In Wall Amplifier - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-06-2011, 10:12 AM - Thread Starter
BigSkyDave's Avatar
Really, in-wall amplifiers are not for high-end audio systems, but does anyone have opinions on using them just to play music from an iPod or mobile device to built-in speakers?
BigSkyDave is offline
post #2 of 6 Old 04-06-2011, 12:32 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Someone else asked about this same thing, forget how far back. There are some small light weight amps out there if you don't need a lot of power.
I know those T-amps are pretty small, for example. Pyle makes a mini amp.
This is wide, but pretty thin, and the brand seems to have a pretty good rep (http://www.amazon.com/AudioSource-AM...2114715&sr=8-6)
"But this one goes up to 11"
MichaelJHuman is offline
post #3 of 6 Old 04-06-2011, 03:13 PM
jzoz01's Avatar
If you can still find one of the Sherborne IWA-1 amps, they are pretty slick. In wall and RS232 controllable with an adjustable crossover and sub out. I have one in the wall behind one of my TVs hooked to the variable audio out powering a pair of our on-wall Profile speakers. Makes a great little "tv enhancement" system.
jzoz01 is offline
post #4 of 6 Old 04-11-2011, 07:50 PM
srlindsey's Avatar
The AudioShare IWA-50 is a great in-wall amp. Lot's of power in a little package. Very reliable as well.
http://www.amazon.com/AudioShare-50w...ata/B001ULF2XS
I have also used an in-wall amp made by Pragmatic but it has been a few years since I've used them.
Good luck!
srlindsey is offline
post #5 of 6 Old 04-13-2011, 12:32 AM
ASRich's Avatar
I too have had good luck with the Audioshare IWA-50. I have a home recording studio and was driving the monitors with a reference amp. About 2 years ago, I tried the IWA-50 just for kicks. I haven't switched back to the reference amp since.
Rich
ASRich is offline
post #6 of 6 Old 07-23-2016, 10:24 AM
pkok3's Avatar
I've been looking for something similar. Thanks!
pkok3 is offline
