Pioneer VSX-1121 Owner's Thread - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
Old 12-21-2011, 03:53 PM
dubnspace's Avatar
Originally Posted by ten8yp View Post
Speaking of that... there are ENTIRELY too many Officially Unofficial threads that label themselves "Official"... like this one. Who do I talk to about that?
I don't see any "Official" in the title of this thread...
dubnspace is offline
Old 12-21-2011, 03:56 PM
millerrh's Avatar
Originally Posted by G37x View Post
OK, since I haven't gotten any answers here, decided to mess with this and boy it sounds unbelievable. Came to the conclusion that all these calibration systems are basically useless, all they do is to make your system sound dull, w/o bass and trouble. So what I did was to adjust the EQ using all that old curve (for all 7 channels), and then lower the level for each channel per my taste (last EQ column on the right). I just wish you could adjust the EQ in real time using music not the tones. Using these settings and also the EXT STEREO, this AVR is phenomenal, really....next to test a movie....
Cheers,
G37x
What is "that old curve?" is that where bass and treble are in the positive and mid range stays close to 0? Like a Nike swoosh?
millerrh is offline
Old 12-21-2011, 06:27 PM
ten8yp's Avatar
You are correct... I edited my post as such. Might as well have been. Someone started an Ownership thread before the product was even available for purchase.
I'm done.
ten8yp is offline
Old 12-21-2011, 06:51 PM
G37x's Avatar
Yes that is correct. I believe I set up mine like this (I didn't want to go all the way to 8,9, that would be the max) :
L/R: 7 6 5 4 3 4 5 6 7 -3
SB/SL/SBR/SBL/C: 6 5 4 3 3 4 5 6 -2
You can play with the level (last column on right) to fit your needs. I like to hear all my speakers. Why I hate the calibration systems? Because all they do is to make your speakers suck, really...In my case the bass/trouble was cut big times and only meds to go through. Test it and you won't believe what this Pio can do.
Cheers!
G37x is offline
Old 12-21-2011, 07:06 PM
Pastor Jim's Avatar
How is it that you do what you are talking about here?
Pastor Jim is offline
Old 12-22-2011, 07:59 AM
leobag's Avatar
Originally Posted by bhazard View Post
The one thing I wish this receiver got around is the copy protection on the optical out port when using hdmi as an input for sound/video. I would have loved to drive my Turtle Beach headphones out of the Optical out port for movies off my PC, but the copy protection wont let it. I have to pass through to my tv's optical port which will only do stereo.
Yeah, I find this a bummer too. Are there receivers that *do* enable any type of digital audio out (even if it is downsampled to stereo) from the unit?
Also, how do you pass through to your TV's optical port? Do you use the "HDMI Through" settting?
leobag is offline
Old 12-22-2011, 08:41 AM
feadin's Avatar
A 150hz crossover would sound terrible.
I think there's either a bug with MCACC or bass crossover settings in general on this receiver. You must use the icontrolav2 app to get your bass back inside the emphasis section, either using finger eq or the bass section.
Bhazard, thanks for your reply. I used only once the Full Auto MCACC, I think I need to do manual adjustments to improve the sound. My sub is not THX certified, perhaps that's why MCACC didn't put the crossover at 80hz?
And I can't use the icontrolav2 app since my receiver is not connected to my network. Is it really worth it or can I make satisfactory adjustments without the app, just with the receiver? I find the Pioneer wi-fi adapter expensive...
feadin is offline
Old 12-22-2011, 08:42 AM
Greg Robinson's Avatar
Has anyone had issues with AirPlay/HMG in zone 2 timing out? I've been experiencing an issue where Zone 2 airplay music (sourced from a wireless Powerbook/iTunes) will stop after 30 mins in Zone 2, yet it will continue playing in Zone 1. Is there a setting I missed, or does this sound like a glitch? I would say it's a network/wifi issue, BUT the fact that zone 1 keeps playing the HMG music makes me think it's a receiver issue. Thoughts?
Thanks and merry christmas!
"Have you ever fired two guns whilst jumping through the air?"
-Danny Butterman, HOT FUZZ
Greg Robinson is offline
Old 12-22-2011, 09:04 AM
Gary Quiring's Avatar
One big hassle with the 1121 is entering passwords for services like Pandora. They use the archaic up/down arrows to cycle through the whole alphabet to enter your login and password data. To add insult the iPad app is not supported for entering this info. Plus if you plug a USB keyboard in, it also only supports the up/down arrows to enter the data!! I can't believe how out of date this interface is.
