Pioneer VSX-1121 Owner's Thread - Page 112 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #3331 of 3358 Old 07-17-2015, 05:24 PM
larrylwill's Avatar
Quoted: 29 Post(s)
Solved
Originally Posted by larrylwill View Post
Im suddenly having HDMI problems, I have 2 OTA tivos and 1 Direct TV and 1 BluRay DVD, it seems that Im having problems where I loose video or audio or both and I have to wiggle the cables for the source in. They all seem very loose with a lit of slop. All cables and all inputs. Has anyone else had such a problem. I have a new cable and it does the same thing, its sloppy and I have to play with it to get a connection. Im not sure if its the HDMI board or the connectors, any ideas?
Replacing all the HDMI cables fix all the problems. Seems that the pins lost their spring inside the cable shell.
larrylwill is offline
post #3332 of 3358 Old 07-17-2015, 05:30 PM
shivaji's Avatar
Quoted: 327 Post(s)
Liked: 210
Can someone tell me how to turn off and on the speakers with the remote? Im using earphones plugged in the back and the only way I can hear only through them is if I turn off the speakers. I want to program this into my harmony remote.
If I am not mistaken, there is not a button for that on the remote. You have to push the A and or B buttons on the unit itself to turn off the speakers.
shivaji is online now
post #3333 of 3358 Old 07-17-2015, 05:32 PM
larrylwill's Avatar
Quoted: 29 Post(s)
I was afraid of that. Which is what I am doing now.
post #3334 of 3358 Old 07-17-2015, 06:45 PM
shivaji's Avatar
Quoted: 327 Post(s)
Liked: 210
They probably thought that one will usually have to go to the receiver to plug the headphones in anyways, might as well just push the buttons while there.
post #3335 of 3358 Old 07-17-2015, 06:46 PM
larrylwill's Avatar
Quoted: 29 Post(s)
There wireless connected to the back of the receiver jacks.
post #3336 of 3358 Old 07-18-2015, 02:15 PM
GodFather13's Avatar
I'm selling my VSX-1121k
I posted my Pioneer VSX-1121k for sale on eBay if anyones interested. It's barely used and in near mint condition.
http://www.ebay.com/itm/Pioneer-VSX-...item43df759c9e
Sorry if this doesn't belong here...just trying to let people know if they are looking for a nice used one.
GF
GodFather13 is offline
post #3337 of 3358 Old 09-05-2015, 04:56 PM
Rich9132's Avatar
H.M.G not working
When I try to turn on the HMG it starts up for a second and then just switches back to one of my other inputs. Has anyone else experienced this and how did you fix it. Thanks for your help.
Rich9132 is offline
post #3338 of 3358 Old 09-07-2015, 12:16 PM
larrylwill's Avatar
Quoted: 29 Post(s)
Mine has always done that. I turn it on and select Tivo1 for instance but it goes back to a default input, sometimes I have to select Tivo1 2 or 3 times before it stays there.
I hope there is a fix. except leaving it on 24/7
post #3339 of 3358 Old 10-08-2015, 12:27 PM
geomatic's Avatar
Mine has always done this. I've had to keep trying until it sticks...very annoying. It also drops from the network regularly. It's hard wired so no Wifi issues.
My receiver also loses sound from the left speaker, subwoofer, and every so often right speaker. Mainly the left speaker....pretty much constantly. If I do the advanced sound test (loud static, so stupid) it works just fine afterwards. Once tuned off though, I have to do it again upon powering up. I've been fairly happy with this receiver but thinking it's time to go with Yamaha. There's been multiple other issues as well.
geomatic is offline
post #3340 of 3358 Old 11-29-2015, 02:09 PM
Nick_WI's Avatar
I have 2 questions. I've had my 1121 since it came out and didn't start having the speaker pop issue until after the first year. As of 2 pages back it looks like there was never a fix for it, correct?
Also, a buddy of mine has played DVD's directly from a PS3 and then a newer blu ray player that look much better than DVD's played on my PS3 through the 1121. I have seen this on 2 of his TV's and mine is quite capable of excellent picture. I don't play very many DVD's as much of my library is blu ray or digital, but it is frustrating to see his set up perform better lol. If the issue isn't the display, is there an up-conversion setting that I could have wrong? Should the PS3 or 1121 be doing the work? Does one or the other have to be turned off?
Visiting since 2002!
