Needs some advice on the right AV Receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-16-2011, 11:01 AM - Thread Starter
schneidercom's Avatar
I am looking for and AV Receiver that can process hdmi audio sources and output a preamp signal to a separate amp to run a whole house speaker system.
I've seen receivers that only send preamp out when using stereo inputs. Are there amps that'll convert 5.1 signals to stereo and output all sources to preamp?
Thanks in advance!
schneidercom is offline
post #2 of 2 Old 03-16-2011, 11:13 AM
Kal Rubinson's Avatar
Quoted: 697 Post(s)
Liked: 477
That is pretty easy to satisfy but not at the lowest prices. Here's one: http://us.marantz.com/us/Products/Pa...oductId=SR5005
Sure, you can specify stereo output from any source but it will be the same at the main outputs as well.
Now, if you are looking for an independent zone or two, that is another story.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
