Onkyo TX-SR608 Fried? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-04-2011, 11:32 AM - Thread Starter
jader201's Avatar
I was sitting here watching my TV, and all of the sudden, lightning made your power glitch a little, and now my receiver doesn't seem to be sending passthrough video. Audio works fine, and the receiver seems ok functionally, other than I don't get video.
I tried taking the HDMI cable from the output of the receiver, and plug it into my PS3, and the cable and TV seem fine -- video works fine that way.
So, either some setting got reset somewhere, or it's fried.
Any ideas? Maybe some other troubleshooting I didn't think of?
Thanks in advance.
jader201 is offline
post #2 of 5 Old 04-04-2011, 02:26 PM - Thread Starter
jader201's Avatar
If anybody stumbles upon this, the problem seemed to be a loose HDMI-out connection in the back. The plug is seated properly, but for some reason, there is suddenly an angle that the cord now loses connection. If I put some upward pressure on the cord, it picks up the signal.
Not sure if/how this was related to lightning, but that's when it started happening.
jader201 is offline
post #3 of 5 Old 04-04-2011, 02:51 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi jader201, try another HDMI cable.
Another option is a HDMI cable with locking retainer or HDMI lock adaptor.
JChin is offline
post #4 of 5 Old 04-04-2011, 04:09 PM - Thread Starter
jader201's Avatar
Thanks, JChin. I'll definitely keep that in mind if I start to have recurring issues with this.
jader201 is offline
post #5 of 5 Old 04-04-2011, 06:03 PM
M Code's Avatar
Quoted: 728 Post(s)
Liked: 438
You might consider using 90 degree HDMI adapters, they are available on line for about $5 each. By angling the cable downward, it relieves the weight of the cable itself from the chassis HDMI jack as they can be easily damaged by heavy cables..
Just my $0.02...
M Code is offline
Onkyo Tx Sr608 Receiver
