Which Audyssey XT32 piece do you recommend, why? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 33 Old 04-27-2011, 10:51 AM
Kal Rubinson's Avatar
Quoted: 804 Post(s)
Liked: 570
Originally Posted by cybrsage View Post
Do both. OF course, the more perfect your room is, the less you need correction for the room.
Do both. OF course, the more perfect your room is, the more successful will be the total correction for the room.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #32 of 33 Old 04-27-2011, 11:41 AM
rnrgagne's Avatar
Quoted: 65 Post(s)
Liked: 65
+1
Since with multi-channel audio it's not just room acoustics in play but also the "blending" of those multiple channels, which includes timing and bass management that RC's like Audyssey breeze through.
I think passive acoustic treatments can have a bigger impact than EQ depending on the room, but the combination of both is unparalleled.
Current Gear: Anthem AVM60, D-Sonic 3500/7, Oppo UDP-203, PS Audio Nuwave Phono Pre, Technics SL1210 w/ Denon DL103, Dune Duo 4K, LG Oled55e6, Paradigm Sig. S6 & C3 v.3's, Monitor ADP's, Velodyne SPLR1200.
rnrgagne is offline
post #33 of 33 Old 04-27-2011, 11:50 AM
e2g_'s Avatar
Ok, thanks guys. I actually started to look at $400 and less receivers but couldn't imagine hooking up my Klipsch RF-7IIs and my Emotiva amps to such receivers. I may or may not tell the difference, but it would seem like having a really good sound system hooked up to my mother's old 1980 13" TV.
Ok, back on topic.
e2g_ is offline
