Onkyo TX-NR609, TX-NR509, TX-SR309 Thread - Page 131 - AVS Forum
post #3901 of 3905 Old 10-17-2014, 05:32 PM
DocCasualty's Avatar
Quoted: 37 Post(s)
Liked: 217
Originally Posted by JChin View Post
Strange, before you were able to duplicate this.
I remember we had this discussion 3 1/2 years ago. I'm going to have to play around with this again because I could never get it to work with the other inputs, which I think is what we're talki ng about here. Maybe you're correct that there is a work around for digital audio inputs. Analog audio inputs are easy to switch.
My "solution" is to bypass the AVR with a component cable for video in this situation. So yes, it is an HD video picture, though a max of 720p/1080i. So choose whatever digital input you want for an audio source and that's what the AVR is set to. I use a Harmony remote and just program a button to switch to video component 1 in to the TV when I wish to do that. So for instance, I can play music from my NAS via NET, iPod or from the Apple TV and watch a sporting event from the DVR.
I have for instance used a different analog audio source on the VCR input where I have my HDDVD player hooked up via HDMI. To play the sync of Pink Floyd's "Echoes" with the "Jupiter and Beyond the Infinite" sequence of 2001: A Space Odyssey, I just have to switch the audio input to analog and plug in my iPod. This is one of the reasons I asked about this 3.5 years ago when we got into this discussion, JChin. I'll have to go back and try this again but believe I couldn't make happen what I needed to on the necessary AVR inputs. I seem to recall at that time you had a predecessor AVR to the 609; am I not remembering correctly?
"Dave, this conversation can serve no purpose anymore. Goodbye." - 2001:ASO
DocCasualty is online now
post #3902 of 3905 Old 10-18-2014, 11:36 AM
am_dew's Avatar
Quoted: 21 Post(s)
This is another option by connecting the iPad to the CBL/SAT analog input.
- select CBL/SAT input to watch DVR
- on the remote press "Receiver" and then "Setup"
- scroll down to select menu "Source Setup"
- scroll down to select menu "Audio Selector"
- now change Audio Selector CBL/SAT from HDMI to Analog
Just remember to change Audio Selector CBL/SAT back to HDMI when finish.
I had never tried plugging the analog audio from the iPad into the CABL/SAT analog audio input (did not even realize it existed - DOH!). Once I did this it worked perfectly using the steps above. Thanks to all!
am_dew is offline
post #3903 of 3905 Old 10-21-2014, 10:49 PM
am_dew's Avatar
Quoted: 21 Post(s)
In follow-up to this issue, has anyone ever been successful at creating a "macro sequence" with a Logitech Harmony remote which will change the audio selector from HDMI to Analog? It seems the numbers in Onkyo's Setup menus have no relevance with regards to being able to invoke the menu option by clicking that number on the remote control. Not being able to do this, essentially disables your ability to create a macro sequence because otherwise you are having to use the up/down arrows and that is no good since you may land on any given item at any given time (ie. it seems to remember the last option you picked).
am_dew is offline
post #3904 of 3905 Old Yesterday, 09:48 AM
nas1080p's Avatar
Hi guys, I'm from uk and was wondering...Does jose from onkyo give you warranty for the amp if it was bought off ebay as a used item?
nas1080p is offline
post #3905 of 3905 Old Yesterday, 11:07 AM
Liked: 0
I also bought a used one on ebay - came with no remote.
Currently I don't know how to change the input from analog to anything else. I've taken the following steps:
1) plug in optical cable to pc and configured default output from pc as optical (I'm using a ASUS Z97-AR motherboard)
2) assigned optical1 to one of the input mode "game"
3) changed audio selector for "game" to optical
Still, on the receiver's screen I only see "analog".
Mustakotka is online now
Onkyo Tx Nr609 7 2 Channel Network Thx Certified A V Receiver , Onkyo Tx Nr509 5 1 Channel Network A V Receiver , Onkyo Tx Sr309 5 1 Channel Home Theater Receiver
Gear in this thread - Nr609 by PriceGrabber.com
