The "official" Yamaha RX-V671 thread. 7.1-Channel Network AVR - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 9Likes
post #181 of 2311 Old 07-13-2011, 04:35 PM
DR.DTS's Avatar
Quoted: 22 Post(s)
Someone over at the Harmony Forums (Logitech site) did ask about the codes for the 671 not showing up. It was suggested to either try the 667 or 867 and see. Didn't see an update or response if it worked or not. Still haven't got around to mine yet...(700)
Kenny J.
DR.DTS is offline
post #182 of 2311 Old 07-13-2011, 07:38 PM
Brutus63's Avatar
Kenny J.
I tried to configuration it by downloading the app instead of doing over the web and I'm still checking it out. Might be working!!!
Brutus63 is offline
post #183 of 2311 Old 07-13-2011, 08:19 PM
batman15's Avatar
Originally Posted by rdgrimes View Post
An inexpensive ethernet switch can connect as many devices to the wireless bridge as you wish. You'd probably want to get a 4-port switch.
Thats genius Thanks for the idea.
batman15 is offline
post #184 of 2311 Old 07-14-2011, 04:28 AM
daviseh's Avatar
I just got my V671 and set it up last night. It took a while to make sure I had the right combination of Audio and Video inputs but finally figured it out. I can not find a screen saver option. Most of the media players I have owned included this feature to prevent burn in.
Also, I ran the outs from Zone2 to an external amp to power my outdoor speakers. In setup, I chose 7.1 plus 1 and turned on Zone2. I tried to output Pandora and FM but can't get any sound out of Zone2. The manual indicates that these sources plus devices connected to the analog inputs should play through Zone2. I don't have any devices connect to the analog ports to try.
Any ideas of what I am doing wrong? Thanks for the help.
daviseh is offline
post #185 of 2311 Old 07-14-2011, 11:03 AM
gh02's Avatar
Hello everyone,
I recently bought the Klipsch Quintets. I am looking to get a receiver and I was thinking about getting the RX-V671. Is the RX-V671 going to be powerful enough to run these speakers and maybe bigger, more powerful speakers down the line?
I guess I am a little confused about all the power rating per channel stuff. The v671 has the following specs listed:
Rated Output Power (1kHz, 1ch driven) 125W (8ohms, 0.9% THD)
Rated Output Power (1kHz, 2ch driven) 105W (8ohms, 0.9% THD)
Rated Output Power (20Hz-20kHz, 2ch driven) 90W (8ohms, 0.09% THD)
What is this saying?
Thank you for your help,
Gloria
gh02 is offline
post #186 of 2311 Old 07-14-2011, 11:06 AM
rdgrimes's Avatar
Quoted: 2000 Post(s)
Liked: 1337
It's saying that the more channels being driven, the less power per channel. Only the 20-20kHz ratings have any real meaning.
rdgrimes is offline
post #187 of 2311 Old 07-14-2011, 03:34 PM
Townielax5JPL's Avatar
I got my 671 from a site called CrispDeals for $390 and got it in 3 days via UPS and am loving it. I'm not a huge audiophile or anything but it sounds a lot better than my Sony it replaced. I really love the internet radio and Sirius/XM (comes with a month trial).
I have the Harmony One and the 671 doesn't work too well with it so I was reading the 867 or the 667 is the way to go for Harmony full control, as I don't want to teach it. Basic controls like the D pad doesn't fully work. So the 667?
Also, is there a way to disable the on screen volume bar? I HATE THAT! I read someone say pages 98 of the OM and I didn't see anything there for that. Can someone send me the stet-by-step instructions for this...if its possible (running the 1.13 FW update).
Thanks everyone!
Townielax5JPL is offline
post #188 of 2311 Old 07-14-2011, 05:50 PM
cbhpi's Avatar
Search for "short message" in the OM, which will provide step-by-step instructions for disabling the volume level bar.
cbhpi is offline
post #189 of 2311 Old 07-14-2011, 06:08 PM
gh02's Avatar
So is that good enough for the speakers? Thanks.
gh02 is offline
post #190 of 2311 Old 07-14-2011, 07:29 PM
DR.DTS's Avatar
Quoted: 22 Post(s)
Originally Posted by gh02 View Post
Hello everyone,
Gloria
You'll be fine with them. I'm running a 7.1 w/presence speaker setup now. I've got Boston VRS 90 micros for the rear, a micro 90 for the center, a pair of PSB 500 Century for the fronts and Boston micro 90s as my presence speakers.
The Bostons are rated at 15-125 watts at 100-20,000Hz
The PSBs are 10-150 watts at 50-20,000Hz
Even though the specs on those Quintets show..."50 watts (200 peak)" you'll be fine unless you just really like the sound maxed out. Especially if you're running a 5.1 instead of a 6.1 or 7.1 setup.
DR.DTS is offline
post #191 of 2311 Old 07-14-2011, 07:56 PM
AWESOME Worked like a charm...THANKS
post #192 of 2311 Old 07-14-2011, 10:11 PM
gh02's Avatar
Okay, thanks for your help!
gh02 is offline
post #193 of 2311 Old 07-15-2011, 05:44 AM
DR.DTS's Avatar
Quoted: 22 Post(s)
I've got a question about YPAO
After running and saving it can I make a change say the fronts from small to large or up the db in the rears without effecting the saved settings?
