12v trigger cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 04-11-2011, 01:17 PM - Thread Starter
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
I want to connect my XPA-3 to my rx-v765 via the 12v trigger. Is the the cable I need...
Thanks!!!!
ratm is offline
post #2 of 12 Old 04-11-2011, 01:22 PM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
Thanks!!!!
Should be, I just hooked mine up to my 807 onk with just the cable. Went into my zone 2 output on the back and just have to activate the z2 button my remote, not sure how similar or not your yam is.
I'm guessing you have the interconnects already such as the RCA or XLR cables?
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
post #3 of 12 Old 04-11-2011, 01:37 PM - Thread Starter
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
Yup, got me 3 of these on their way...
All I'm looking to do with mine is just having to turn on the yammy and have the amp come on with it.
ratm is offline
post #4 of 12 Old 04-11-2011, 01:43 PM
whitey019's Avatar
Quoted: 90 Post(s)
Liked: 55
Thanks!!!!
While that may work.....you only need a mono, not stereo, cable.
whitey019 is offline
post #5 of 12 Old 04-11-2011, 02:12 PM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
Thanks!!!!
Right, I got my trigger cable included with my amp, maybe call Emo and ask if they could send one out?
Set up:
post #6 of 12 Old 04-11-2011, 02:17 PM - Thread Starter
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
I searched monoprice for a mono 3.5mm cable and found bubkus.
Ideas?
ratm is offline
post #7 of 12 Old 04-11-2011, 02:34 PM
Jacksmyname's Avatar
For my XPA2, I picked up a mono cable from Radio Shack.
Jacksmyname is offline
post #8 of 12 Old 04-11-2011, 02:57 PM
Quoted: 1392 Post(s)
Liked: 587
Don't have that model receiver, but on the 12volt triggers on my devices they're all mono plugs.
JimP is online now
post #9 of 12 Old 04-11-2011, 03:04 PM - Thread Starter
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
Like this??
http://www.radioshack.com/product/in...uctId=2102950#
ratm is offline
post #10 of 12 Old 04-11-2011, 04:48 PM
Yep.
post #11 of 12 Old 04-11-2011, 05:24 PM - Thread Starter
ratm's Avatar
Quoted: 39 Post(s)
Liked: 39
Awesome. I'll get that one.
So I can learn, what's wrong with using a stereo plug to connect the devices?
ratm is offline
post #12 of 12 Old 04-12-2011, 05:53 AM
I had picked up a stereo cable while waiting for my XPA2 to arrive. Posts on another forum said the stereo cable was needed for the trigger.
This was the first time using a trigger for me, so that's what I bought.
When I got the amp and installed it in my system with the stereo cable, it didn't work.
Ran out to Radio Shack and got the mono cable, and that worked.
ETA: The cable you posted is 1/8. I'm assuming that's equivalent to 3.5mm which is what you need (too early for me to do the math heh heh).
