Onkyo TX-NR609, TX-NR509, TX-SR309 Thread - Page 137 - AVS Forum | Home Theater Discussions And Reviews
 20Likes
post #4081 of 4088 Old 07-23-2017, 05:41 AM
JChin's Avatar
Quoted: 354 Post(s)
Liked: 205
Originally Posted by JRock3x8 View Post
I don't think this is right - the BDV-E770W can decode and pass through Dobly Digital and DTS so what is the problem? Everything is set to Auto on the player's settings menu...
I don't follow why the BD player should be an issue.
Hi JRock3x8, suggest to re-check your BD player audio setting menu ... BD Audio MiX Setting should be Off.
JChin is offline
post #4082 of 4088 Old 07-23-2017, 05:45 AM
JRock3x8's Avatar
Quoted: 708 Post(s)
Liked: 187
Ok that was on. Thanks.
JRock3x8 is offline
post #4083 of 4088 Old 07-23-2017, 09:54 AM
Tesla1856's Avatar
Quoted: 111 Post(s)
Liked: 68
Question
When you get a chance, please confirm whether or not real DTS-HD from a BluRay is fixed and working now on your Onkyo.
Living Room Home-Theater:
Epson 8350 Projector (1080p @ 96") / Panasonic 850u 46" 1080p Plasma TV
Onkyo TX-sr607 AVR (7.2ch ~ HDMI ~ wrat-Amp 630 watts )
AppleTV-4 / Panasonic dmp-BD60 Blu-Ray Disc Player / Cisco 8742hdc DVR (TWC)
Harmony 670 Remote / HTPC (Kodi/Win10-64) Media Server PC / Synology 12tb Raid-5 NAS
Polk Audio Monitor Series-II Speakers (Large 6.1 Matched Separates) / psw-505 12-Inch Sub
Tesla1856 is offline
post #4084 of 4088 Old 07-24-2017, 02:40 AM
JRock3x8's Avatar
Quoted: 708 Post(s)
Liked: 187
I'm not sure how I would see that. I have my BR player input set to DTS Neo : 6
JRock3x8 is offline
post #4085 of 4088 Old 07-24-2017, 10:08 AM
Tesla1856's Avatar
Quoted: 111 Post(s)
Liked: 68
1. I'm not sure how I would see that.
2. I have my BR player input set to DTS Neo : 6
1. I just meant "is your DTS working better now". It should say it on the Onkyo.
2. That is fine. Just remember that other than that one BD-AudioMix setting in the BD-Player/HTiB itself, you change all Listening Modes at the Onkyo. Also, only the Onkyo's display is accurate.
You can use Neo:6 if you want, but that is just a fake-surround mode ... usually for 2/3-channel stereo/pro-logic (to matrix them-out to more speakers).
post #4086 of 4088 Old 07-24-2017, 10:50 AM
JRock3x8's Avatar
Quoted: 708 Post(s)
Liked: 187
so what should my listening mode be set to?
I thought the reason you used those modes (ie NEO 6) is because they have the audyssey EQ whereas a straight pass through would not?
JRock3x8 is offline
post #4087 of 4088 Old 07-24-2017, 11:14 AM
Tesla1856's Avatar
Quoted: 111 Post(s)
Liked: 68
I don't mind chatting with you about this, but I get the feeling you are not reading and/or understanding the Onkyo manual (hard-copy or PDF). It's hard to convey all required info in a forum thread.
My understanding of Onkyo Listening Modes is ...
-When the Onkyo sees a certain sound format (from whatever source material) it does this certain thing with the sound before it is outputted to the speakers. There is a nice chart in the manual.
Especially for Blu-Ray discs (in a real BD-Player) I like to set them similar to this:
When the Onkyo sees this - It does this
Dolby Digital - Exact Dolby Digital to 5.1 speakers
DTS - - Exact DTS to 5.1 speakers
Dolby True-HD - Exact Dolby-HD to 7.1 speakers
DTS-HD - Exact DTS-HD to 7.1 speakers
2ch Stereo - NEO:6 to 5.1 speakers
3ch ProLogic - PLIIx-Movie to 5.1 speakers
... like that. Most of those use the sound directly from the DVD/BD, while the bottom ones digitally re-process the sound.
Actually, that's pretty much how I have all mine set for all Input devices.
I think the only Listening Mode that disables Audyssey is Direct. If you have properly run Audyssey Calibration (and like the more balanced and speaker equalized sound) ... you really don't want to be disabling Audyssey.
Edit for completeness:
I should also add that while these Listening Modes can be changed on-the-fly with the remote's buttons, I would rather they default properly automatically. This way, I don't have to mess with them or, if someone else is using the system (ie. Wife) they are set optimally automatically by default.
post #4088 of 4088 Old 07-24-2017, 09:17 PM
JChin's Avatar
Quoted: 354 Post(s)
Liked: 205
Use the Display Info button to reveal the incoming Audio as the AVR sees it.
Go into Listening mode and set:
Dolby D/Dolby D Plus/TrueHD to "Straight Decode"
DTS/DTS-ES/DTS-HD to "Straight Decode"
Other Multich Source to "Straight Decode"
JChin is offline
Onkyo Tx Nr609 7 2 Channel Network Thx Certified A V Receiver , Onkyo Tx Nr509 5 1 Channel Network A V Receiver , Onkyo Tx Sr309 5 1 Channel Home Theater Receiver