Gary Quiring is offline
Old 12-22-2011, 09:33 AM
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 56
HDMI Through instead of HDMI AMP. Downsampled stereo works fine in this case, as its for a pair of headphones. I just wish it all came out of the amp so i wouldn't have to manually adjust the settings every time.
bhazard is offline
Old 12-22-2011, 09:34 AM
bhazard's Avatar
Quoted: 86 Post(s)
Liked: 56
Haha yeah that was a pain. I figured I'd rather have a crappy interface than no Pandora at all. Maybe they can add it in a firmware or icontrolav2 app update.
bhazard is offline
Old 12-22-2011, 10:22 AM
I just wish more iPad apps supported Airplay. I would much prefer to have Pandora on my iPad using Airplay than using Pandora directly on my 1121. I found the 1121 menus and navigation to be very clunky.
Old 12-22-2011, 10:47 AM
iafzal's Avatar
touche
iafzal is offline
Old 12-22-2011, 11:17 AM
JonCr's Avatar
You may be able to work around that. Start AirPlay with iTunes, then switch to Pandora. The iTunes may stop and the Pandora start with AirPlay still running. It works for the Sirius app.
JonCr is offline
Old 12-22-2011, 11:32 AM
owine's Avatar
Or just double tap home to get the multitasking bar and swipe to the right (you want what's to the left of the default view) and use the AirPlay icon there. All audio will work with AirPlay I believe.
owine is offline
Old 12-22-2011, 11:41 AM
Jeesh I must be Stevie Wonder for missing that one! Thanks for the great tip, it works great!
Old 12-22-2011, 05:47 PM
G37x's Avatar
I know this might be unrelated to this thread, but could someone shed some light for me on why I don't see the freaking airplay icon in the itunes? This sw must be the biggest POS ever invented by humans. Because of this I cannot play music from my PC via Pioneer AVR.
Thank you.
G37x is offline
Old 12-22-2011, 06:12 PM
JonCr's Avatar
Thank you.
You need to enable Home Sharing on your iPod (or Mac) in order for AirPlay to work. Have you done that?
JonCr is offline
Old 12-22-2011, 06:21 PM
G37x's Avatar
You mean Turn On Home sharing in Itunes?
G37x is offline
Old 12-22-2011, 06:24 PM
G37x's Avatar
You mean Turn On Home sharing in Itunes? I don't see why my Ipod would have anything to do with my PC-AVR connection... Yes I did turn On Home sharing in Itunes and still nothing..
G37x is offline
Old 12-22-2011, 06:36 PM
JonCr's Avatar
It doesn't. I use an iPod for AirPlay and missed where you said it was a PC. Sorry for the confusion.
JonCr is offline
Old 12-22-2011, 06:39 PM
G37x's Avatar
I see..I can see my AVR from my IPOD but airplay icon does not show up on my itunes...So basically I can play music from my Ipod via airplay to my AVR but not from my PC because of the missing icon. Can you pls check to see if yours work? Thanks!
G37x is offline
Old 12-22-2011, 06:44 PM
JonCr's Avatar
Mine works from iPod / iPhone with no problem. When I pick a song to play, the AirPlay symbol is in the lower right. You can also double tap the home button and then go to the right and get the airplay symbol. If you haven't already, go to settings - iTunes - and enable Home Sharing for the iPod (each device has to be set up)
JonCr is offline
Old 12-22-2011, 06:51 PM
G37x's Avatar
My question is when you go into itunes and play a song do you see the airplay symbol on the bottom right corner?
G37x is offline
Old 12-22-2011, 06:59 PM
owine's Avatar
Check your itunes settings there is something about AirPlay speakers. Might be under devices iirc.
owine is offline
Old 12-22-2011, 07:02 PM
G37x's Avatar
That's what I thought but don't see anything in there... Could you please check to see yours? Man this drives me nuts really..I'd really appreciate any help. I run itunes 10.5.2.11.
G37x is offline
Old 12-22-2011, 07:14 PM
owine's Avatar
owine is offline
Old 12-22-2011, 07:25 PM
G37x's Avatar
Thanks but mine doesn't have those options there...What itunes ver are you running please?
G37x is offline
Old 12-22-2011, 07:40 PM
owine's Avatar
Latest 10.5 version. Try uninstall and reinstall maybe?
owine is offline
Old 12-22-2011, 07:43 PM
G37x's Avatar
Thank you. I trust when you say latest 10.5 you refer to 10.5.2.11...I tried the repair option w/o luck..Will try uninstall and install.
G37x is offline
