Onkyo TX-NR609, TX-NR509, TX-SR309 Thread - Page 136 - AVS Forum | Home Theater Discussions And Reviews
 20Likes
post #4051 of 4068 Old 10-21-2016, 10:52 PM
gregger77's Avatar
Originally Posted by WeaponX Alpha View Post
Unfortunately, the answer is no. The HDMI board somehow also control the speaker outputs and there is no sound when the HDMI board breaks. With this failure, the Onkyo receptors become useless.
My 609 audio just started pooping out. First I got loud crackling / popping noises from the rear L and R speakers, then no sound at all. I am only able to watch TV by using HDMI pass through and putting the receiver in standby.
Does this sound like the "no sound" issue being addressed by the extended warranty action?
-- G.
gregger77 is offline
post #4052 of 4068 Old 10-23-2016, 08:57 AM
WeaponX Alpha's Avatar
-- G.
Onkyo support list of symptoms that may be related to a faulty HDMI board are:
- Loss of sound experienced on a specific channel.
- Loss of sound experienced on all channels.
- Speaker indicator on display is not showing.
- Speaker indicator on display is on.
- "Now Initializing..." message on display is showing constantly.
- Network settings in Setup Menu is grayed out (unselectable).
- Loss of video on HDMI output.
- Noise/crackled audio comes out of speakers (after verifying speaker wires and audio connections are secure).
In my 509, I had loss of sound on all channels, speaker indicator on display not showing and network settings grayed out, but video using HDMI output worked fine.
You need to contact Onkyo support. Using the receiver serial number, you can verify if yours is covered under the extended warranty and get it repaired for free.
WeaponX Alpha is offline
post #4053 of 4068 Old 10-23-2016, 10:38 AM
gregger77's Avatar
Thanks, I have a few of those symptoms.
I went on-line, verified my S/N was covered, and signed up for the repair program. Prepaid shipping box on the way.
post #4054 of 4068 Old 12-01-2016, 11:47 AM
scipper77's Avatar
Quoted: 39 Post(s)
My brother in law lost his setup mic for his 509. Does anyone know if the mic for my 609 will work for him? I can't find a part number for my mic but it looks like his is Acm1h.
scipper77 is offline
post #4055 of 4068 Old 12-05-2016, 09:02 PM
gregger77's Avatar
As a belated follow-up, the receiver came back in less than a week! So far it works flawlessly, but a little differently. HDMI start-up takes longer than it did before. I have no issue with it if it's going to be more reliable.
post #4056 of 4068 Old 12-06-2016, 07:24 AM
raistline's Avatar
Quoted: 35 Post(s)
Liked: 25
You will also notice the cooling fan kicking in more often, or at least that is what I saw when I got mine repaired.
raistline is offline
post #4057 of 4068 Old 12-29-2016, 06:31 PM
Liked: 0
New member here looking for some help with my TX-NR509. I've had it for about 4 years and it's worked great with no issues, until today. I had been watching tv with my kids for about a half hour when all of a sudden the receiver shut down. Strange thing was it kept cycling on and off. When it would power on I'd here, what i believe is, the relay then every pixel of the display would light up for 1/2 a second before it would shut down, only to start turning on again.
I called Onkyo and the guy basically said he's never heard of this issue before and I would have to pay for at least a diagnostic fee at a service center.
I'd like to pick the forum's brain about what this might be and what I might try. I tried doing the factory reset but it doesn't stay on long enough - same goes for a firmware update, doesnt' stay on long enough. I took the cover off to look for anything obviously burned out or melted.
Thanks for any help you might provide.
Md44022 is offline
post #4058 of 4068 Old 12-29-2016, 11:04 PM
Augerhandle's Avatar
Quoted: 743 Post(s)
Liked: 649
Send it in to Onkyo. They'll lose it, and then they'll give you a new one
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #4059 of 4068 Old 12-30-2016, 06:29 AM
Liked: 0
I'm detecting a hint of sarcasm there, but I'd surely have to pay at least shipping charges and whatever fee they'd charge for diagnosing/fixing it.
Md44022 is offline
post #4060 of 4068 Old 12-30-2016, 04:15 PM
Quoted: 743 Post(s)
Liked: 649
They lost mine
Get an estimate from them, or a local shop. Weigh the cost against a new unit, and then decide.
post #4061 of 4068 Old 01-02-2017, 08:16 PM
Liked: 0
They lost mine
Thanks. I called the service center in NY a few days ago and they said they'd diagnose it for free and tell me the cost to fix. I figure the cost to ship it ($20) was worth it to find out if the fix is cheap and easy or cost prohibitive, or anywhere in between. I'll report back.
