denon which I doubt. I could use the HDMI inputs though, since my Denon has none
Mits-WS55413;Denon-3803;ToshibaXA1 HD-DVD;Klipsch- RF35;Samsung-TS160;SVS PB12plus/2
XBL GT - se7entee7
alpha21 is offline
post #168 of 751 Old 09-30-2011, 10:21 AM
fkramer's Avatar
This receiver is only $150 on woot(dot)com today only!! I think I"ll be getting one!! ( can't enter URLs as I'm a new member )
fkramer is offline
post #169 of 751 Old 09-30-2011, 10:51 AM
Iteki's Avatar
I bought one to replace my aging Onkyo with no HDMI...crossing fingers!
Iteki is offline
post #170 of 751 Old 09-30-2011, 02:10 PM
kenelbow's Avatar
Same here. I hope I don't have any of the noisy picture over HDMI issues that I've seen others mention.
kenelbow is offline
post #171 of 751 Old 09-30-2011, 02:39 PM
Quoted: 17 Post(s)
Thanks. You should see their price on woot.
Originally Posted by Charles R View Post
I returned mine...
Thanks. Since your comparisons were based with receivers costing 2-4 times as much, I'll keep that in perspective. I am considering this for my bedroom, so your insightful comments about the low end should not be a problem for me.
post #172 of 751 Old 09-30-2011, 02:51 PM
toofart's Avatar
Shiz that is a steal.
toofart is offline
post #173 of 751 Old 10-01-2011, 11:50 AM
vitis's Avatar
Hello,
I bought VSX-521 about two weeks ago. I want to switch between my laptop with HDMI out (Acer 5820TG) and my HTPC with HDMI out too. There was no problem with HTPC (little problem was old HDMI rev, so i can't output lossless DTS and DD), but my laptop cannot output higher resolution than 1280 horizontaly and only in mirroring mode. I can output 1280×720, 1280×768, 1280×1024, but when I set to output 1920×1080 lcd in laptop starts to blink and I hear how receiver is beeing connected and unconnected. Is there any solution for my laptop?
Second question is about my HTPC. I bought nVidia GT520 to be able to output lossless DTS and DD and there's same problem as on my laptop. Only 1280×xxxx in mirroring mode.
Can you help me somehow please? Or is this receiver PC unfriendly? :/
PS: sorry, for my english
edit:
Receiver video output is going to Acer X243H LCD monitor.
vitis is offline
post #174 of 751 Old 10-01-2011, 02:54 PM
jddesigned's Avatar
I wanted to chime in that after 3 months I finally saw the black dot issue. It was after adding new speaker wire/speakers and unplugging the HDMI from my cable box (I think there may have been an update to the box the night before too) Anyways after unplugging and turning off/on the receiver and DVR a few times the issue went away. Not sure if I should be concerned but I'll keep you all updated if things go bad.
jddesigned is offline
post #175 of 751 Old 10-01-2011, 05:15 PM
toofart's Avatar
I looked closely, and I see black dots also. I'll try swapping some HDMI cables to see if that fixes it.
Disappointing.
Edit: I only see dots from my WD TV Live, which is connected to the receiver via a "3 for $9.99" hdmi cable. Maybe I went a bit too cheap on that one. No dots from my Pioneer DVD player.
toofart is offline
post #176 of 751 Old 10-01-2011, 08:33 PM
g4s
g4s's Avatar
I got mine back from the shop. He said he wasn't able to reproduce the problem. Only has a 32" display there. Probably not noticeable on it. Not what I wanted to hear. He talked to guy at Pioneer who wasn't aware of anything like that. I was told to change out cables, try different HDMI inputs. If that doesn't fix it he said he would replace the "board" when it becomes available in a couple weeks.
One of my cables is a 1.3 so I ordered a high speed cable for it. Hope that solves it.
I tried outputting different resolutions out of my Panasonic BD80. Everything is fine up to 1080i. When I output 1080p, that's when the dots show up. Seems like a bandwidth problem. Maybe the 1.4 cable will take care of it.
g4s is offline
post #177 of 751 Old 10-01-2011, 09:54 PM
Charles R's Avatar
Liked: 536
Actually, I paid under $200 for two of them (basically the same price as the Pioneer). The other I purchased on close-out... yes roughly twice the price ($399). Fry's is the home of the $199 receiver. This week the Onkyo TX-NR509.
post #178 of 751 Old 10-02-2011, 06:17 AM
toofart's Avatar
That matches what I'm seeing. My DVD is a 1080p player, but I have a quality cable connected to it. My WD TV is also a 1080p but has a crappy cable. I'll try swapping the two to see if it makes a difference.
toofart is offline
post #179 of 751 Old 10-02-2011, 08:37 AM
g4s
g4s's Avatar
Let us know how it does. I'm curious and won't have my cable for a few days.
g4s is offline
post #180 of 751 Old 10-02-2011, 03:38 PM
jddesigned's Avatar
For me it's cheap 1.4 HDMI cables and a DVR set to 1080i.
