The "official" Yamaha RX-V671 thread. 7.1-Channel Network AVR - Page 74 - AVS | Home Theater Discussions And Reviews
AVS | Home Theater Discussions And Reviews > Audio > Receivers, Amps, and Processors > The "official" Yamaha RX-V671 thread. 7.1-Channel Network AVR
captzerf's Avatar captzerf
07:26 AM Liked: 0
post #2191 of 2216
12-10-2014 | Posts: 8
Originally Posted by Bond 007 View Post
You are correct.
Have you tried a Google search? Look at the Yamaha website for accessories for the 671.
Thanks 007. I have spent a good amount of time searching online for a straight forward answer. I assumed that since I haven't found one it is either not possible or that I don't understand what the actual question I should be asking is. The only IR accessory on Yamaha's website that I can find is an IR blaster (transmitter); no sign of an IR receiver. So I need to understand what the IR range is for the Yamaha receiver in order to find an IR receiver that is compatible.
Bond 007's Avatar Bond 007
01:55 PM Liked: 925
post #2192 of 2216
12-10-2014 | Posts: 12,759
My brother has a remote IR receiver hooked up to his Yamaha AVR for his home theater. The AVR is in a room behind his theater screen and the IR receiver is in the theater.
I'll see if I can find out from him where he got the remote sensor and let you know.
http://www.monoprice.com/Product?c_id=109&cp_id=10110&cs_id=1011009&p_id=80 60&seq=1&format=2#specifications
Don't know if this one will work for you but it will be something like this.
05:41 AM Liked: 0
post #2193 of 2216
12-11-2014 | Posts: 8
{url omitted because I don't have the minimum number of posts}
Thanks. I was looking at that exact one last night, but can't seem to find if it would work with my receiver or not. I suppose it's cheap enough to purchase and try. I should also add for reference I tested with the IR receiver that works with my cable box, but it did not work with the receiver. So I guess I can use that information to rule out which other IR receivers might not work.
07:53 AM Liked: 925
post #2194 of 2216
12-11-2014 | Posts: 12,759
My brother said his came with his Logitech Harmony One remote.
Yi. It might be a process finding one that's compatible.
08:44 AM Liked: 0
post #2195 of 2216
Thanks for the follow up 007. I'll give that IR receiver from mono price a go. I'm pretty sure I have two Harmony One remotes, but I don't remember mine coming with any IR accessories. Are you sure it was part of another Logitech product?
11:45 AM Liked: 925
post #2196 of 2216
That's what he said. He's had it for years. Maybe the sensor was part of some sort of sale or something.
captnem0's Avatar captnem0
05:53 PM Liked: 10
post #2197 of 2216
12-15-2014 | Posts: 31
I have been using Xantech IR system. All my equipment is in a hallway closet.
I was wondering if I could unplug 1 emitter 283m cord (cord with mini jack on 1 end and relay sensor on other end which is attached to yamaha front panel remoter sensor), replace it with a mini plug patch cord (male both ends), plug 1 end to the emitter jack on the 789-44 and the other to my yamaha rx-v671 receiver using the remote in/out jack on the back (using the in jack).
Would this let me control the receiver just like if I was using the 283m cord with the ir sensor?
11:45 AM Liked: 0
post #2198 of 2216
12-16-2014 | Posts: 8
http://www.monoprice.com/Product?c_i...specifications
Unfortunately this cable didn't do the trick. I will try playing with it a little more tonight, but I plugged it in and got no response.
12:30 PM Liked: 925
post #2199 of 2216
12-16-2014 | Posts: 12,759
What about using the app or a pc to control the 671?
12:51 PM Liked: 0
post #2200 of 2216
I know the app works, but I'm not sure that is something that will fly with Wifey.
12:55 PM Liked: 925
post #2201 of 2216
lol The beauty of the app is supposed to be its simplicity and large screen.
