The "official" Yamaha RX-V671 thread. 7.1-Channel Network AVR - Page 76 - AVS Forum | Home Theater Discussions And Reviews
post #2251 of 2264 Old 08-02-2015, 06:56 AM
austin_john's Avatar
Hi - I have a Sonos Connect and am trying to connect RX-671 via RCA cables so that I can get TV audio in kitchen. My setup is 3 HMDI inputs (Apple TV2, Cable, DVD) and HDMI output to TV (video only) and 2 front speakers (R/L) wired to the speaker terminals. I have tried both "Audio Out" and the audio terminals on the AV Out, but neither provide audio to the Sonos. I just upgraded to the newest firmware and have reviewed the settings. Not sure what "HDMI/Standby Through" is for (it's ON)and there are options on the "Speaker/Manual Setup" that show Bi-Amp and Extra SP, but not sure if these will help. Any assistance is appreciated!!
austin_john is offline
post #2252 of 2264 Old 08-02-2015, 07:22 PM
Nebor's Avatar
Anyone know if this old gal will pass through 4k? I just picked up a Samsung 4k TV and plan on connecting my Apple TV, desktop PC and Xbox one to it. I have no other problems with the receiver do it'd be a shame to get rid of it.
Nebor is offline
post #2253 of 2264 Old 08-04-2015, 12:44 PM
Sorry I didn't receive a reply to #2251 above, but for any others with a similar issue, the answer is that the unit will not convert the HDMI audio to analog audio and, therefore, the Audio Out will not have output. However, as a work-around, I can set the HDMI Audio Output to also send audio to the TV - and then use the RCA Audio Out from the TV to provide a signal to the Sonos component. Hope this helps other Yamaha 671 owners!!
post #2254 of 2264 Old 08-04-2015, 12:49 PM
2ndvizio's Avatar
Quoted: 12 Post(s)
It might be because it doesn't support hdmi to the audio out. I know it doesn't work when doing multizone for whole house audio but that's ok for me since I usually just use Pandora. If Pandora works for you then you are going to have to use a different audio source. When I had a cable box, I was able to run the av output from that to the receiver and that worked.
2ndvizio is offline
post #2255 of 2264 Old 08-18-2015, 07:27 PM
Liked: 0
Hello my friends,
my receiver has indicated the availability of a new version of firmware has been updated to version 1.75 firmware. I will review the options and tell them that brings improvements. greetings
Ricardo Cuéllar is online now
post #2256 of 2264 Old 08-19-2015, 03:21 AM
jeremygary's Avatar
Quoted: 34 Post(s)
Originally Posted by Ricardo Cuéllar View Post
Hello my friends,
Thanks for the info. I will check mine also.
jeremygary is offline
post #2257 of 2264 Old 08-19-2015, 03:49 AM
TentacleNo1's Avatar
Hello my friends,
Please, I'm curious
TentacleNo1 is offline
post #2258 of 2264 Old 08-19-2015, 04:42 PM
jeremygary's Avatar
Quoted: 34 Post(s)
Just got the 1.75 update prompt on my 671. D/L now. Had the receiver on all day, but it only showed up when I pressed the 'Onscreen' button on the remote.
post #2259 of 2264 Old 08-19-2015, 04:48 PM
Cla55clown's Avatar
Quoted: 44 Post(s)
Liked: 33
What does the update add or fix?
Cla55clown is online now
post #2260 of 2264 Old 08-19-2015, 04:51 PM
jeremygary's Avatar
Quoted: 34 Post(s)
Not sure. It is not listed on the website yet. Assume maybe it fixes Access Error with Pandora.
post #2261 of 2264 Old 08-20-2015, 08:26 PM
Liked: 0
Reviewing the settings (v1.75), I see some changes in the configuration screens for manual and automatic speaker. In my case I use the Napster - rhapsody service and with this new version have far more stability in the connection (with v1.60 in my case had cuts and sporadic blockades). Regards.
post #2262 of 2264 Old 08-21-2015, 03:12 AM
jeremygary's Avatar
Quoted: 34 Post(s)
Same here ... noticing far better stability with streaming. Kudos to Yamaha for continuing to support their products. They have earned my brand loyalty.
post #2263 of 2264 Old 08-31-2015, 01:21 PM
Toweri's Avatar
Liked: 0
Cool Firmware version 1.76 now available
Indeed!
I just downloaded and installed FW version 1.76. Yet another update more! (Probably some embarrassing bug they discovered on 1.75... )
This came via the "Firmware Update Through the Internet", a forced update via 'net (as described on "RX-V671 Firmware Update Version 1.60_Installation_Manual, downloadable at "download.yamaha.com/search/detail/?language=en&site=europe.yamaha.com&asset_id=63904 &category_id=16445&product_id=1485484&144105200 4"
It is odd that they do not publish the current 1.7x version on that download page...
I have been known to be wrong...
-- Me
Toweri is offline
post #2264 of 2264 Old Today, 07:16 PM
Liked: 0
Firmware V1.76
Hello, reviewing the performance of version 1.76 notice an improvement in downtime when switching between audio program options (eg hall of hall of Munich to Vienna to Chamber ) . This seems a good thing once already started playing a song and want to change the sound program or a movie to change the audio decoder, because you do not have a long silence in change.
Yamaha Rx V671 Receiver
Gear in this thread - V671 by PriceGrabber.com