Md44022 is offline
post #4062 of 4068 Old 01-12-2017, 07:52 AM
andyross63's Avatar
Quoted: 228 Post(s)
Liked: 71
Out of curiosity, does the TX-NR609 have the ability to somewhere show the bitrate of digital audio being fed it? For example, for DD, could it show if it's 384, 448, etc...
Need help with your Motorola DVR? Check the Wikibook: How to use a Motorola DVR
andyross63 is offline
post #4063 of 4068 Old 01-12-2017, 07:39 PM
scipper77's Avatar
Quoted: 39 Post(s)
I don't think it can. At least mine doesn't by default and I've never seen anything indicating that there may be a setting to do so.
post #4064 of 4068 Old 01-13-2017, 12:57 AM
hyperactiveme's Avatar
Quoted: 119 Post(s)
Liked: 72
I have the 609 and am anyways messing around with the listening modes for movies/games. Is there a set it and forget it that I should just leave it at? I normally stitch between all stereo and thx movie. I never use direct.
Everytime I run audesey I get different result and I use the Xbox one s as my media hub. I'm not disappointed by the sound however I'd like to stop messing around with it.
I'm assuming everyone just pass through the video and not use any presets either.
hyperactiveme is offline
post #4065 of 4068 Old 01-13-2017, 08:31 AM
andyross63's Avatar
Quoted: 228 Post(s)
Liked: 71
It can vary on just what you really want.
You are probably right that many users will have the video set for pass thru or equivalent.
I don't think I use any of the pre-defined modes. I do have the Audyssey set up. I also have 2.0 audio set to use PLII Movie decoding. Other formats are unmodified.
post #4066 of 4068 Old 02-08-2017, 12:37 PM
Merlin2000's Avatar
I just switched out my receiver from a Marantz SR7001 to the Onkyo TX NR609. I have a HSU VTF-15H MK2sub.
When I had the sub connected to the Marantz, I was able to feel the sound of certain scenes through my clothes. Using the same settings on the sub, the super low lows are just not hitting the same. I'm comparing the same audio scene that was run under both receivers. Literally watched the same scene 100 times to re-tune the speakers.
Is there some other setting on the TX NR609 that might be limiting the sub? Just not sure where to look. The sub has a built-in amp that I'm using. I do see the option for speaker distance with the sub. Wondering if I should just set that to 0ft?
Merlin2000 is online now
post #4067 of 4068 Old 02-08-2017, 12:56 PM
Tesla1856's Avatar
Quoted: 86 Post(s)
Liked: 66
Have you tried setting the manual Volume and Frequency response on the sub near max, and then running full Audyssey Calibration on Onkyo?
Living Room Home-Theater:
Epson 8350 Projector (1080p @ 96") / Panasonic 850u 46" 1080p Plasma TV
Onkyo TX-sr607 AVR (7.2ch ~ HDMI ~ wrat-Amp 630 watts )
AppleTV-4 / Panasonic dmp-BD60 Blu-Ray Disc Player / Cisco 8742hdc DVR (TWC)
Harmony 670 Remote / HTPC (Kodi/Win10-64) Media Server PC / Synology 12tb Raid-5 NAS
Polk Audio Monitor Series-II Speakers (Large 6.1 Matched Separates) / psw-505 12-Inch Sub
Tesla1856 is offline
post #4068 of 4068 Old 02-08-2017, 01:07 PM
Merlin2000's Avatar
- I have the sub set to play 40hz and below, volume is at 6.5/10 (another sub is hitting the higher frequencies, but I've left that off for this test/tune).
Rather than Audyssey, I have a musician friend that has lent an ear for fine tuning each speaker for the type of movies we watch. We've nailed the 5 surround speakers perfect, it's just the sub we're having trouble with.
Setting was the same on the sub for both receivers. It just looks like the Onkyo has a ton more options for additional ways to manipulate the signal, and I'd rather have the sub's amp do all that work... I just can't tell what else is being manipulated.
Onkyo Tx Nr609 7 2 Channel Network Thx Certified A V Receiver , Onkyo Tx Nr509 5 1 Channel Network A V Receiver , Onkyo Tx Sr309 5 1 Channel Home Theater Receiver