Nick_WI is offline
post #3341 of 3358 Old 12-05-2015, 11:18 PM
Liked: 0
Which plugs on the back of the receiver did you use for your wireless headphones so that you are still able to to keep the main speakers on? Was it the optical out jack? We are trying to allow my dad to use headphones to help him listen (he's hearing impaired) without turning off the speakers (such as what happens when you plug the headphones into the headphone jack).
aliparand is offline
post #3342 of 3358 Old 12-05-2015, 11:31 PM
larrylwill's Avatar
Quoted: 29 Post(s)
Just below the svideo connector in the mddle are a right and left center out one above the other. I use some cheap but good RF (not FM) headphones and the surround sound is great, I sware I can actually tell when a sound is behind me..
post #3343 of 3358 Old 12-07-2015, 08:35 PM
xrob's Avatar
Sonos player with optical audio + HDMI
Hi all,
This receiver has served me well with a traditional home theatre speaker setup until today. I decided to mess around with the SONOS components and bought a playbar and a sub. The playbar requires optical audio to work. I have not been using the optical ports, only HDMI. This has worked fine. Now I am trying to run the optical out in conjunction with HDMI and am not sure this is doable. When I run a cable from the optical out to the playbar, I get nothing. Furthermore, the optical ports do not appear to be active as I don't see any lights from them. Perhaps this is because the HDMI circuit is being used? I am hoping that optical can run in conjunction with HDMI, but so far, no luck. What *has* worked is choosing "HDMI through" from the options menu, which disables the auto HDMI feature, and I'm afraid most of the goodness that this receiver offers. Sure, I can get audio, but I am wondering what will happen with my other components (using a Tivo now).
Any and all advice/info on this would be most appreciated. This thread has been a fantastic resource for me over the years!
Rob
xrob is offline
post #3344 of 3358 Old 12-10-2015, 12:55 PM
graymoment's Avatar
I have owned the VSX-1121 for about 2.5 years now, I think. Last week I turned it on with my Roku input and only had audio playing from the Roku (no picture to my TV from the HDMI out on the receiver). I turned it off and then back on, and from that point forward I have not had either the audio or video playing from the receiver. I tried several options, looked to make sure I didn't have anything muted, etc., but I got nothing. I tried unplugging it for about an hour and that did not work. As a last resort, I did a reset to factory settings with the hold down the enter button and the standby at the same time option and put it back to factory settings. I still do not have anything coming out from the receiver to my speakers or TV.
My question is whether or not this receiver is dead or not. I can still change inputs, settings, etc. on the receiver, but I just do not get an output of any kind. Any advice that I can try before ordering a new receiver?
graymoment is offline
post #3345 of 3358 Old 12-10-2015, 05:27 PM
Liked: 0
I tried plugging some earplugs into those outputs using an RCA/headphone jack adapter but I didn't get any sound - do I need some sort of mini-amp in order to connect wired headphones to those outputs or is there something else I need to do?
I was thinking about getting dad a pair of open-back (he needs to be able to hear the phone ring when listening) RF headphones that plug into the optical out, but was worried the slight signal delay might be annoying to him or people sitting near him. If your headphones are open-back, have you not had that problem?
post #3346 of 3358 Old 12-10-2015, 05:31 PM
larrylwill's Avatar
Quoted: 29 Post(s)
Im using a cheap pair of Big Lots RF ones about $15 and they work great. The RF ones have an amp inside the transmitter and the impiedence is low but ear bids are high so I doubt you'll hear anything unless you turn the volume way up, besides the earphones have a volume control inside them and an amp.
aliparand likes this.
post #3347 of 3358 Old 12-15-2015, 12:30 PM
TransAmLS1's Avatar
I am trying to connect my Windows 10 Ultrabook with Intel Radeon 4400 graphics (latest driver installed) to my Pioneer VSX-1121 receiver through the front HDMI port. The TV is a Mitsubishi WD-82840 DLP.
The computer recognizes the display as "VSX-1121" but I get no Audio or Video. I hook up the laptop directly to the TV and it works fine.
Any idea why the receiver isn't passing the signal to the TV? Is it capable of what I'm trying to do? I want to end up getting audio through the receiver so I can play through my speakers and video on my TV.
TransAmLS1 is offline
post #3348 of 3358 Old 12-15-2015, 12:31 PM
TransAmLS1's Avatar
post #3349 of 3358 Old 12-15-2015, 04:45 PM
graymoment's Avatar
It seems as though my message did not get a response, which makes me think that this might not have been the right place to post my question.
