Onkyo TX-NR609, TX-NR509, TX-SR309 Thread - Page 132 - AVS | Home Theater Discussions And Reviews
post #3931 of 3939 Old 01-17-2015, 02:32 PM
david0406's Avatar
Originally Posted by gregger77 View Post
Hi all,
Totally new to the universal remote world here...so patience is appreciated!
I have a home theater based on TX-NR609 AV receiver which as you know has good "systemwide" capability but can't be programmed for "activities" or macros, so I bought the 650. Got it all set it up according to instructions (very nice, smooth on-line et-up routine!) for my Panasonic TV, Panasonic Blue Ray player, Panasonic DVD Recorder, and of course the AVR.
The remote will not do anything with the Onkyo. Won't power it on. When I try to "fix" the power on command, and go into manual learning mode, the Harmony will not respond to / accept the Onkyo remote's signal. Some notes:
- Yes, the Onkyo remote is in great condition, has fresh batteries, and works flawlessly with the receiver and everything else in the system.
- Yes, I am VERY carefully positioning both remotes according to instructions, and then also slightly changing the alignment during attempted learning to get the right angle. Nothing.
- Yes, on the Onkyo remote you can plainly see the signal emitter firing consistently during attempted learning.
- Yes, the Harmony display shows it is patiently attempting to receive the signal during learning.
So...
- It seems odd the 650 won't work the Onkyo at all without any manual learning. BTW, the Onkyo RIHD setting was already to "OFF"
- It seems even more odd that the 650 doesn't learn the Onkyo signal or apparently even see it.
Any help appreciated! (I am also posting this in the Harmony 650 thread.)
Not sure why your 650 won't power your NR 609. My Harmony One has always worked with my 609 and I have a SR-313 that's works fine with a Harmony 650. I have never had to use the learn function of Harmony with any Onkyo receiver I have owned and that number is 4. Are you sure you programmed the right Onkyo into " Your devices"?
david0406 is online now
post #3932 of 3939 Old 01-21-2015, 11:14 AM
Liked: 0
Originally Posted by DocCasualty View Post
Depending on your model there is probably a page very similar to this in your LG's audio setup menu. Make sure and choose "Primary Pass-Thru or something similar in the options.
Exactly this!! Thank you so much!
When I first tried to look for this setting, I had a DVD playing and I was going into the settings for the DVD. I actually had to RTFM in order to find out there there was a higher-level settings menu where I could set the audio output. Amazing what I've been missing for the last two years... and I thought my surround was working the whole time!
Thanks again!
Mitchum is offline
post #3933 of 3939 Old 01-21-2015, 11:34 AM
DocCasualty's Avatar
Quoted: 129 Post(s)
Liked: 1242
Thanks again!
You're most welcome. Glad it worked out and enjoy the sound!
"Dave, this conversation can serve no purpose anymore. Goodbye." - HAL 9000
DocCasualty is online now
post #3934 of 3939 Old 01-23-2015, 04:52 AM
JRWalker's Avatar
Quoted: 16 Post(s)
Liked: 41
"Loss of Audio/Network Connection Customer Care Program" Extension
Reminder: Onkyo's "Loss of Audio/Network Connection Customer Care Program" has been extended to 2018. The program extends the warranty, for specific problems, for new and refurbished receivers manufactured between 2009 and 2012 in the USA https://repair.onkyousa.com/na/003_2012.php?country=USA . Those in other countries can start here for their programs https://repair.onkyousa.com/na/ .
I had intermittent sound problems on my TX-NR609. Following the link above I was offered repair of my 609 or rebate on choice of new Onkyo. I chose $125 rebate on TX-NR636, which I purchased on Amazon. Very pleased with the new receiver. Wasn't expecting to see improvement in picture quality but it was noticeable on my Samsung PN-60F8500. Since the NR636 supports Dolby Atmos, I purchased Onkyo SKH-410 speakers. Enjoy the improvement in sound on Dolby 5.1 sources which are now 5.1.2.
JRWalker is offline
post #3935 of 3939 Old 01-23-2015, 11:34 AM
greeno's Avatar
just some feedback on the repair of my 609 under the customer care program. it took awhile, almost 2 weeks from when i submitted the form on-line, to get the packaging materials. from mailing it off though until receiving it it back took about 1 full week. I did verify i received back the same SN as I shipped to them.
the 609 is now my backup receiver should the new 636 go out. I note that i have a squaretrade warranty on the 609. they also would repair it free of charge and with free round-trip shipping. I didn't go that way as the repair was through a 3rd party central electronics repair facility.
Best,
jeff
greeno is offline
post #3936 of 3939 Old 01-24-2015, 06:33 PM
gregger77's Avatar
Figured out part of the Harmony problem...
After a long period of finagling, it turns out...
1) I goofed. Looking at the diagram of how to teach the Logitech to learn commands, it looked like the two remotes are placed "head to head." In fact, the arrangement is "head to toe" (weird but cool, I suppose, that the Logitech has IR sensors at both ends).
2) Logitech goofed. They sell a product whose database of thousands of common home theater equipment still, after what I have discovered from many different web threads, is not that great with Onkyo receivers.
Logitech technical support walked me through "learning" every single command from the Onkyo remote that I need to watch TV, listen to music, etc. Eager to get me off the phone, he said, "That's all, right?" I said, "Well, sure, for now, but there are DOZENS of commands that I use the Onkyo remote for while doing these activites--change aspect ratio, change audio profile from Dolby to All Channel, etc. etc etc. Are you saying I your database doesn't know a single one of these...and that I have to teach all of them to the 650?" He said, yep, that's what I'm saying.
He'd "make a note of the issue" and they'd "let me know" when they get their Onkyo receiver commands database "fixed."
Ha.
gregger77 is offline
post #3937 of 3939 Old Yesterday, 05:55 PM
Augerhandle's Avatar
Quoted: 99 Post(s)
Liked: 93
Ha.
I don't know which Onkyo remote came with your receiver, but the higher tier models have activity buttons and can learn to operate all your other equipment, so a Harmony remote would be superfluous. You can also order one of those learning remotes from OnkyoUSA. Since most of your activities used are with the Onkyo, and not with the TV, Set top Box, or Player, you won't need too many commands to be learned for them anyway.
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
Augerhandle is offline
post #3938 of 3939 Old Yesterday, 11:03 PM
sage11x's Avatar
Quoted: 374 Post(s)
Liked: 583
This years Onkyo models are a no-go for me since they dumped Audyssey. Atmos for Audyssey is a raw deal, IMO.
"For small creatures such as we the vastness is bearable only through love."
--Carl Sagan
sage11x is offline
post #3939 of 3939 Unread Today, 03:49 AM
david0406's Avatar
Can the Onkyo higher tier remote also operate each function of the individual devices as the Harmony remotes can? I am not sure what the issue was with the user's Harmony and the Onkyo was or is but I have 3 Onkyo's currently in service mated with Harmony's. 2 650's and 1 Harmony One. Maybe it is the newer models that he is having an issue with. I have an SR-505 and SR-313 and a NR-609
Onkyo Tx Nr609 7 2 Channel Network Thx Certified A V Receiver , Onkyo Tx Nr509 5 1 Channel Network A V Receiver , Onkyo Tx Sr309 5 1 Channel Home Theater Receiver
Gear in this thread - Nr609 by PriceGrabber.com