01:00 PM Liked: 925
post #2202 of 2216
This is a thought if the free app won't do. It comes with a "Harmony Hub".
http://www.amazon.com/Logitech-Harmony-Control-Smartphone-Simple/dp/B00BQ5RYI4/ref=pd_sim_e_5?ie=UTF8&refRID=1JY4TG3EY05Z0T78R15Q
11:47 AM Liked: 0
post #2203 of 2216
12-31-2014 | Posts: 8
After a little back and forth with Yamaha support I've found out the following:
  • the "Remote In" and "Remote Out" jacks on the back of the receiver are not powered, and
  • the receiver will accept IR signals into the "Remote In" jack from a self powered device
So I bought this to self powered IR receiver
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
and ran a 50ft 3.5mm stereo extension cable and a male to male 3.5mm stereo cable from the self powered IR receiver to the "Remote In" jack on the back of the receiver
It appears to be working quite well. Thanks for all the help!
05:22 PM Liked: 925
post #2204 of 2216
01-01-2015 | Posts: 12,759
Good deal. Congrats!
lamplighter's Avatar lamplighter
07:02 PM Liked: 11
post #2205 of 2216
01-17-2015 | Posts: 120
Any chance we could get a firmware update to the 671 for ATMOS
08:39 PM Liked: 925
post #2206 of 2216
01-17-2015 | Posts: 12,759
Absolutely no chance.
fatbottom's Avatar fatbottom
04:18 AM Liked: 273
post #2207 of 2216
01-18-2015 | Posts: 4,488
Yes. Get a sticker like this and put it on front of your 671 next to the other logos
http://techwelike.com/wp-content/upl...mos-Logo-1.jpg
jeremygary's Avatar jeremygary
06:10 AM Liked: 18
post #2208 of 2216
01-18-2015 | Posts: 91
Have yet to even hear it at a theater. But the tech sounds very intriguing.
Sent from my GT-N8013 using Tapatalk
06:29 AM Liked: 11
post #2209 of 2216
01-20-2015 | Posts: 120
I have a 5.1 hookup, speakers are not bi amp connected. Should I use the 5.1 bi amp connection in setup or the basic setup..somewhat confused on this.
Thanks..
06:36 AM Liked: 925
post #2210 of 2216
01-20-2015 | Posts: 12,759
Thanks..
Basic
07:37 AM Liked: 11
post #2211 of 2216
thanks.
flashgeist
08:47 AM Liked: 0
post #2212 of 2216
Today | Posts: 3
Originally Posted by SkyWalker666 View Post
Bought the RX-V671 AVR for HTS but increasing listening to SACD's sending Multichannel DSD over HDMI and 2ch Stereo 96kHz downloads from a NAS (PC Input source) with Pure Direct enabled to improve quality. After upgrading firmware 1.47 to 1.60 have noticed a change in the sound signature. I found the flat sound signature for easy listening quite pleasing but now sounds like the tone control is still enabled or to my ears like a cat with it's balls caught in a vice.
Read some posts on this thread that suggest the firmware can be downgraded but unable to find a UK version of the 1.47 firmware on Yamaha's download page.
Any ideas where I could find this version or even if possible to rollback to version 1.47?
Even though it seems unlikely to me that a firmware could be causing this, I have the same issue. Maybe some setting has been reset, but I don't want to recalibrate my system because it was perfect the way it was before the update.
I mailed Yamaha's customer service but so far they ignored my message.
Does anyone still has a copy of firmware 1.47?
SkyWalker666's Avatar SkyWalker666
12:16 PM Liked: 10
post #2213 of 2216
Today | Posts: 6
Rolling back to firmware V1.47 solved my issue with 2ch Stereo 96kHz downloads from a NAS (PC Input source) with Pure Direct enabled to improve quality (think SACD multichannel was a control group). Yamaha's customer service did get back but took a few days to respond.
flashgeist
12:33 PM Liked: 0
post #2214 of 2216
Today | Posts: 3
That would be fantastic if you could mail me the firmware!
I cannot post my email address because my post count is under 5!
My email is a hotmail address, and the user name is daudetalphonse...
03:06 PM Liked: 10
post #2215 of 2216
Today | Posts: 6
Sent
flashgeist
05:22 PM Liked: 0
post #2216 of 2216
Today | Posts: 3
Sent
Thank you!
Tags: Yamaha Rx V671 Receiver
Gear in this thread - V671 by PriceGrabber.com
Subscribe to this Thread
Powered by vBadvanced CMPS v3.2.3