Can someone help point me in the right direction in terms of where I can go to determine if my receiver is repairable, or if it's dead and I need to buy a new one? I would expect a receiver to last more than a few years, but maybe not.
Thanks in advance for any help in pointing me in the right direction.
post #3350 of 3358 Old 12-17-2015, 11:30 AM
xrob's Avatar
Hey there. I think because this receiver is a few years old that fewer of the "experts" are hanging out here. Mostly it's people who have questions (like me, a few above, also unanswered). Hopefully a more knowledgeable person will swing on by and help us all out.
Rob
xrob is offline
post #3351 of 3358 Old 02-20-2016, 07:21 AM
mike808's Avatar
You might make sure you're running the latest firmware from Pioneer.
mike808 is offline
post #3352 of 3358 Old 02-20-2016, 07:56 AM
mike808's Avatar
Originally Posted by JuiceRocket View Post
Hello all!
Up until yesterday, I've never used my VSX-1121 to play music from sources other than what was broadcast through my STB.
I was able to set it up to access music from the internet radio function (what an insane amount of stations....wow)
Is there any way to listen to Google Play music from a Mac through the VSX-1121? Although my Mac is on my wifi network, my VSX doesn't seem to see it in the H.M.G.
-JR
You Mac needs to be using AirPlay to broadcast signal to the receiver. I don't have a Mac, but I used an AirPlay program for the VSX to think it was one.
JuiceRocket likes this.
mike808 is offline
post #3353 of 3358 Old 02-22-2016, 08:58 AM
JuiceRocket's Avatar
Quoted: 50 Post(s)
Liked: 41
Thanks Mike! I went old school and used a cable to attach physically to my Mac. I need to dedicate some time to see if I can work with AirPlay to get the VSX to connect!
-JR
JuiceRocket is offline
post #3354 of 3358 Old 02-22-2016, 09:54 AM
LNEWoLF's Avatar
Quoted: 104 Post(s)
Liked: 75
Is there any error codes present.
This thread may be of interest
UE22 Error Master Thread-Pioneer, are you listening?
Liv Rm, Mitz 73740 DLP, Pioneer Elite SC 97 AVR, 7.1.2, Sony BDP-BX650, ATV G3, Harmony Smart Control, I Pad Air, Winegard FL6550A, F L R Cerwin Vega AT-12, Cen JBL EC-35, S R L JBL CST-56, S Backs JBL Loft 50 Towers, JBL E-10 Angled To Reflect Off Ceiling to MLP (Modified Atmos), MBed Rm, Mitz WD65413 R Proj HDMI to DVI, Sony BDP BX650, 2 Home Worx HW180 STB OTA Tuners with 2TB DVR, J Tech Digital JTD4KAT0301SW 5 HDMI in 1 HDMI out Audio Extractor, Bose SR1 5.1 Sound Bar, Harmony 650
LNEWoLF is offline
post #3355 of 3358 Old 03-03-2016, 08:09 AM
akarol's Avatar
Hi there,
I have purchased a Chromecast Audio and have hooked it up via a Y RCA cable to the back of the receiver onto the L/R front speaker ports. This works great, but when I mute my TV, it mutes the entire receiver. Is there a way to hook up the Chromecast audio so that its volume control is isolated from that of the rest of the unit? I would like to have it so that when I mute the TV, the CC is still playing.
Thanks in advance...
akarol is offline
post #3356 of 3358 Old 03-15-2016, 07:36 AM
Mavinwow's Avatar
Quoted: 362 Post(s)
Liked: 433
My HDMI board died, everything else seems to work.
Any idea if this is user replaceable?
Samsung 55ES8000
Vizio 70 P Series, Calibration settings
CalMAN 5 Novice Walkthrough
Denon X4200, 5.1.4 setup
Mavinwow is offline
post #3357 of 3358 Old 04-25-2016, 09:16 AM
tylerh's Avatar
I'm considering upgrading my desktop HT card from a nividia gts 250 to something like a gtx 750.I was only able to get stereo out of the hdmi so I also ran an optical cable.Does any one know if newer video cards support 5.1 just using HDMI to the 1121?Thanks
tylerh is offline
post #3358 of 3358 Old 05-01-2016, 06:28 AM
uh2
uh2's Avatar
Not sure if I ever came back to post this, but I can confirm that assigning a static IP address fixes the problem with the mobile app not finding the receiver.
uh2 is offline