DR.DTS is offline
post #194 of 2311 Old 07-17-2011, 10:01 AM
DR.DTS's Avatar
Quoted: 22 Post(s)
Never mind...I answered my own question last night. I change the fronts from small to large and it appears the settings stayed the same. I did hear a more lower end from the front stage that seeme more dispersed while not overpowering the mids and highs. I left everything else alone including the crossover setting YPAO picked, which cannot be changed, at 200Hz. I just know after throwing in Bttle L.A and Rambo 4 the overall sound was better.
DR.DTS is offline
post #195 of 2311 Old 07-17-2011, 04:43 PM
Tarrega's Avatar
Hello everyone,
Gloria
I have the very same speakers and just added the RX-V671 and am VERY pleased with the results.
Tarrega is offline
post #196 of 2311 Old 07-17-2011, 05:01 PM
Tarrega's Avatar
Has anyone had success with marking shortcuts on the RX-V671. I'm trying to mark a shortcut to a track on my iPod per the instructions but when I press the Memory button to do so, there's no reaction.
Tarrega is offline
post #197 of 2311 Old 07-17-2011, 05:41 PM - Thread Starter
cavu's Avatar
You have to hold the button down for an extended period!
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
post #198 of 2311 Old 07-17-2011, 05:50 PM - Thread Starter
cavu's Avatar
I recently bought the Klipsch Quintets. I am looking to get a receiver and I was thinking about getting the RX-V671. Is the RX-V671 going to be powerful enough to run these speakers?
The published specs on these speakers are:
SENSITIVITY: Satellite: 91dB@2.83 volts/1 meter
Center: 94dB@2.83 volts/1 meter
This means they can produce 85dB/SPL THX average loudness with 0.25W per channel and hit 105dB/SPL peaks with 25W per channel.
I think the RX-V671, with its 90W per channel, can handle it!
" - MLK
cavu is offline
post #199 of 2311 Old 07-17-2011, 08:22 PM
ufgatorindc's Avatar
Hey guys,
Looking for the best price on this receiver online factoring in shipping/sales tax to CA. Best I could find myself is $433 shipped from Electronics Expo (which as a mediocre reseller rating)
Looking to finally upgrade my Yamaha RX-v663...I do wish it had built in airplay...
ufgatorindc is offline
post #200 of 2311 Old 07-18-2011, 06:31 AM
Tarrega's Avatar
Thanks for the tip. I got this to work on a PC shortcut but it's still not working for my iPod (even after holding the memory button for a full minute). I'm using an old Video iPod. I'll try it with a newer version (Touch) this evening.
Tarrega is offline
post #201 of 2311 Old 07-18-2011, 01:05 PM
batman15's Avatar
So is there a Harmony remote that will work with this receiver?
batman15 is offline
post #202 of 2311 Old 07-19-2011, 06:37 PM
Txtate's Avatar
Pardon my technology ignorance, but is there any way to connect a RX 671 to an existing wireless network? I'm not keen on running cat5 through the attic and down the wall. If so, please explain how to do it in layman terms.
Thanks in advance.
Txtate is offline
post #203 of 2311 Old 07-19-2011, 06:45 PM
DR.DTS's Avatar
Quoted: 22 Post(s)
I won't get around to trying my 700 till this weekend. I'm waiting on a component-to-HDMI box from Monoprice so I can hook up my Xbox 360 thru HDMI instead of component. If they don't have a coe up yet for the 671 I'm going to try using the 871. I read someone suggested using "last years model" but the 667 doesn't have the 'net' button.
DR.DTS is offline
post #204 of 2311 Old 07-19-2011, 06:57 PM
cbhpi's Avatar
Thanks in advance.
Use a wireless ethernet adaptor, sometimes referred to as a wireless game adaptor.
cbhpi is offline
post #205 of 2311 Old 07-19-2011, 09:31 PM
Txtate's Avatar
Thanks. I assume that you are talking about one that connects to the Ethernet port and not the USB? Any suggested brands that are known to work with RX 671?
Thanks again.
Txtate is offline
post #206 of 2311 Old 07-20-2011, 01:22 AM - Thread Starter
cavu's Avatar
As I've stated before in this thread, my Harmony One works just fine (although it is still programmed for my old RX-V663).
" - MLK
cavu is offline
post #207 of 2311 Old 07-20-2011, 03:10 PM
Ambavi's Avatar
Does anyone have outdoor antenna is the only source connected to a TV? Since antenna is directly connected to TV, how do you feed video to this receiver? Friend of mine has a TV (KDL60NX810) with ARC HDMI port but video going directly to TV, what is the best way to connect this receiver to TV. Since I have connected HDMI output from receiver to ARC HDMI port in TV, the audio is working fine but no video. Any suggestions?
Ambavi is offline
post #208 of 2311 Old 07-20-2011, 05:37 PM
cbhpi's Avatar
Video is not sent to the receiver under this circumstance. Audio from the TV's tuner is fed to the receiver, either through the HDMI cable utilizing ARC or through an optical cable connection.
cbhpi is offline
post #209 of 2311 Old 07-20-2011, 05:37 PM
Mitch G's Avatar
If using OTA, then just run a spdif (optical) from the TV back to the receiver.
In other words, the video never goes through the receiver - nor is there really a reason for it to.
But, use an optical cable back from the TV to the receiver to get 5.1 from the HD channels.
Mitch
Mitch G is offline
post #210 of 2311 Old 07-20-2011, 06:01 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Hi Ambavi, select the correct video input (TV) on the tv.
JChin is offline
Yamaha Rx V671 Receiver
