Onkyo TX-NR609, TX-NR509, TX-SR309 Thread - Page 138 - AVS Forum | Home Theater Discussions And Reviews
 23Likes
post #4111 of 4117 Old 08-30-2017, 07:14 AM
Liked: 0
Onkyo TX-NR609 audio dropouts (compatibility issue with TV?)
Hello, I am new to this and in desperate need of your help!
My issue is, that I experience (at first) random audio dropouts using my Receiver (onkyo tx-609) connected to the TV (LG OLED 65B6V) via HDMI-ARC.
The dropouts are very short (fraction of a second) and appear on all speakers; depending on the material they appear from once in a movie to multiple times in a minute. Audio resumes normal after a dropout.
It only happens, when the receiver has to play a digital audio source (dts or dolby digital) with the tv (internal Netflix app or internal player) as its source.
I tried a replacement receiver connected the same way as the Onkyo -> no issues detectable anymore
The dropouts also disappear when I use another playback device (Amazon FireTV 2nd gen in my case)
what I have already tried:
- different HDMI cable
- other means of signal transport: optical SPDIF
- RMA of the TV -> mainboard change
- Receiver already went through the "loss of audio"-Customer Care Program
- RMA of the Receiver -> HDMI-processing board change
I am thankful of every help I'll get.
- Morehatz
Morehatz is offline
post #4112 of 4117 Old 10-01-2017, 12:06 PM
jaimocan's Avatar
Liked: 1
Angry Spotify dropped support for TX-NR 609
I just tried to connect my TX-NR609 to my Spotify premium account and discovered that this receiver along with a bunch of others is no longer supported.
https://support.spotify.com/us/liste...on-my-speaker/
Does anyone know why Spotify would block access from these receivers?
jaimocan is offline
post #4113 of 4117 Old 10-01-2017, 12:14 PM
Augerhandle's Avatar
Quoted: 879 Post(s)
Liked: 809
Less device specific software updates to write (cheaper).
"The wise understand by themselves; fools follow the reports of others"-Tibetan Proverb
_____________________ http://www.scientificamerican.com/article/auger-handle/ ____________________________
Augerhandle is offline
post #4114 of 4117 Old 10-01-2017, 12:40 PM
david0406's Avatar
Quoted: 23 Post(s)
I think Spotify wanted to eliminate the various different applications on different devices by streamlining use of the app through the mobile application. Just a guess and probably cheaper as the other poster stated. When I had my 609 I just connected a Chromecast to it and cast the app from my smartphone. This does require a WI-FI connection to your smartphone. I used to stream Spotify through my Roku3 and Spotify eliminated the use of playlists from the Roku app therefore rendering it useless to me in my opinion.
david0406 is offline
post #4115 of 4117 Old 10-01-2017, 01:58 PM
Tesla1856's Avatar
Quoted: 197 Post(s)
Liked: 76
Well, unless I'm missing something here, it sounds like you have already trouble-shot it down to a problem with the Onkyo 609 itself.
As far as ARC goes:
- ARC is only for content generated by the TV itself (like on-board tuners or TV-Apps)
- Turning-off ARC and using an optical SDPIF should be exactly the same thing (in fact, more "native")
- On my brother's system (Onkyo-609 and Panasonic Plasma), I recall having to turn-on HDMI-CEC on both to get ARC to work.
Living Room Home-Theater (Multi-Use Room):
Epson 8350 Projector (1080p @ 96") ~ Panasonic 850u 46" 1080p Plasma TV
Onkyo TX-sr607 AVR ~ Cisco 8742hdc DVR (Spectrum) ~ Panasonic BD60 Blu-Ray Player
AppleTV-4 (iTunes,Plex,DMA,Vudu) ~ Simple Control HA ~ Alexa Echo Dot
Harmony 670 Remote ~ HTPC (Kodi/Win10-64) Media-Server ~ Synology DS412+ 16tb Raid-5 NAS
Polk Audio Monitor Series-II CS-2 Center & 60,40 Pairs / PSW-505 12-Inch Subwoofer
Tesla1856 is offline
post #4116 of 4117 Old 10-01-2017, 02:18 PM
jaimocan's Avatar
Liked: 1
So, is it Onkyo that is not updating their receiver firmware? - sounds like a ploy to force me to purchase a new receiver when the existing TX-NR506 perfectly meets my needs.
jaimocan is offline
post #4117 of 4117 Old 10-01-2017, 07:01 PM
Tesla1856's Avatar
Quoted: 197 Post(s)
Liked: 76
Exclamation
Possibly, but in this case it appears to be Spotify's decision (as usual, the App developer is calling the shots).
As far as Onkyo not keep their firmware current, so is the case with many aged components that have advanced tech like this. For instance, VieraCast in both my Panasonic Plasma and Blu-Ray were great for the first few years. But then, slowly, we started loosing functional Apps (Amazon, YouTube, etc.). Nowdays, they are pretty much void of working popular Apps.
Something can be said for keeping "the cool stuff" in small up-gradable/replaceable boxes (connected via HDMI).
Onkyo Tx Nr609 7 2 Channel Network Thx Certified A V Receiver , Onkyo Tx Nr509 5 1 Channel Network A V Receiver , Onkyo Tx Sr309 5 1 Channel Home Theater Receiver
